Int8 to Binary Function Trouble
alyeomans
PostPosted: Sat Jul 02, 2016 1:30 am     Reply with quote
Hi All
I have an issue with the the function which takes an int8 and outputs the binary equivalent:
#include <18F4620.h>
//FUSES
#FUSES NOWDT                      //No Watch Dog Timer
#FUSES INTRC                      //Internal RC Osc, with CLKOUT
#FUSES NOPROTECT                  //Code not protected from reading
#FUSES NOBROWNOUT
#FUSES NOPUT                      //No Power Up Timer
#FUSES NODEBUG                    //No Debug mode for ICD
#FUSES NOLVP                      //No low voltage programming
#FUSES NOWRT                      //Program memory not write protected
#FUSES CCP2B3                     //CCP2 output on RB3 and not RC1
#FUSES MCLR                       //Master Clear pin enabled
#define TX   PIN_C6
#define RX   PIN_C7
#use delay(clock=8000000)
#use RS232 (BAUD = 9600, XMIT = TX, RCV = RX, STREAM = COM_A, ERRORS)
//prints binary from int8 var
void printb(int8 b){
   for (int8 i = 8; i > 0; i--) {
      if(bit_test(b, i))
         printf("1");
         printf("0");
void main(void) {
   while(1){
      for(int8 s = 0; s < 8; s++){
         printb(s);
         printf("\n\r");
} //end main
The expected output should be binary counting to 8 however I get:
00000000
00000001
00000001
00000010
00000010
00000011
00000011
This seems silly - the answer must be staring me in the face!
Al
I type therefore I press buttons
PostPosted: Sat Jul 02, 2016 4:08 am     Reply with quote
Bits are 7 to 0.....
You are trying to start on bit 8, and counting to bit 1.
C has a function to do this already. Look at itoa.
alyeomans
PostPosted: Sat Jul 02, 2016 5:34 am     Reply with quote
Thanks again, Ttelmah. I'll have a look at the itoa function but what you pointed to with the bit index range was part of the problem. It seems that the issue was in the for loop condition: testing for i>=0 in this function caused the issue.
Does not work:
   for (int8 i = 8; i>=0; i--) {
      if(bit_test(b, i))
         printf("1");
         printf("0");
Does work:
   for (int8 i = 8; i>0; i--) {
      if(bit_test(b, i-1))
         printf("1");
         printf("0");
Cheers
Al
PostPosted: Sat Jul 02, 2016 7:32 am     Reply with quote
With an unsigned integer, the index is _always_ going to be >=0. An unsigned can only ever be +ve, so how can it ever be <0?......
Simply use a signed int.
alyeomans
PostPosted: Mon Jul 04, 2016 6:54 am     Reply with quote
Thanks again...but to slide the last word in I was testing for equal or greater than 0 (i>=0) which adheres to the unsigned int rule when it failed.
A
PostPosted: Mon Jul 04, 2016 7:47 am     Reply with quote
The problem is that when you decrement 0, this wraps. It can never go -ve in an unsigned, so can never be <0. Think about it.
alyeomans
PostPosted: Tue Jul 05, 2016 12:38 am     Reply with quote
Oww yes. I see. Red face. Thank you for setting me straight
PostPosted: Tue Jul 05, 2016 3:32 am     Reply with quote
Don't worry.
It's one of those ones that _everyone_ here will have been caught by at some point!.... Very Happy
