scanan
[S O L V E D] About max1039 multi channel 8bit ADC |
Posted: Wed Dec 21, 2016 9:25 am |
Here is my code driver I wrote down.
I can read from channel 0 but can't get any value from other channels.
Please any help will be appreciated.
#define max1039_addr 0xCA
#define max1039_write_addr 0xCA
#define max1039_read_addr 0xCB
// Configuration byte config bit 1, no scan 11, cs3 cs2 cs1 cs0 single ended 1
#define configbyte 0b11100001
// Setup Byte
// setupbit 1, sel2 sel 1 sel0 0 010 external ref,CLk int 0, UNIpolar 0, RST 1, X
#define setupbyte 0b00100010
unsigned int8 adcval=0;
#include "elf-max1039.h"
BOOLEAN max1039_ready()
int1 ack;
i2c_start(); // If the write command is acknowledged,
ack = i2c_write(max1039_write_addr); // then the device is ready.
i2c_stop();
return !ack;
void max1039_test(void)
do
}while(!max1039_ready());
void max1039_write(char deviceAddress,char val)
i2c_start(); // start transmission to device
i2c_write(deviceAddress); // send device address
i2c_write(val); // send value to write
i2c_stop();
char max1039_read(int8 deviceAddress,char AN_channel)
unsigned int8 configbyte_,adcvalue;
configbyte_=configbyte|(AN_channel<<1);
i2c_start();
i2c_write(configbyte_);
i2c_start();
i2c_write(deviceAddress + 1);
delay_us(10);
adcvalue = i2c_read(0);
i2c_stop();
return adcvalue;
void max1039_init(void)
max1039_write(max1039_write_addr,configbyte);
max1039_write(max1039_write_addr,setupbyte);
and my main()
max1039_test();
for(i=0;i<11;++i)
adcval=max1039_read(max1039_addr,1);
printf("ADC channel-> %u | adc value-> %u\r\n",i,adcval);
What could be the problem?
All my hardware setting are correct.
I already get the channel 0 values and have other i2c devices functioning correctly like eeprom reading correctly, etc. and TCA9535 functioning like a charm.
I just put the code section for the max1039.
cheers _________________ Dr Suleyman CANAN
R&D Electronic Engineer
https://suleymancanan.wordpress.com
Do whatever you do with amateur spirit -
But always feel professional.
Posted: Wed Dec 21, 2016 10:33 am |
It's behaving as if it is in the default scan mode. So returning AN0 as the first value read.
Try sending the setup byte first. Though they say the order does not matter. the RST bit will be 0, at start, which could then reset things.
If you are intending to read multiple channels, why not let it scan, and just read the results from all the channels?. |
Joined: 01 Jul 2010 Posts: 9162 Location: Greensville,Ontario
Posted: Wed Dec 21, 2016 10:36 am |
You need to 'play computer'... cut extra code to display(send to PC or LCD) the variable 'configbyte_'.
That way you can actually SEE what it is.
Actually dumping it in binary is the best way, so you can easily check that the bits are correct.
You could have a hardware problem, grounded ADC input pins, bad cable, etc. but you still need to confirm the software !
Jay |
Posted: Wed Dec 21, 2016 1:18 pm |
You have this in your program:
Quote: | #define configbyte 0b11100001
// Setup Byte
But in the max1039 data sheet, in Table 1 or Table 2, it says the opposite
of what you are doing. It says this:
Quote: |
Bit 7 - Register bit. 1 = Setup Byte , 0 = Configuration Byte.
Notice in your #define statements, your 'configbyte' has bit 7 = 1
and 'setupbyte' has bit 7 = 0. That's not correct.
Also, I don't like the way you write code. In the C language, there is
a convention that #define'd constants should be in upper case.
2nd thing. Adding an underscore to a similar varibale name is very error
prone. These two things you are doing make it harder to see errors by
just glancing at your code. Your goal should be to write code in a style
that minimizes errors. |
scanan
Posted: Thu Dec 22, 2016 7:22 am |
At the moment I solved the problem.
It was from the setup and conf bytes 7th bit.
Many thanks for your help.
The driver is working well for all channels.
Here is the corrected code:
*.h file
#define MAX1039_ADDR 0xCA
#define MAX1039_WRITE_ADDR 0xCA
#define MAX1039_READ_ADDR 0xCB
// Configuration byte configbit 0, no scan 11, cs3 cs2 cs1 cs0, single ended 1
#define CONFIGURATION_BYTE 0b01100001
// Setup Byte
// setupbit 1, sel2 sel 1 sel0 010 (external ref),CLK 0 (internal), UNIpolar 0, RST 1, X
#define SETUP_BYTE 0b10100010
max1039.c
int1 ack;
ack = i2c_write(MAX1039_ADDR); // then the device is ready.
i2c_stop();
return !ack;
do
printf("no connection\r\n");
if(max1039_ready())
printf(" max1039 connect\r\n");
//delay_ms(500);
i2c_stop();
unsigned int8 max1039_read(unsigned int8 deviceAddress,unsigned int8 AN_Channel)
unsigned int8 newConfigbyte,adcValue=0;
newConfigbyte=CONFIGURATION_BYTE|(AN_Channel<<1);
//printf("CONFIGURATION_BYTE: %u \r\n",CONFIGURATION_BYTE);
//printf("newConfigbyte: %u \r\n",newConfigbyte);
i2c_write(newConfigbyte);
i2c_start(); // restart - the bus is now set to _read_
i2c_write(deviceAddress+1); // now turn the bus round
i2c_stop();
return adcValue;
max1039_write(max1039_write_addr,SETUP_BYTE);
max1039_write(max1039_write_addr,CONFIGURATIOn_BYTE);
main.c
unsigned int i;
max1039_init();
max1039_test();
do{
for(i=0;i<11;++i)
adcval=max1039_read(MAX1039_ADDR,i);
printf("ADC channel-> %u | ADC value-> %u\r\n",i,adcval);
delay_ms(3000);
printf("\r\n \r\n \r\n");
}while(1==1);
You may use this driver at your own risk.
Many thanks _________________ Dr Suleyman CANAN
But always feel professional. |
