USB 18F4550 not recognized by PC
MiniMe
PostPosted: Fri Nov 04, 2016 4:05 pm     Reply with quote
Hi!
There is a problem in a hobby project from years ago. USB is not working. I am afraid that the configuration is not correct.
What I have done:
- Reduced program to minimum
- Tried several configurations for USB
- Ensured that delay by delay_ms(1000) is ~1 sec according to observations.
Header file:
#include <18F4550.h>
#device adc=10
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
//#FUSES INTRC_IO               //Internal RC Osc, no CLKOUT
#FUSES XTPLL
#FUSES PUT                      //Power Up Timer
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOIESO                   //**Internal External Switch Over mode enabled
#FUSES NOFCMEN                  //**Fail-safe clock monitor enabled
#FUSES NOPBADEN                 //**PORTB pins are configured as analog input channels on RESET
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES MCLR                     //Master Clear pin enabled
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES PLL1                     //Divide By 12(48MHz oscillator input)
#FUSES CPUDIV3                  //System Clock by 4   // 3 = 4   96 / 4 = 24 Mhz
#FUSES USBDIV                   //USB clock source comes from PLL divide by 2
#FUSES VREGEN                   //USB voltage regulator enabled
#FUSES HS
//#FUSES NOICPRT                  //**ICPRT enabled
//#define RTCC_PRELOAD (256 -  39)
#define RTC_SDA  PIN_C1
#define RTC_SCL  PIN_C0
//#use I2C(MULTI_MASTER,sda=RTC_SDA, scl=RTC_SCL)
//s#use delay(clock=24MHz, crystal=4MHz, USB_LOW)
#use delay(clock=48MHz, crystal=4MHz, USB_FULL)
#use rs232(uart1, baud=9600 ,XMIT=PIN_C6, RCV=PIN_C7 )
Program file:
#include "main EC-12M.h"
#OPT 9
//USB glob vars
//#define USB_CON_SENSE_PIN PIN_B2
//#define USB_OPT_FOR_ROM 1
#include <stdlib.h>
#include <usb_cdc.h>
void main(){
   UNSIGNED int32 counter = 0;
   //USB_init
   usb_cdc_init(); // Start cdc
   usb_init(); // Start USB
   //usb_init_cs(); // vb parem varian kui ylemine
   WHILE(TRUE){
      printf(" % Lu / n / r", counter);
      usb_task();
      IF(usb_enumerated()){
         output_low(PIN_D7);
         output_high(PIN_D7);
         printf(usb_cdc_putc, " % Lu", counter);
         //usb_cdc_putc_fast
      counter++;
Schematic
Questions:
-Could it be a hardware problem?
-Could it be a PC problem (tried 2 PCs)
-What are the check i have to make to narrow down the problem.
Tests were conducted on actual soldered PCB and in Proteus ISIS simulation environment.
The spaghetti code which I wrote worked very long time ago. ~4-5 years. Smile. I did not know how to use auto formatter then.
PostPosted: Fri Nov 04, 2016 4:55 pm     Reply with quote
First, I would confirm the PIC is operational by coding a '1Hz LED' program and seeing that work. This will show the hardware is 'probably' OK.
Second, 4-5 years is a LONG time. If this program did work back then and the PIC hardware has never been changed then the only source of problem will be the PC. ANY upgrade in the operating system can and will affect if IT can see the PIC.
If the correct USB driver is installed a program like USBVIEW should see the PIC.
You say you've made changes to the old working program. Hopefully you have a copy of one that DID work, use that as a reference after the 1Hz LED program works.
These are general comments, as I no longer use the '4550' PIC. It was easier/faster/cheaper to use a USB<>TTL module.
Jay
PostPosted: Fri Nov 04, 2016 10:38 pm     Reply with quote
See these examples and explanations by Ttelmah about your problems:
http://www.ccsinfo.com/forum/viewtopic.php?t=51692
http://www.ccsinfo.com/forum/viewtopic.php?t=50558
PostPosted: Sat Nov 05, 2016 4:20 am     Reply with quote
These lines conflict with one another:
For your clock statement as posted, you want CPUDIV1.
Also get rid of HS. You have XTPLL selected as well. For a 4MHz crystal, you just want XTPLL.
Add 'ERRORS' to your RS232 setup. This should always be used on the
hardware UART, unless _you_ are adding your own error code. Can get the chip hung if it is not there....
Then you are printing to the port, when there may be nothing there to receive the data. Being 'enumerated' does not mean the port is 'open'....
So code becomes:
#device adc=10
#FUSES XTPLL
#FUSES BROWNOUT               //brownout reset - should be used
#FUSES CPUDIV1                  //System Clock 48Mhz
#use rs232(uart1, baud=9600 ,XMIT=PIN_C6, RCV=PIN_C7, ERRORS )
#include <stdlib.h>
   //USB requires the global interrupt enabled, unless _you_
   //are polling usb_task at least 1000* per second
   usb_cdc_init(); // setup cdc
   usb_init_cs(); // Start USB when CS
   WHILE(TRUE)
      usb_task();
      if (usb_enumerated())
         //Problem here is you are printing to an enumerated port
         //that may not be open. The enumeration occurs as soon as
         //the device is attached. The port only 'opens' when a program
         //actually attaches to it....
         if (usb_cdc_carrier.dte_present)
            printf(usb_cdc_putc, " % Lu", counter); //send when open
            output_low(PIN_D7);
      counter++;
If you look at the CCS examples, they only print to the port, once something has been received. The code here shows how to print automatically when the port is opened.
