Please Help me about RS232
dp
PostPosted: Fri Dec 19, 2003 12:38 am     Reply with quote
How i get String from RS232 in interrupt --> #int_RDA. When i write this code it receive one char but i want whole string.
Please example code. I must do it as soon as i can. Please help me......
example: i sent Data from terminal ----> "This is DATA"
but i receive T only one char
Please help me...
#int_RDA
void RDA_isr()
char string1[20],string2;
char Data;
int c ;
get_string(string1,20);
strcpy(string2,string1);
printf("%S",string2);
Kieran
PostPosted: Fri Dec 19, 2003 3:38 am     Reply with quote
Every char in the incomming string will cause an interrupt. You need to store each one in a buffer. See the CCS example Ex_sisr.c
Define the strings globally no locally as in the example.
joe
strings
PostPosted: Fri Dec 19, 2003 10:25 am     Reply with quote
give this a try.... it worked well for me.
char input_string[5] = {0};         // global variable [5] was the width i needed, it [] could be anything
int news=0;                         // i used it to test if if the string i was reading
                                    // was the newest string recieved
#INT_RDA                            // recieve data interupt
isr_rda()
{                                   // when data is detected on the rx pin this
     restart_wdt();                 // function clears the watchdog timer and
     gets(input_string);            // pulls the characters off UNTIL it gets
     news = 1;                      // a carrage return <0x0D>.
     return;                        // it then stores it in a global variable.
// good luck!
