apakSeO
Joined: 07 Dec 2016 Posts: 60 Location: Northeast USA
Unable to locate 32-bit version of jvm.dll ???? |
Posted: Tue Dec 13, 2016 9:45 am |
Attempting to use the CCS C Compiler / IDE with IDC3 programmer. I hit the PROGRAM button in the IDE. Device Programmer window comes up, and a "Browse for Folder" window comes up with the message "Unable to locate 32-bit version of jvm.dll"
Quite perplexing. I am on a 64-bit system ( Windows 7 ) I thought that the CCS compiler/IDE now supports ICD3 ... I don't know what to do from this point on.
I browsed the rest of this forum for similar problems, but the only answer I found was "Get rid of MPLAB X" |
Joined: 01 Jul 2010 Posts: 9225 Location: Greensville,Ontario
Posted: Tue Dec 13, 2016 10:07 am |
obvious thing wiould be to grab a 32bit version of jbm.dll off the web and shove it into your PC, 'somewhere'.....
though a huge read flag is in your post
'can't find 32 bit version of jvm.dll' AND you're running a 64bit version of Windows....
I have NO idea IF you can run the SW and OS as described.....
maybe ask CCS directly? They've always got back to me with answers.. |
Posted: Tue Dec 13, 2016 10:20 am |
That's the Java Virtual Machine.
The older MPLAB 8.92, installed it for you. MPLAB-X doesn't. CCS support for the ICD3, requires you to have MPLAB installed (it adds the drivers needed for the ICD3). Pull a copy of MPLAB 8.92, install this and add the MPLAB interface module to this, and the ICD3 then works.
You have to remember that the ICD3 is a MicroChip product, so CCS are dependant on you having the MicroChip drivers installed.... |
jlgreer
Posted: Sun Dec 18, 2016 10:17 am |
Thank you for posting this tip. I need to re-install MPLAB |
