dallas onewire primitives library and ds1822 driver code
jds-pic
PostPosted: Fri Jun 04, 2004 9:54 am     Reply with quote
http://losdos.dyndns.org:8080/public/onewire/lib-onewire.html
// onewire library, for dallas onewire devices
// currently includes:
//   - generic onewire functions (init, readbyte, sendbyte, crc, etc.)
//   - ds1822 dallas-semi econo-thermometer
// (C) copyright 2003 j.d.sandoz / jds-pic !at! losdos.dyndns.org
// released under the GNU GENERAL PUBLIC LICENSE (GPL)
// refer to http://www.gnu.org/licenses/gpl.txt
// This program is free software; you can redistribute it and/or modify
// it under the terms of the GNU General Public License as published by
// the Free Software Foundation; either version 2 of the License, or
// (at your option) any later version.
// This program is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
// GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with this program; if not, write to the Free Software
// Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
// ds1822 scratchpad registers
#define DS1822_SP_TLSB  0
#define DS1822_SP_TMSB  1
#define DS1822_SP_HLIM  2
#define DS1822_SP_LLIM  3
#define DS1822_SP_CFG   4
#define DS1822_SP_RES0  5
#define DS1822_SP_RES1  6
#define DS1822_SP_RES2  7
#define DS1822_SP_CRC   8
// ds1822 rom registers
#define DS1822_ROM_DEVTYPE  0
#define DS1822_ROM_SERIAL1  1
#define DS1822_ROM_SERIAL2  2
#define DS1822_ROM_SERIAL3  3
#define DS1822_ROM_SERIAL4  4
#define DS1822_ROM_SERIAL5  5
#define DS1822_ROM_SERIAL6  6
#define DS1822_ROM_CRC      7
// ds1822 command set
#define DS1822_CMD_READROM           0x33
#define DS1822_CMD_SKIPROM           0xCC
#define DS1822_CMD_CONVERTTEMP       0x44
#define DS1822_CMD_WRITESCRATCHPAD   0x4E
#define DS1822_CMD_READSCRATCHPAD    0xBE
#define DS1822_CMD_COPYSCRATCHPAD    0x48
// note that not all applications need to disable interrupts when
// performing onewire transactions.  but, if unmasked interrupts
// cause onewire timing violations, returned data will be suspect
// or there may be other, hard-to-reproduce problems.
void onewire_disable_interrupts(int disable) {
   if (disable)
     disable_interrupts(GLOBAL);
short int onewire_init_with_error_check() {
   onewire_disable_interrupts(TRUE);
   output_low(ONE_WIRE_PIN);
   delay_us( 500 ); // pull 1-wire low for reset pulse
   output_float(ONE_WIRE_PIN); // float 1-wire high
   delay_us( 5 );   // allow pin to stabilize
   if (!input(ONE_WIRE_PIN)) {
      onewire_disable_interrupts(FALSE);
      return ( FALSE ); // error (1-wire leads shorted)
   delay_us( 80 ); // wait for presence pulse, allowing for device variation
   if (input(ONE_WIRE_PIN)) {
      return ( FALSE ); // error (no 1-wire devices present)
   delay_us( 420 ); // wait-out remaining initialisation window.
   //printf(debug_putc,"<>ok >onewire_init\n\r");
   return ( TRUE ); // device(s) present and initialised.
void onewire_init() { // OK if just using a single permanently connected device
void onewire_sendbyte(int data) {
   int count;
   //static int debugS;
   //printf(debug_putc,"0x%x >onewire_sendbyte(%u)\n\r",data,debugS++);
   for (count=0; count<8; ++count) {
      delay_us( 2 ); // pull 1-wire low to initiate write time-slot.
      output_bit(ONE_WIRE_PIN, shift_right(&data,1,0)); // set output bit on 1-wire
      delay_us( 60 ); // wait until end of write slot.
      output_float(ONE_WIRE_PIN); // set 1-wire high again,
      delay_us( 2 ); // for more than 1us minimum.
int onewire_readbyte() {
   int count, data;
   //static int debugR;
      delay_us( 2 ); // pull 1-wire low to initiate read time-slot.
      output_float(ONE_WIRE_PIN); // now let 1-wire float high,
      delay_us( 8 ); // let device state stabilise,
      shift_right(&data,1,input(ONE_WIRE_PIN)); // and load result.
      delay_us( 120 ); // wait until end of read slot.
   //printf(debug_putc,"0x%x >onewire_readbyte(%u)\n\r",data,debugR++);
   return( data );
int onewire_ds1822_read_scratchpad(int field) { /* returns config bitfield */
   int data[9];
   onewire_init();
   onewire_sendbyte(DS1822_CMD_SKIPROM);
   onewire_sendbyte(DS1822_CMD_READSCRATCHPAD);
   data[DS1822_SP_TLSB]=onewire_readbyte();    // 0 Tlsb
   data[DS1822_SP_TMSB]=onewire_readbyte();    // 1 Tmsb
   data[DS1822_SP_HLIM]=onewire_readbyte();    // 2 Thlim
   data[DS1822_SP_LLIM]=onewire_readbyte();    // 3 Tllim
   data[DS1822_SP_CFG]=onewire_readbyte();     // 4 Config
   data[DS1822_SP_RES0]=onewire_readbyte();    // 5 RES0
   data[DS1822_SP_RES1]=onewire_readbyte();    // 6 RES1
   data[DS1822_SP_RES2]=onewire_readbyte();    // 7 RES2
   data[DS1822_SP_CRC]=onewire_readbyte();     // 8 CRC
   if (field > 8) {
      //printf(debug_putc,"ERR! >scratchpad field 0x%x out of range (ds1822)\n\r",field);
      return(0);
   else {
      //printf(debug_putc,"0x%x >scratchpad field 0x%x (ds1822)\n\r",data[field],field);
      return(data[field]);
int onewire_ds1822_read_rom(int field) { /* rtns ROM info, one byte at a time */
   int data[8];
   if (!onewire_init_with_error_check())
     return (0);
   onewire_sendbyte(DS1822_CMD_READROM);
   data[DS1822_ROM_DEVTYPE]=onewire_readbyte();   // 0 family code
   data[DS1822_ROM_SERIAL1]=onewire_readbyte();   // 1 serial number LSB
   data[DS1822_ROM_SERIAL2]=onewire_readbyte();   // 2 serial number
   data[DS1822_ROM_SERIAL3]=onewire_readbyte();   // 3 serial number
   data[DS1822_ROM_SERIAL4]=onewire_readbyte();   // 4 serial number
   data[DS1822_ROM_SERIAL5]=onewire_readbyte();   // 5 serial number
   data[DS1822_ROM_SERIAL6]=onewire_readbyte();   // 6 serial number MSB
   data[DS1822_ROM_CRC]=onewire_readbyte();       // 7 CRC
   if (field > 7) {
      //printf(debug_putc,"ERR! >rom field 0x%x out of range (ds1822)\n\r",field);
      return(0);
   else {
      //printf(debug_putc,"0x%x >rom field 0x%x (ds1822)\n\r",data[field],field);
int onewire_crc(int oldcrc, int newbyte) {
   // see http://pdfserv.maxim-ic.com/arpdf/AppNotes/app27.pdf
   int shift_reg, data_bit, sr_lsb, fb_bit, j;
   shift_reg=oldcrc;
   for(j=0; j<8; j++) {   // for each bit
      data_bit = (newbyte >> j) & 0x01;
      sr_lsb = shift_reg & 0x01;
      fb_bit = (data_bit ^ sr_lsb) & 0x01;
      shift_reg = shift_reg >> 1;
      if (fb_bit)
         shift_reg = shift_reg ^ 0x8c;
   return(shift_reg);
int onewire_ds1822_set_temperature_resolution(int resolution) { /* set up for nbit resolution */
   int resolution_cfgfield;
   if ((resolution < 9) || (resolution > 12))
      resolution=9;
   resolution_cfgfield=((resolution-9)<<5);  // see DS1822 datasheet page 7
     return (0);
   onewire_sendbyte(DS1822_CMD_WRITESCRATCHPAD);
   onewire_sendbyte(0b01111101);   // set max TH threshold (125'C)
   onewire_sendbyte(0b11001001);   // set min TL threshold (-55'C)
   onewire_sendbyte(resolution_cfgfield);    // Temp resolution, set to nbit
   onewire_init(); // reset
   onewire_sendbyte(DS1822_CMD_COPYSCRATCHPAD);
   delay_ms(15); // allow time for flash memory write.
   return( (onewire_ds1822_read_scratchpad(DS1822_SP_CFG) & 0b01100000)>>5 );
int onewire_ds1822_read_temp_c_lite() { /* 0 to 125'C byte rtnd, nonparasitic mode */
   int temperatureLSB, temperatureMSB, config, delaymult;
   config=((onewire_ds1822_read_scratchpad(DS1822_SP_CFG) & 0b01100000)>>5);
      // each addn'l resolution bit needs twice the base conversion time!
     return (0);
   onewire_sendbyte(DS1822_CMD_CONVERTTEMP);
   delaymult=(1<<config);
      //printf(debug_putc,"0x%x >delay_mult (ds1822)\n\r",delaymult);
   while (delaymult--)
      delay_ms(100); // allow worst case time for temp. conversion.
   temperatureLSB = onewire_ds1822_read_scratchpad(DS1822_SP_TLSB);
   temperatureMSB = onewire_ds1822_read_scratchpad(DS1822_SP_TMSB);
   if (temperatureMSB & 0b11111000) // if temp is negative rtn 0
      return(0);
   else {                           // else rtn the positive temp
      temperatureLSB=((temperatureLSB & 0b11110000)>>4);
      temperatureMSB=((temperatureMSB & 0b00000111)<<4);
   return(temperatureMSB | temperatureLSB);  // OR msb&lsb
jds-pic
PostPosted: Sat Jun 12, 2004 7:13 am     Reply with quote
someone asked me for example code...
for temperature measurements WITH A SINGLE PERMANENTLY ATTACHED DS1822 onewire device...
in your main() or other calling function:
int temperature;
if (int onewire_init_with_error_check()) {
  // set the number of bits of resolution on the ds1822.
  // note that this affects the conversion time,
  // RTFM and see the called function.
  onewire_ds1822_set_temperature_resolution(9);
  // read the temperature from the ds1822.
  // note that the returned value is in deg C,
  // and the "lite" function returns only positive temps.
  temperature = onewire_ds1822_read_temp_c_lite();
  printf("onewire device not found");
here's a little snippet that shows how to get the 48bit unique serial number from the DS1822...
printf(lcd_putc,"Widget / Ver%04Lx", (int16)FW_VERSION);
printf(lcd_putc,"Ser ");
if (onewire_init_with_error_check()) {
  for (loop=6; loop>=1; loop--)
  printf(lcd_putc,"%x",onewire_ds1822_read_rom(loop));
and then another snippet that shows how to retrieve the burned in CRC and compute same from the ROM data...
crc=0;
  for (loop=0;loop<7;loop++)  // crc check to see if we are reading onewire net correctly
    crc=onewire_crc(crc,onewire_ds1822_read_rom(loop));
  printf(serial_putc,"\r\nchk: 0x%x/",onewire_ds1822_read_rom(DS1822_ROM_DEVTYPE));  // 1st ROM byte = device type
  printf(serial_putc,"0x%x/0x%x\r\n",onewire_ds1822_read_rom(DS1822_ROM_CRC),crc);
glavic
PostPosted: Wed Jul 13, 2005 6:34 am     Reply with quote
function onewire_readbyte()
   int count, data;
   return( data );
Why is there 120us delay in readybyte function ?
The read-time slots is minimum 60us + minimum 1us recovery time between slots, so 80us is enough. I am using 66us read-time slots. You should take samples between 15us and 30us. I am getting sample in 18us.
edited >
int onewire_read_byte ()
   int count, data;
   for (count=0; count < 8; ++count)
      delay_us(2);
      delay_us(18);
      shift_right(&data, 1, input(ONE_WIRE_PIN));
      delay_us(44);
   return(data);
function onewire_ds1822_read_temp_c_lite()
Here you read the scratchpad twice. Why?
edited >
void onewire_ds1822_read_scratchpad(int *data)
   onewire_init();
so now you can call this function once and you will get all the scratchpad registers in array >>
   int temperatureLSB, temperatureMSB, config, delaymult, scratchpad[9];
   onewire_ds1822_read_scratchpad(scratchpad);
   temperatureLSB = scratchpad[0];
   temperatureMSB = scratchpad[1];
jds-pic
Re: dallas onewire primitives library and ds1822 driver code
PostPosted: Wed Jan 11, 2006 2:42 pm     Reply with quote
<...snip...>
      return(0);
for dealing with negative temperatures, see this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=25630
jds-pic
PostPosted: Wed Mar 08, 2006 8:12 am     Reply with quote
A more efficient implementation of the CRC calculation can be found in http://www.ccsinfo.com/forum/viewtopic.php?p=60194
acidice333
PostPosted: Sun Dec 24, 2006 4:25 am     Reply with quote
Now I know this is for just a single, but does anybody have a modified code for multiple?
jds-pic
PostPosted: Sun Dec 24, 2006 9:11 am     Reply with quote
you need to use the "Search ROM" technique to find all of the devices on the onewire net; see for example,
http://www.ccsinfo.com/forum/viewtopic.php?t=21848
http://www.ccsinfo.com/forum/viewtopic.php?t=19255
etc
jds-pic
nuclear__
can't make it work
PostPosted: Fri Dec 16, 2016 4:07 am     Reply with quote
Hi there. Using 16f684 and pin_c2 with internal 8MHz osc, i try to make it work. I don't have lcd on it, it's a very simple circuit. Generally working. I have 3 leds for debugging.
Anyway i can't get temperature reading. I can see that i get no pulses to pin_c2 (with oscilloscope). When i use #use FIXED_IO( C_outputs=PIN_C2) then i do see pulses coming periodically, however it's still not reading anything but 0.
Running this at main once, i can see ledr going low:
  else {
   output_low(ledr);
   delay_ms(2000);
Probably something is wrong with my configuration.
Nothing changes if i remove ds1822.
Any tip?
#include <16F684.h>
#device ADC=8
#FUSES WDT                      //Watch Dog Timer
#FUSES NOPUT                    //No Power Up Timer
#FUSES PROTECT                  //Code protected from reads
#use delay(internal=8000000,restart_wdt)
#use FIXED_IO( C_outputs=PIN_C5,PIN_C4,PIN_C3,PIN_C0 )
#include <ds1822.c>
#define pot   PIN_A2
#define s_season   PIN_A4
#define s_mode     PIN_A5
#define Relay   PIN_C0
#define ledR   PIN_C3
#define ledG   PIN_C4
#define ledB   PIN_C5
nuclear__
fixed
PostPosted: Fri Dec 23, 2016 3:11 pm     Reply with quote
I removed fixed_io line and now works.
