AHCCS
Compiler issue: Wrong value in variable |
Posted: Mon Nov 14, 2016 1:57 am |
Facing a strange issue with variable definition. I have two global unsigned int 8 variables (lsbEnc1 and lsbEnc2) both have same values but one of them skips the last bit (lsbEnc2) i.e. if I store 71 it will have a value of 70 (last bit is always zero).
pseudo code
#include <33EP256MU806.h>
#fuses NOWDT, PR_PLL,FRC_DIV_BY_16 // Internal FAST RC oscillator with 16x PLL
#use delay(crystal=12M,clock=120M)
#define StartByte '$' // start byte of each serial frame
#define EndByte1 '\r' // 2nd last byte of each serial frame
#define EndByte2 '\n' // last byte of each return serial frame
//pins for UART
#pin_select U1TX=PIN_E7
#pin_select U1RX=PIN_F3
#define UART_HW UART1
#use rs232(baud=115200,parity=N, ERRORS,UART1,stream=SerialGame)
unsigned int8 lsbEnc1=0; // variable 1
unsigned int8 lsbEnc2=0; // variable 2
void SerialTransmitframe(void);
setup_timer4(TMR_INTERNAL |TMR_DIV_BY_256, 234); //interrupt every 1ms prescalar
enable_interrupts(INT_TIMER4);
SerialTransmitframe();
void SerialTransmitframe()
lsbEnc1=71;
lsbEnc2=71;
fprintf(SerialGame,"%cHM,",StartByte);
fprintf(SerialGame,"%c",lsbEnc1); // prints 71
fprintf(SerialGame,",%c",lsbEnc2); // prints 70 (Wrong value)
putc(EndByte1);
putc(EndByte2);
Output is $HM,GF
Hope my question makes sense. I feel its a compiler issue or I am missing something really stupid _________________ Novice User |
AHCCS
Posted: Mon Nov 14, 2016 2:09 am |
I just checked if I remove the function and place everything in main it works but still not sure why its not working in the function. _________________ Novice User |
AHCCS
Posted: Mon Nov 14, 2016 3:00 am |
Ok just to keep on updating. Seems like after a while again in main as well I face the same issue. The variable doesn't seem to store the correct value.
My guess is its some memory issue or compiler issue. Please any info of this will be very helpful. _________________ Novice User |
Posted: Mon Nov 14, 2016 4:12 am |
What is your actual clock?.
You have conflicting settings. Crystal, and internal RC.
What you are describing, may not be a variable problem at all, but a small timing error in the RS232. It's be the last bit sent that is wrong.
Your pseudo code we can't test, since there are other things needed (interrupt handler for timer4 etc..). |
AHCCS
Posted: Mon Nov 14, 2016 5:17 am |
For reference: I am using the the development board from DSP Analog Development Kit by CCS with the 12 MHz crystal. Below I have a more simplified code.
#fuses NOWDT, PR_PLL, FRC_DIV_BY_16 // Internal FAST RC oscillator with 16x PLL
/********** Definition of serial Modes ***************/
//pins for UART
/** Global Variables **/
unsigned int8 msbEnc1=0;
unsigned int8 msbEnc2=0;
signed int16 countR=0;
signed int16 countL=0;
countL=71; // fixed values for testing
countR=71;
msbEnc1=make8(countL,1);
lsbEnc1=make8(countL,0);
msbEnc2=make8(countR,1);
lsbEnc2=make8(countR,0);
fprintf(SerialGame,"%cHM,",StartByte); //%c,%c,%c,%c,%2d,%2d,%c%c",StartByte,msbEnc1,lsbEnc1,msbEnc2,lsbEnc2,countL,countR,EndByte1,EndByte2);
fprintf(SerialGame,"%u,",msbEnc1);
fprintf(SerialGame,"%u,",lsbEnc1);
fprintf(SerialGame,"%u,",msbEnc2);
fprintf(SerialGame,"%u,",lsbEnc2);
fprintf(SerialGame,"%c%c",EndByte1,EndByte2);
I checked countL has the value of 70 instead of 71. So not sure if its a serial issue. _________________ Novice User |
Posted: Mon Nov 14, 2016 8:42 am |
The comment that you checked the value, implies some form of debugger attached?.
Try the simple expedient of reversing the declaration order of the variables. So:
If the problem moves to countR, then you have a RAM fault in the PIC. |
newguy
Posted: Mon Nov 14, 2016 8:50 am |
Since this is a dsPIC project, an obvious question is how much RAM are you setting aside for the stack? Is it the default? What happens if you increase it? |
Posted: Mon Nov 14, 2016 8:57 am |
With the current compiler, it doesn't overflow as posted (that is why I don't bother to mention this). However the default size was increased some time ago, so if using a older compiler, definitely worth checking.
Generally if there was maths inside the printf for example, this would be very likely.... |
AHCCS
Posted: Mon Nov 14, 2016 11:45 pm |
Ttelmah wrote: | The comment that you checked the value, implies some form of debugger attached?.
This is indeed the case. If I invert the CountL works while the other gives the wrong value.
By RAM fault you mean I need to specify more and how should I do so? I dont have a lot of variables assigned so not sure how I run out of RAM so fast?
Lastly I have two boards and I have tried on both and it gives me the same issue. _________________ Novice User |
AHCCS
Posted: Mon Nov 14, 2016 11:49 pm |
newguy wrote: | Since this is a dsPIC project, an obvious question is how much RAM are you setting aside for the stack? Is it the default? What happens if you increase it? |
It is default and I am not sure how much is it. I am using compiler v4.125. Any suggestions how to check it. Although when I compile it I can see that I am using 1% of RAM only.
Best
Asif _________________ Novice User |
AHCCS
newguy
Posted: Tue Nov 15, 2016 7:22 am |
Look for the #BUILD stack line and increase the amount specified in that line. |
AHCCS
Posted: Tue Nov 15, 2016 10:03 pm |
newguy wrote: |
Increased the stack but hardly changed anything.
Code: | #include <33EP256MU806.h>
//#build(stack=0x1E00:0x1FFF)
#build(stack=0x300)
#define EndByte2 '\n' // last byte of each return serial frame |
Posted: Wed Nov 16, 2016 1:46 am |
The example code, didn't hit the stack limit, so I didn't expect this to help, however will become necessary as the code grows. I have to repeat my belief that this is a RAM fault. By this I mean _a faulty chip_. It does happen. Unless you have tried on at least two chips (and preferably from different batches), I have to say that this really is the most likely reason.
It might be being cause by your hardware though. How confident are you that the chip really is receiving a noise free, stable supply?. Does your circuit have the recommended decoupling close to the chip?. Does it behave the same without the debugger?. Are you sure there is nothing in the circuit that could result in unexpected voltages to pins?.
You can always prove that you don't have a stack error, by simply enabling INT_STACKERR, and having a handler for this. If the code arrives here, you have a stack error. Otherwise, this is not the problem. |
AHCCS
Posted: Wed Nov 16, 2016 4:05 am |
Ttelmah wrote: | The example code, didn't hit the stack limit, so I didn't expect this to help, however will become necessary as the code grows. I have to repeat my belief that this is a RAM fault. By this I mean _a faulty chip_. It does happen. Unless you have tried on at least two chips (and preferably from different batches), I have to say that this really is the most likely reason.
I will check for the stack now. But for RAM issue I am using the embedded platform provided by CCS http://www.ccsinfo.com/product_info.php?products_id=dsPIC-analog-kit
And i have two of them both behave in a similar manner. So is the probability both are wrong?
Finally the only way I debug is by using serial ports somehow i cant debug as well using the software. But I am sure its not serial port issue because I verified it by using conditional statements. _________________ Novice User |
