Switch from Slave to Master in I2C during execution.
facosta.ie
PostPosted: Tue Nov 29, 2016 12:35 pm     Reply with quote
Hi, I'm trying to change a PIC18F25k80 from slave to master and vice versa during the program execution, is this posible?
My PIC works fine as master and as Slave individualy using the instructions:
#use i2c(SLAVE,ADDRESS=0x16,sda=PIN_C4,scl=PIN_C3,)
Or
#use i2c(MASTER,sda=PIN_C4,scl=PIN_C3)
But I need that the same IC2 works sometimes like master and sometimes like slave.
Thanks in advance.
PostPosted: Tue Nov 29, 2016 2:35 pm     Reply with quote
Setup the two uses with streams.
You will need to behave like in multi master mode, and not use the master, unless the clock line is high.
Use force_hw on the slave setup, and software for the master (you are already doing this, I2C defaults to software mode for the master unless you use force_hw).
Obviously your master should not try to talk to the address used by the slave.
facosta.ie
PostPosted: Tue Nov 29, 2016 5:09 pm     Reply with quote
Slave works ok, but master is not working, I use the Slave Stream in the interrupt and the Master Stream when I want to read another Slave, any suggestion?
P.S when I quit the Slave USE the master works correctly.
jeremiah
PostPosted: Tue Nov 29, 2016 6:00 pm     Reply with quote
perhaps there is a particular register bit that must be set master vs slave? If so, you may have to do that manually.
PostPosted: Wed Nov 30, 2016 1:49 am     Reply with quote
You do understand that you have to switch off the slave peripheral to run the master. They can't both be enabled at the same time:
#use i2c(SLAVE, ADDRESS=0x16, I2C1 STREAM=slaveI2C)
#use i2c(MASTER,sda=PIN_C4,scl=PIN_C3, baud=100000, STREAM=masterI2C, force_sw) //ensure this is using software
//Then your code in the slave interrupt, must use the stream name
//so:
val = I2C_read(slaveI2C); //etc..
I2C_write(slaveI2C, val); //etc..
//Then when you want to use the master:
while (input(PIN_C3==0)
    //do something. The master cannot be enabled something else
    //is driving the bus
    //you really need to use a timer here, and only enable the master
    //if the line stays high for a few mSec
I2C_init(slaveI2C,FALSE); //switch off the slave peripheral
//Now you should be able to drive the software I2C
I2C_start(masterI2C);
i2C_write(masterI2C, val); //etc..
//Then when the transaction is complete
I2C_init(slaveI2C,TRUE); //re-enable the slave
facosta.ie
PostPosted: Wed Nov 30, 2016 10:33 am     Reply with quote
Thanks for your answers, Ttelmah and jeremiah with the I2C_init() instruction was enough to enable and disable one or another, it works fine.
I was testing the clk pin(C3), for enable the master and it stucks, if I don't test this pin, the master enables and disables correctly.
For my application I'll be testing a control pin wich will tell me the moment to act like master or slave, with this pin I will not need check the clk pin right? Only will be one master enabled in the bus.
PostPosted: Wed Nov 30, 2016 11:24 am     Reply with quote
A control pin is much better.
Remember though to not turn it off on whichever device operates it, until the transaction has completed.
You should be able to read C3 though. I suspect the problem here is TRIS. By default in standard I/O mode, reading the pin would change the TRIS. You read the pin in multi-master mode, and to avoid two devices trying to operate the clock at the same time, but when I've done this I've always been in fast_io mode (so controlling the TRIS). Even with this being read, you have the problem without a separate control, if two devices start at the same time. This is why you have to add bus collision detection when using multi-master. So a separate control line is very much better. Smile
facosta.ie
PostPosted: Wed Nov 30, 2016 12:25 pm     Reply with quote
Thank you again for your help Ttelmah, I think that the control line is what I need to sync correctly the devices and avoid collisions.
I'll test the complete system and will tell you the results.
Regards.
jeremiah
PostPosted: Wed Nov 30, 2016 12:35 pm     Reply with quote
Side note: If you want to read a pin in standard IO mode without changing the input/output state, the input_state() function is an additional option. It'll read the pin without changing the TRIS settings. I prefer to use this rather than fast IO or fixed IO.
