art
EX_USB_BOOTLOADER.C |
Posted: Sun Dec 25, 2016 9:30 am |
I've just compiled the EX_USB_BOOTLOADER.C, but it shows message Error 71 "usb bootloader.c" Line 339(1,2): Out of ROM, A segment or the program is too large load_program. Hope someone can explain to me. What should I do ?
#include <ex_usb_common.h>
Configure, then load the bootloader definitions
#define _bootloader
#include "usb_bootloader.h"
// Includes all USB code and interrupts, as well as the CDC API
#include <usb_cdc.h>
#define ROM_BLOCK_INVALID -1
int32 rom_block_start = ROM_BLOCK_INVALID;
#if defined(__PCD__)
#define EEPROM_ERASE_SIZE getenv("FLASH_ERASE_SIZE")/2
#else
int8 rom_block[EEPROM_ERASE_SIZE];
// see rom_w() documentation. performs the flushing
void rom_w_flush(void)
if (rom_block_start != ROM_BLOCK_INVALID)
#if !defined(__PCD__)
erase_program_eeprom(rom_block_start); //erase entire block
#else
erase_program_memory(rom_block_start);
write_program_memory(rom_block_start, rom_block, sizeof(rom_block)); //write modified block
// see rom_w() documentation. performs the writing
void rom_w_block(int32 location, char *src, int16 size)
int32 block_start;
int16 i,num;
block_start = location & (~((int32)EEPROM_ERASE_SIZE-1));
i = location - block_start;
while (size)
if (block_start != rom_block_start)
rom_w_flush();
rom_block_start = block_start;
read_program_memory(block_start, rom_block, sizeof(rom_block)); //read entire block to ram buffer
if (size>(EEPROM_ERASE_SIZE-i)) {num=EEPROM_ERASE_SIZE-i;} else {num=size;}
memcpy(&rom_block[i], src, num); //modify ram buffer
src += num;
block_start += EEPROM_ERASE_SIZE;
i = 0;
size -= num;
// Write to Flash ROM.
// location - flash program memory address
// src - pointer to data to write
// size - number of bytes to write to flash
// Here is the sequence of events:
// 1.) Goes to the beginning of the first erase block for this address
// 2.) Reads n records to ram, where n is the PIC's flash erase size
// 3.) Erases block in flash
// 4.) Modifies block in RAM
// 5.) Writes changed block back to FLASH. Writes in chunks defined by PIC's flash write size
// 6.) Goes back to step1 if there is still more data to be written
void rom_w(int32 location, char *src, int16 size)
rom_w_block(location, src, size);
rom_w_flush();
#define BUFFER_LEN_LOD 64
#define ACKLOD 0x06
#define XON 0x11
#define XOFF 0x13
// Convert two hex characters to a int8
unsigned int8 atoi_b16(char *s)
char c;
unsigned int8 result = 0;
int i;
for (i=0; i<2; i++,s++)
c = *s;
if (c >= 'A')
result = 16*result + c - 'A' + 10;
result = 16*result + c - '0';
return(result);
void load_program(void)
int1 do_ACKLOD, done=FALSE;
int8 checksum, line_type;
int16 l_addr,h_addr=0;
int8 to;
int32 addr;
int8 dataidx, i, count;
int8 data[32];
int buffidx;
char buffer[BUFFER_LEN_LOD];
unsigned int32 address_erase;
for(address_erase=APPLICATION_START;address_erase<APPLICATION_END-EEPROM_ERASE_SIZE+1;address_erase+=EEPROM_ERASE_SIZE)
erase_program_memory(address_erase);
while (!done) // Loop until the entire program is downloaded
usb_task();
if (!usb_cdc_kbhit())
continue;
buffidx = 0; // Read into the buffer until 0x0D ('\r') is received or the buffer is full
to = 250; //250 milliseconds
do
delay_ms(1);
usb_task();
to--;
if (!to)
to = 250;
i = usb_cdc_getc();
buffer[buffidx++] = i;
} while ( (i != 0x0D) && (i != 0x0A) && (buffidx <= BUFFER_LEN_LOD) );
if (!to)
continue;
usb_cdc_putc(XOFF); // Suspend sender
do_ACKLOD = TRUE;
// Only process data blocks that start with ':'
if (buffer[0] == ':')
checksum = 0; // Sum the bytes to find the check sum value
for (i=1; i<(buffidx-3); i+=2)
checksum += atoi_b16 (&buffer[i]);
checksum = 0xFF - checksum + 1;
if (checksum != atoi_b16 (&buffer[buffidx-3]))
do_ACKLOD = FALSE;
count = atoi_b16(&buffer[1]); // Get the number of bytes from the buffer
// Get the lower 16 bits of address
l_addr = make16(atoi_b16(&buffer[3]),atoi_b16(&buffer[5]));
line_type = atoi_b16 (&buffer[7]);
addr = (make32(h_addr,l_addr)/2);
#else
addr = make32(h_addr,l_addr);
// If the line type is 1, then data is done being sent
if (line_type == 1)
done = TRUE;
else if (line_type == 4)
h_addr = make16(atoi_b16(&buffer[9]), atoi_b16(&buffer[11]));
else if ((line_type == 0) && (addr >= (int32)APPLICATION_START) && (addr < ((int32)APPLICATION_END)))
// Loops through all of the data and stores it in data
// The last 2 bytes are the check sum, hence buffidx-3
for (i = 9,dataidx=0; i < buffidx-3; i += 2)
data[dataidx++]=atoi_b16(&buffer[i]);
rom_w_block(addr, data, count);
#else
write_program_memory(addr, data, count);
addr += count;
read_program_memory(addr, data, count);
if(do_ACKLOD)
usb_cdc_putc(ACKLOD);
usb_cdc_putc(XON);
rom_w_flush();
while(!usb_cdc_put_buffer_free())
uart_task();
usb_cdc_putc(XON);
delay_ms(2000); //give time for packet to flush
reset_cpu();
HW_INIT();
//we use a button as an event to determine if we should start the USB CDC
//bootloader. if button is not pressed then goto the application, else if
//button is pressed then do the bootloader.
if(BUTTON_PRESSED())
usb_init_cs();
while(!usb_enumerated())
// necessary for polling function to work
#ifdef USB_ISR_POLLING
usb_task();
LED_ON(LED3);
load_program();
#asm
goto APPLICATION_START
#endasm
#int_default
void isr(void)
jump_to_isr(APPLICATION_ISR);
Posted: Sun Dec 25, 2016 10:36 am |
What is your PIC ? |
art
Posted: Sun Dec 25, 2016 11:02 am |
Pic18f4550 |
Posted: Sun Dec 25, 2016 11:23 am |
1. What's your compiler version ?
2. Did you un-comment the line for 18F4550 in ex_usb_common.h
as shown below in bold ? (and make sure all other PICs are commented out).
Quote: |
////// Begin User Configuration
#define USB_HW_CCS_PIC18F4550 //CCS PIC18F4550 USB Development kit
//#define USB_HW_CCS_PIC18F45K50 //CCS PIC18F45K50 USB Development kit
//#define USB_HW_CCS_E3 //CCS E3 Mini development kit. 18F14K50 with 12Mhz crystal.
//#define USB_HW_CCS_16F1459 //CCS Rapid USB devleopment kit. 16F1459 with no oscillator
//#define USB_HW_CCS_PIC24F //CCS 24FJ256GB206 USB Development kit
//#define USB_HW_CCS_PIC33EP //CCS PIC24 USB Development kit, PIC replaced with a 33EP256MU806
//#define USB_HW_CCS_USBN9604 //CCS National USBN9604 USB development kit (external USB peripheral)
//#define USB_HW_MCHP_18F14K50 //Microchip low-pin count USB development kit (PIC18F14K50) |
art
Posted: Sun Dec 25, 2016 4:38 pm |
1) compiler Version 5.008
2)Yes, I did un-comment the line for 18F4550 in ex_usb_common.h |
Posted: Sun Dec 25, 2016 6:24 pm |
I installed vs. 5.008 and was able to get it compile by editing the
usb_bootloader.h file in the Drivers sub-directory. I changed
the loader size as shown in bold below.
Quote: |
#define LOADER_START (0)
#define LOADER_SIZE (0x1900) // Was 0x1800 |
I don't guarantee this works. I didn't test the code. I just got it to compile. |
art
Posted: Sun Dec 25, 2016 6:37 pm |
I've change it to 0x1900 but it still give the same error.
Seg 0008E-017FE,01F0 left, need 00276
Seg 01800-0180E,000C left, need 00276
Seg 01810-07FFE,67F0 left, need 00276
Seg 00000-00006,0004 left, need 00276
Seg 00008-0008C,0000 left, need 00276
#define LOADER_SIZE (0x1900)//original 0x1800
#if defined(__USB_87J50__)
#define APPLICATION_END (getenv("PROGRAM_MEMORY")-9) //configuration bits
#elif defined(__PCD__)
#define APPLICATION_END (getenv("PROGRAM_MEMORY")-2)
#else
#define APPLICATION_END (getenv("PROGRAM_MEMORY")-1)
#if defined(__PCM__)
#define LOADER_END (LOADER_SIZE+0x40-1)
#elif defined(__PCH__)
#define FLASH_SIZE getenv("FLASH_ERASE_SIZE")
#if (((LOADER_SIZE) % FLASH_SIZE) == 0 ) //IF LOADER_SIZE is even flash boundary
#define LOADER_END (LOADER_SIZE-1)
#else //ELSE, goto next even boundary
#define LOADER_END (((LOADER_SIZE)+FLASH_SIZE-((LOADER_SIZE)%FLASH_SIZE))-1)
#define FLASH_SIZE getenv("FLASH_ERASE_SIZE")/2
#if (((LOADER_START+LOADER_SIZE) % FLASH_SIZE) == 0)
#define LOADER_END (LOADER_START+LOADER_SIZE-1)
#else
#define LOADER_END (LOADER_START+(LOADER_SIZE+FLASH_SIZE-((LOADER_SIZE)%FLASH_SIZE))-1)
#else
#error PCM, PCH, and PCD only supported
#define APPLICATION_START (LOADER_END+1)
#if defined(__PCH__)
#define APPLICATION_ISR (APPLICATION_START+8)
#elif defined(__PCM__)
#define APPLICATION_ISR (APPLICATION_START+4)
//// --- end configuration --- ////////////////////////////////////////////
#ifdef _bootloader
// bootloader won't use interrupts, instead it will poll USB IF
#define USB_ISR_POLLING
Provide an empty application, so if you load this .HEX file into the pic
without an application this will prevent the pic from executing unknown code.
#org APPLICATION_START,APPLICATION_START+0xF
void BlankApplication(void)
while(TRUE);
//we need to prevent the loader from using application space
#if (APPLICATION_END > 0x10000)
#org APPLICATION_START+0x10, 0xFFFF {}
#if (APPLICATION_END > 0x20000)
#org 0x10000, 0x1FFFF {}
#org 0x20000, APPLICATION_END {}
#else
#org 0x10000, APPLICATION_END {}
#else
#org APPLICATION_START+0x10, APPLICATION_END {}
#define USB_CONFIG_PID 0x0034
#define USB_STRINGS_OVERWRITTEN
char USB_STRING_DESC_OFFSET[]={0,4,12};
// Here is where the "CCS" Manufacturer string and "SERIAL DEMO" are stored.
// Strings are saved as unicode.
// These strings are mostly only displayed during the add hardware wizard.
// Once the operating system drivers have been installed it will usually display
// the name from the drivers .INF.
char const USB_STRING_DESC[]={
//string 0
4, //length of string index
0x03, //USB_DESC_STRING_TYPE, //descriptor type 0x03 (STRING)
0x09,0x04, //Microsoft Defined for US-English
//string 1 - manufacturer
8, //length of string index
'C',0,
'C',0,
'S',0,
//string 2 - product
30, //length of string index
'C',0,
'D',0,
'C',0,
' ',0,
'B',0,
'o',0,
'o',0,
't',0,
'l',0,
'o',0,
'a',0,
'd',0,
'e',0,
'r',0
#endif //_bootloader
#ifndef _bootloader
//in the application, this moves the reset and isr vector out of the bootload
//space. it then reserves the loader space from being used by the application.
#build(reset=APPLICATION_START, interrupt=APPLICATION_ISR)
#org 0, LOADER_END {}
Posted: Sun Dec 25, 2016 7:24 pm |
I'm running vs. 5.008 with your posted program.
I don't know, try a larger size. Try 0x1F00. See what happens. |
art
Posted: Sun Dec 25, 2016 7:52 pm |
I've tried...but the result still the same.
However when I skip the #int_default , it can be compile.
what does #int_default means?
//#int_default
void isr(void)
Posted: Sun Dec 25, 2016 8:09 pm |
Oh, that's one thing I forgot. Ttelmah explained in this thread
http://www.ccsinfo.com/forum/viewtopic.php?t=55739&start=35
that it really should be #int_global. I edited your program and
changed it to this:
Quote: |
#int_global
void isr(void)
Try that and see if it works. |
art
Posted: Sun Dec 25, 2016 8:32 pm |
I've change it to #int_global..... but when i compiled, error message appear.
Error 71 "usb bootloader.c" Line 339(1,2): Out of ROM, A segment or the program is too large MAIN
Seg 0001E-017FE,005C left, need 00068
Seg 01800-0180E,000C left, need 00068
Seg 01810-07FFE,67F0 left, need 00068
Seg 00000-00006,0004 left, need 00068
Seg 00008-0008C,0000 left, need 00068 |
Posted: Sun Dec 25, 2016 8:44 pm |
I don't know the reason. I'm compiling with vs. 5.008. I made only
the changes that I mentioned. It compiles OK for me:
Quote: | Executing: "C:\Program files\Picc\CCSC.exe" +FH "PCH_Test.c" +DF +LY -T -A +M -Z +Y=9 +EA #__buildcount__="0" #__18F4550=TRUE
Memory usage: ROM=19% RAM=23% - 30%
0 Errors, 0 Warnings.
Build Successful.
Loaded C:\Program Files\PICC\Projects\PCH_Test\PCH_Test.cof.
BUILD SUCCEEDED: Sun Dec 25 18:44:31 2016 |
art
Posted: Sun Dec 25, 2016 8:50 pm |
Dear PCM,
Could you paste your EX_USB_BOOTLOADER.C and USB_BOOTLOADER.H code here. Maybe I can check if there is any differences. |
Posted: Sun Dec 25, 2016 8:53 pm |
We're not supposed to do that, according to the forum rules which are in
the first thread at the top of the forum. I don't want to break the rules. |
art
Posted: Sun Dec 25, 2016 11:21 pm |
I really hope someone can confirm that the EX_USB_BOOTLOADER.C and USB_BOOTLOADER.H that i have is same with the latest version. Hope it can work. |
