UDP doesn't work
biomed12
UDP doesn't work
PostPosted: Thu Aug 25, 2016 7:54 pm     Reply with quote
Hello everyone,
Very basically I want to communicate my 18f4620 with my PC. The software which is at PC side is a server and the PIC is client.
I started the server and also tested by sending some datas from my android phone. I used two type of code. Here is:
#include <main.h>
enum states{SET_TICK_COUNTER,MONITORING,UDP_PUT_FAIL,TXD_PROCESS};
int8 adcData=0;
states state=SET_TICK_COUNTER;
int32 tickCounter=0;
UDP_SOCKET s1;
void IPAddressInit(void)
   //MAC address of this unit
   MY_MAC_BYTE1=0x00 ;
   MY_MAC_BYTE2=0x4;
   MY_MAC_BYTE3=0xA3;
   MY_MAC_BYTE4=0x00;
   MY_MAC_BYTE5=0x00;
   MY_MAC_BYTE6=0x00;
   //IP address of this unit
   MY_IP_BYTE1=MY_DEFAULT_IP_ADDR_BYTE1;
   MY_IP_BYTE2=MY_DEFAULT_IP_ADDR_BYTE2;
   MY_IP_BYTE3=MY_DEFAULT_IP_ADDR_BYTE3;
   MY_IP_BYTE4=MY_DEFAULT_IP_ADDR_BYTE4;
   //network gateway
   MY_GATE_BYTE1=MY_DEFAULT_GATE_BYTE1;
   MY_GATE_BYTE2=MY_DEFAULT_GATE_BYTE2;
   MY_GATE_BYTE3=MY_DEFAULT_GATE_BYTE3;
   MY_GATE_BYTE4=MY_DEFAULT_GATE_BYTE4;
   //subnet mask
   MY_MASK_BYTE1=MY_DEFAULT_MASK_BYTE1;
   MY_MASK_BYTE2=MY_DEFAULT_MASK_BYTE2;
   MY_MASK_BYTE3=MY_DEFAULT_MASK_BYTE3;
   MY_MASK_BYTE4=MY_DEFAULT_MASK_BYTE4;
void udpTask()
   switch(state)
      case SET_TICK_COUNTER:
         tickCounter = TickGet() + (TICK_SECOND);
         state = MONITORING;
      case MONITORING:
         if((long)(TickGet() - tickCounter) > 0)
         output_high(PIN_B0);
         state=MONITORING;
         }else{
            state=UDP_PUT_FAIL;
            output_low(PIN_B0);
      case UDP_PUT_FAIL:
         if((UDPIsPutReady(s1)>0))
         {  adcData=read_adc();
            state=TXD_PROCESS;
            output_high(PIN_B1);
            {  state=MONITORING;
      case TXD_PROCESS:
            UDPPut(adcData);
            UDPFlush();
            output_low(PIN_B1);
      default:
   setup_adc_ports(ALL_ANALOG);
   set_adc_channel(0);
   disable_interrupts(GLOBAL);
   set_tris_b(0x00);
   output_b(0xff);
   IPAddressInit();
   //TickInit();
   StackInit();
   output_low(PIN_B0);
   UDPInit();
   output_low(PIN_B1);
   BOOL durum;
   do{
   s1=UDPOpen(NULL,"192.168.0.18",1453);
   durum=UDPIsOpened(s1);
   if(durum==FALSE)
      {  output_low(PIN_B2);
         StackTask();
      }else{
         output_high(PIN_B2);
   }while(!durum);
   output_b(0x00);
   output_high(PIN_B7);
      // TCP/IP code
      StackTask();
      StackApplications();
      udpTask();
      UDPClose(s1);//never will be executed
Then I thougt I had a mistake maybe and I wrote very simple code. It didn't also run.
#include <main.h>
int8 adcData=0;
BOOL durum=TRUE;
UDP_SOCKET s1;
int32 tickCounter;
   MY_MAC_BYTE1=MY_DEFAULT_MAC_BYTE1;
   MY_MAC_BYTE2=MY_DEFAULT_MAC_BYTE2;
   MY_MAC_BYTE3=MY_DEFAULT_MAC_BYTE3;
   MY_MAC_BYTE4=MY_DEFAULT_MAC_BYTE4;
   MY_MAC_BYTE5=MY_DEFAULT_MAC_BYTE5;
   MY_MAC_BYTE6=MY_DEFAULT_MAC_BYTE6;
   //network gateway
   //subnet mask
   setup_adc_ports(AN0);
   setup_adc(ADC_CLOCK_INTERNAL|ADC_TAD_MUL_0);
   set_adc_channel(0);
   set_tris_b(0x00);
   output_b(0x00);
   IPAddressInit();
   TickInit();
   StackInit();
   UDPInit();
   do{
   s1=UDPOpenEx("192.168.0.18",2,0,1453);
   //s1=UDPOpen(NULL,"192.168.0.18",1453);
   if(s1==INVALID_UDP_SOCKET)
      {output_high(PIN_B1);durum=FALSE;}
   }while(!durum);
   output_b(0x00);
      // TCP/IP code
      StackTask();
      adcData=255;
            UDPPut(adcData);
            UDPFlush();
      //TODO: User Code
At two situation machine gets an ip and response for any ping. But There were not any data at the server side.
Thanks.
