Need help on int32 number storage to external memory
ritchie
PostPosted: Wed Dec 17, 2003 8:24 pm     Reply with quote
Anybody in the forum/community who can provide me any help on how to store an unsigned int32 variable to an external memory using I2C (e.g. FM24C256)?
A sample code snippet would help?
Thanx
fpgeh
PostPosted: Wed Dec 17, 2003 8:49 pm     Reply with quote
Assuming you have the CCS compilier, look in the "drivers" directory for the file "24256.c" and in the "examples" directory for "ex_extee.c".
To break the 32 bit value into bytes you can use the "make8" built-in function.
ritchie
PostPosted: Wed Dec 17, 2003 10:14 pm     Reply with quote
Thank u for the info in using the built-in make8() function of the CCS compiler.
Would it be possible using also the page write method in storing int32 numbers to external memory? Any ideas on how to do this? maybe a sample snippet will help...
Thanx
PostPosted: Thu Dec 18, 2003 1:28 am     Reply with quote
Thanx
I hope this would help......
void write_fram_int32(
   //unsigned int32 uAddress,   // memory address to write data
   unsigned int8 uAddress,
   unsigned int32 uData)      // put your data here
   //unsigned int32 dummy;
   unsigned int8 dummy;
   for (dummy=0; dummy<4; dummy++)
      write_fram_byte(dummy+uAddress,*(&uData+dummy));
unsigned int32 read_fram_int32(
   //unsigned int32 uAddress)   // specify memory address to read data
   unsigned int8 uAddress)
   unsigned int32 uData;
      *(&uData+dummy) = read_fram_byte(dummy+uAddress);
   return(uData);
happy coding >>>>>
