Convert 74165 decimal result to Binary
art
PostPosted: Mon Dec 12, 2016 7:19 pm     Reply with quote
I've build a program to get result from 8 input push button using 74165 shift register.
The program works well. However the result is in decimal (0~127, -1 ~ -128).
I would like to get the result in binary number such as 11111111 instead of (-128).
Hope someone can help me to solve this problem
#include <18F4550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
#include <string.h>
#include <input.c>
#include <stdio.h>
#include <stdlib.h>
#include <usb_cdc.h>
#include <74165.c>
      char c;
      int8 data ;
      unsigned char d;
      unsigned char key;
   usb_init_cs();
   while (TRUE)
         usb_task();
            if (usb_cdc_kbhit())
                 c=usb_cdc_getc();
                 if (c=='\n') {putc('\r'); putc('\n');}
                 if (c=='\r') {putc('\r'); putc('\n');}
                 while(true)
                  d = usb_cdc_getc();
                         if(d=='U')   // push W
                                while (key!=32) // push SPACE BAR to stop
                                 if(usb_cdc_kbhit())
                                   {key=usb_cdc_getc();}
                                    read_expanded_inputs(&data);
                                    printf(usb_cdc_putc,"\r%d ", data);
                                   } key=0;
PostPosted: Mon Dec 12, 2016 8:54 pm     Reply with quote
See the display_binary() routine in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=1523
art
PostPosted: Mon Dec 12, 2016 9:27 pm     Reply with quote
Hi PCM,
Thanks for the idea.
I've change my code and it works as I plan
#DEVICE ADC=10
#fuses HSPLL,NOWDT,PROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#include <string.h>
#include <input.c>
#include <stdio.h>
#include <stdlib.h>
#include <74165.c>
      char c;
      int8 data ;
      unsigned char d;
      unsigned char key;
   usb_init_cs();
   while (TRUE)
         usb_task();
                 c=usb_cdc_getc();
                 while(true)
                  d = usb_cdc_getc();
                                 if(usb_cdc_kbhit())
                                    delay_us(5);
                                      if(bit_test(data,0))   // 1
                                        m1=1;
                                        m1=0;
                                      if(bit_test(data,1))  //2
                                        m2=1;
                                        m2=0;
                                      if(bit_test(data,2))  //3
                                        m3=1;
                                        m3=0;
                                      if(bit_test(data,3))  //4
                                        m4=1;
                                        m4=0;
                                      if(bit_test(data,4))   // 5
                                        m5=1;
                                        m5=0;
                                      if(bit_test(data,5))  //6
                                        m6=1;
                                        m6=0;
                                      if(bit_test(data,6))  //7
                                        m7=1;
                                        m7=0;
                                      if(bit_test(data,7))  //8
                                        m8=1;
                                        m8=0;
                                    printf(usb_cdc_putc,"\r%d%d%d%d%d%d%d%d ", m1,m2,m3,m4,m5,m6,m7,m8);
                                   } key=0;
art
PostPosted: Mon Dec 12, 2016 9:29 pm     Reply with quote
Do you have ideas to simplify the code?
PostPosted: Mon Dec 12, 2016 11:03 pm     Reply with quote
Your code uses a programming technique called "unrolling a loop".
You could make it into a for() loop.
