lewiseley
switch statements |
Posted: Sat Dec 20, 2003 7:48 am |
i have been adding to my code and i make use of switch statements quite a lot, anyhow now they have all stopped functioning correctly, when i step through the code it jumps off to some routine that reads a table and then returns back to the wrong section of the switch.
has anyone else noticed this ? am i doing something wrong.
it does the same on pch 3.180 and pch 3.181
most frustrating as i am having to recode with loads of if statements
they did work correctly last week, but i have extended the switch statements quite a lot since then. |
Re: switch statements |
Posted: Sat Dec 20, 2003 10:31 am |
lewiseley wrote: | i have been adding to my code and i make use of switch statements quite a lot, anyhow now they have all stopped functioning correctly, when i step through the code it jumps off to some routine that reads a table and then returns back to the wrong section of the switch.
The 'table read' code, _is_ the switch statement.
CCS, uses two different methods of coding switches. The first is similar to performing simple 'if' tests, while the second does a table 'jump' based on the value. Both do work, but the table jump version, can cause problems if table pointers are modified inside interrupt handlers. The current compilers try to protect against this, when CCS's own table handling code is used (arrays, or other switches), but will develop problems if any assembler code uses this ability, and does not save the registers. The code switches to using the 'table' version, if the number of cases is above a critical value (normally about 5), and there is no 'default' case. You can switch the behaviour between the two code types, by simply adding/removing the dafault case.
Presumably you have not got a default case, and have taken the number of statements above the 'switch' point, while something else in your code, is preventing the table based version (which is more efficient for larger switch statements), from working.
Humberto
Posted: Sun Dec 21, 2003 7:36 am |
Hi Ttelmah,
I'm using the compiler since a while, and didn't know this "tips", it's a CCS info or the result of your own experience reading the generated .lst files?
Best wishes,
Humberto
jventerprises
funny switch behavior |
Posted: Fri Nov 19, 2004 2:38 pm |
i have had the same problem. it was becuase i left the default case out.
switch (data)
case 1:
case 2:
did NOT compile correctly. the code just runs off into outerspace!
switch (data)
case 1:
case 2:
default
does work just fine. just add the default statement and it should be fine.
i can post the assembly of these examples if anybody wants them _________________ Jon |
