No display of voltage value on lcd
swapnil
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
no voltage display
PostPosted: Tue Jan 10, 2017 8:55 am     Reply with quote
#include <16F872.h> //equivalent with 10bit ADC
#device ADC=10
#fuses HS //Never use the 'Protect' fuse until you have completed
//your development. Doing so forces every cell in the chip to be erased
//every time you re-program - wastes chip lives. Otherwise the
//programmer will erase only the cells needed.
#use delay (clock=20MHz) // 20MHz
#define use_portb_lcd TRUE
#include <lcd.c>
#define  CCP1_PWM          PIN_C2
#define  MAINS_SWITCH      PIN_C3
#define  CHARGING_LED      PIN_C4
#define  PCU_LOAD          PIN_C5
#define  LOAD              PIN_C6
#define  LOW_BATT_LED      PIN_C7
#define MV_PER_COUNT (int16)(22.87/1024)
//We will do all the 'float' maths at compile time using this
//Not in the PIC itself
#define COUNTS_TO_MV(x) (x*MV_PER_COUNT)
#define TO_MV(x) ((int16)(x*1000))
int16 mean_adc(byte channel)
   const int16 AVERAGING_CYCLE_COUNT=32;
   int8 i;//mean_total = 32;
   int32 total =0;
   set_adc_channel(channel);
    delay_us(100);
   for (i=0; i<AVERAGING_CYCLE_COUNT; i++)
      delay_us(10); //specified Tacq for your chip
      total += read_adc();
   return(total/AVERAGING_CYCLE_COUNT);
//Tacq (no more is needed), is required before sampling, and between
//each reading. More != better.
//********** Main Program*******
void main ( )
   const byte SOLAR_CHANNEL=0;
   const byte BATTERY_CHANNEL=1;
   int16 battery_mv, solar_mv; //,bin,sin;
   set_tris_c(0b00000111);
   // setup_adc_ports(ALL_ANALOG);
   setup_adc_ports(AN0_AN1_VSS_VREF); // Only ever configure pins you
   //use as analog. Enabling others increases noise pickup on the ADC
   //Also setting this to use A3 as the Vref input (2.5v).
   setup_adc(adc_clock_div_32);
   setup_ccp1(ccp_pwm);                   // Configure CCP1 as a PWM
   setup_timer_2(T2_DIV_BY_1, 249, 1);   // Set PWM frequency to 5kHz
   //enable_interrupts(GLOBAL);
   //Since you are not using interrupts don't enable this.
   //Never enable 'GLOBAL', without at least one interrupt handler present
   delay_ms(255); //Many LCD's need 250mSec+ to wake
   printf(lcd_putc,"\f  WELCOME TO   ");
   printf(lcd_putc,"\n LUXNTEK SOLAR  ");
   delay_ms(50);
      solar_mv=COUNTS_TO_MV(mean_adc(SOLAR_CHANNEL));
      battery_mv=COUNTS_TO_MV(mean_adc(BATTERY_CHANNEL));
      //Now just have the two readings in integer mV
      printf(lcd_putc,"\fSOLAR   =%4.1LwV",solar_mv/100);
      //In 'C' the number in front of the DP is the 'total field width',
      //not the digits here . To display 2 digits, DP, one digit, needs a
      //field width of 4.
      printf(lcd_putc,"\nBATTERY =%4.1LwV",battery_mv/100);
      if(solar_mv > battery_mv)
      {  //solar > battery
          if (battery_mv > TO_MV(2.0) && battery_mv <= TO_MV(14.5))
          //This scares me. Do you really envisage any situation where
          //battery_mv can be below 10v?. If so you have a dead battery....
              setup_ccp1(CCP_pwm);
              set_pwm1_duty(500);
              output_high(CHARGING_LED);
              delay_ms(200);
              output_low(CHARGING_LED);
              delay_ms(200);
              printf(lcd_putc,"\fBATTERY CHARGING");
              printf(lcd_putc,"\n  BOOST MODE  ");
              delay_ms(400);
          if(battery_mv > TO_MV(14.5))
              set_pwm1_duty(100);
              set_pwm1_duty(200);
              delay_ms (600);
              printf(lcd_putc,"\n  TRICKLE MODE  ");
      { //solar<battery turn off
          delay_ms(300);
      /////////////////////////////LOAD ////LED INDICATION ///////////////////////////////////////////////////////
   //if dawn to dusk and load on batt
   //actually sounds as if you mean dusk to dawn here (solar <5v)
   if((solar_mv < TO_MV(5.0)) || (battery_mv > TO_MV(12.0)))
       output_high(LOAD);
   if(battery_mv <= TO_MV(11.0))
       output_high(LOW_BATT_LED);
       output_low(LOAD);
       output_low(LOW_BATT_LED);
   //  Mains SNS PCU Load On
   if((input(PIN_C3)==1) && (solar_mv > battery_mv) && (battery_mv > TO_MV(14.6)))
       output_high(PCU_LOAD);
       set_pwm1_duty(500);
   else if(battery_mv <= TO_MV(13.9))
       output_low(PCU_LOAD);
no display of voltage value on lcd
heroswap1981
PostPosted: Tue Jan 10, 2017 1:18 pm     Reply with quote
Have you connected the Vref?.
Remember I said the code was to use an external 2.5v Vref.
PostPosted: Tue Jan 10, 2017 4:59 pm     Reply with quote
This looks incredibly suspicious. You're making a small number, less
than 1, and then you're converting it to an integer. That will give you 0.
This means MV_PER_COUNT is 0. So the results of all the math below
are also 0.
In your earlier thread, Ttelmah told you:
So, learn to debug.
Print the number coming from the ADC with no processing at all. Is this right?.
Then work through things one stage at a time, checking the values, till you find where it goes wrong.
But you didn't do that.
How did I verify there was a problem. First I was suspicious.
Then I added a little code to the start of your program and compiled it:
void main ( )
// *** TESTING ***
   int16 temp;
 // Load this constant so we can see it in the .LST file.
   temp = MV_PER_COUNT;
   while(TRUE);
Then I looked at the .LST file and saw that temp is being set to 0x0000:
.................... int16 temp;
.................... // Load this constant so we can see it in the .LST file.
.................... temp = MV_PER_COUNT;
0311: BCF STATUS.RP0
0312: CLRF temp+1
0313: CLRF temp....................
.................... while(TRUE);
0314: GOTO 314
That means MV_PER_COUNT is 0x0000.
PostPosted: Wed Jan 11, 2017 8:14 am     Reply with quote
And you will see why if you think that the figure should be in mV.....
Twisted Evil
#define MV_PER_COUNT (int16)(22870/1024)
The pity is I was hoping to teach him how to debug.
