sareehy
could anyone convert mikroc esp8266 library to ccs c, please |
Posted: Mon Jun 27, 2016 12:12 pm |
I have an esp8266 library for mikroc pro i got it from mikroe forums.
could anyone help me to convert it to work with ccs c , please ?
esp8266 library
extern sfr sbit RST_ESP8266 ;
extern sfr sbit RST_ESP8266_dir;
// Set of basic AT commands
const char AT[] = "AT"; // startupTest AT startup
const char ATE0[] = "ATE0";//Disable echo
const char AT_RST[] = "AT+RST";//Restart module
const char AT_CWMODE[] = "AT+CWMODE=3";//WIFI mode (station/softAP/station+softAP) now choice station+softAP
const char AT_CIPMUX[] = "AT+CIPMUX=1";//Set multiple connections mode
const char AT_CIFSR[] = "AT+CIFSR";//Get local IP address
const char AT_CWJAP[] = "AT+CWJAP=";// Connect to AP.
const char AT_CWSAP[] = "AT+CWSAP=";//Set parameters under AP mode
const char AT_CIPSEND[] = "AT+CIPSEND=";//Send data
const char AT_CIPSERVER[]="AT+CIPSERVER=1,80";//create server and using port 80.
const char AT_CIPCLOSE[] ="AT+CIPCLOSE=";//disconnection .
extern char ESP_ID ;
extern unsigned char *SSID_STA ;
extern unsigned char *password_STA ;
extern unsigned char *port ;
extern unsigned char *SSID_AP;
extern unsigned char *password_AP ;
extern const char chanel ;
extern const char enc ;
extern unsigned char *IP_address;
extern const char esp8266_rec_max;
extern unsigned char esp8266_received_data[];
// Responses to parse
const char ESP_OK = 1;
const char ESP_Ready_To_Receive_Message = 2;
const char ESP_ERROR = 3;
const char ESP_READY = 4;
const char ESP_FAIL = 5;
const char ESP_SEND_OK = 6;
// State machine control variables
char esp_state = 0;
char esp_response_rcvd = 0;
short esp_responseID = -1, esp_response = -1, esp_rsp;
unsigned char esp_i , esp_DataReady_received=0 , esp8266_len=0,esp8266_id=0 ;
void new_line()
UART_Wr_Ptr(0x0D);
UART_Wr_Ptr(0x0A);
void wait_3sec()
delay_ms(3000);
void wait_1sec()
// Send command or data to the esp8266 Module - (const)
void esp8266_Send(const char *s)
// Send command or data string
while(*s) {
UART_Wr_Ptr(*s++);
// Terminatation by CR+LF
// Send command or data to the esp8266 Module - (RAM)
void esp8266_Send_Ram(char *s1) //
while(*s1) {
UART_Wr_Ptr(*s1++);
//UART_Wr_Ptr(0x0D);
// Get esp8266 response, if there is any
short Get_response()
if (esp_response_rcvd)
return esp_responseID;
else return -1;
// Wait for esp8266 response (infinite loop)
void Wait_response(char rspns)
char test = 1;
while (test)
test = Get_response();
if ((test == rspns) || (test == ESP_ERROR))
test = 0;
test = 1;
// Send Status data
void Send_ESP8266_data(const char *ESP8266_Msg_const ,char *ESP8266_Msg_ram,unsigned int len_esp_data )
esp8266_Send(AT_CIPSEND); // send commands "AT+CIPSEND="
UART_Wr_Ptr(ESP_ID+48);// send ID.
UART_Wr_Ptr(',');
// send lenght data
if(len_esp_data <=9)UART_Wr_Ptr(len_esp_data+48);
else if(len_esp_data >= 10 && len_esp_data <=99 )
UART_Wr_Ptr(len_esp_data/10 +48);
UART_Wr_Ptr(len_esp_data%10 +48);
else if(len_esp_data >=100 && len_esp_data <=999 )
UART_Wr_Ptr(len_esp_data/100 +48);
UART_Wr_Ptr(len_esp_data/10%10 +48);
else if(len_esp_data >=1000 && len_esp_data <=9999 )
UART_Wr_Ptr(len_esp_data/1000 +48);
UART_Wr_Ptr((len_esp_data/100)%10 +48);
UART_Wr_Ptr((len_esp_data/10)%10 +48);
new_line(); //CR+LF .
Wait_response(ESP_OK); // Wait for appropriate ready signal
Delay_ms(20);
esp8266_Send(ESP8266_Msg_const); // Send data content
esp8266_Send_Ram(ESP8266_Msg_ram); // Send data content
Wait_response(ESP_OK); // Wait SEND OK as confirmation that the message was sent
wait_1sec();
esp8266_Send(AT_CIPCLOSE); // Send "AT+CIPCLOSE="
new_line();
void configuration_ESP8266()
RST_ESP8266=0;
RST_ESP8266_dir=0;
wait_1sec();
RST_ESP8266=1;
// Negotiate baud rate
esp8266_Send(AT); // Send "AT" string until ESP8266 sets up its baud rade
new_line();
wait_1sec(); // and gets it correctly
if (Get_response() == ESP_OK) break; // If esp8266 says "OK" on our baud rate we program can continue
esp8266_Send(ATE0); // Disable command echo
new_line();
esp8266_Send(AT_RST); // Send "RST" reset module
new_line();
if (Get_response() == ESP_READY) break; // If esp8266 says "ready" on our baud rate we program can continue
do
esp8266_Send(AT_CWMODE); // set wifi mode 1-station 2- access point 3- station+access point
new_line();
}while(Get_response() != ESP_OK);// If esp8266 says "OK" on our baud rate we program can continue
esp8266_Send(AT_CIPMUX); // Set multiple connections mode
new_line();
do { // connected with your network
//AT+CWJAP="SSID","pasword" <CR><LF>
esp8266_Send(AT_CWJAP);
UART_Wr_Ptr('"');
esp8266_Send_Ram(SSID_STA);
UART_Wr_Ptr('"');
UART_Wr_Ptr(',');
UART_Wr_Ptr('"');
esp8266_Send_Ram(password_STA);
UART_Wr_Ptr('"');
new_line();
wait_3sec();
} while(Get_Response() != ESP_OK);
do { // set parameter for access point
//AT+CWSAP="SSID","pasword" , port,port,mode, <CR><LF>
esp8266_Send(AT_CWSAP);
UART_Wr_Ptr('"');
esp8266_Send_Ram(SSID_AP);
UART_Wr_Ptr('"');
UART_Wr_Ptr(',');
UART_Wr_Ptr('"');
esp8266_Send_Ram(password_AP);
UART_Wr_Ptr('"');
UART_Wr_Ptr(',');
UART_Wr_Ptr(chanel+48);
UART_Wr_Ptr(',');
UART_Wr_Ptr(enc+48);
new_line();
wait_3sec();
do {
//connected with ip addrss and used UDP protocol
esp8266_Send(AT_CIPSERVER);
new_line();
wait_3sec();
// state machine
// Reading the data from UART in the interuppt routine
void esp8266_read_message()
char esp_tmp;
esp_tmp = UART_Rd_Ptr(); // Get received byte
// Process reception through state machine
// words "OK" ,"ready","REEOR","FAIL","+IPD" ,"CLOSED"
switch (esp_state)
case 0: {
esp_response = -1; // Clear response
if (esp_tmp == 'O') // // We have 'O', it could be "OK"
esp_state = 1; // Expecting 'K'
else if (esp_tmp == 'E') // // We have 'E', it could be "ERROR"
esp_state = 10; // Expecting 'R'
else if (esp_tmp == 'r') // // We have 'r', it could be "ready"
esp_state = 20; // Expecting 'e'
else if(esp_tmp == 'F') //// We have 'F', it could be "FAIL"
esp_state = 30; // Expecting 'A'
else if (esp_tmp == '+') // // We have '+', it could be "+IPD"
esp_state = 100; // Expecting 'I'
case 1: {
if (esp_tmp == 'K') // We have 'K', it could be "OK"
esp_response = ESP_OK;// We have "OK" response
esp_state = 2;// Expecting CR+LF
esp_state = 0; // reset operation
case 10: {
if (esp_tmp == 'R') // We have 'R', it could be "ERROR"
esp_state = 11;
esp_state = 0;
case 11: {
esp_state = 12;
esp_state = 0;
case 12: {
if (esp_tmp == 'O') // We have 'O', it could be "ERROR"
esp_state = 13;
esp_state = 0;
case 13: {
esp_response = ESP_ERROR; // ERROR
esp_state = 2;
esp_state = 0;
case 20: {
if (esp_tmp == 'e') // We have 'e', it could be "ready"
esp_state = 21;
esp_state = 0;
case 21: {
if (esp_tmp == 'a')// We have 'a', it could be "ready"
esp_state = 22;
esp_state = 0;
case 22: {
if (esp_tmp == 'd')// We have 'd', it could be "ready"
esp_state = 23;
esp_state = 0;
case 23: {
if (esp_tmp == 'y') // We have 'y', it could be "ready"
esp_response = ESP_READY; // READY
esp_state = 2;
esp_state = 0;
case 30: {
if (esp_tmp == 'A') // // We have 'A', it could be "FAIL"
esp_state = 31;
esp_state = 0;
case 31: {
if (esp_tmp == 'I')
esp_state = 32;
esp_state = 0;
case 32: {
if (esp_tmp == 'L') // We have 'L', it could be "FAIL"
esp_response = ESP_FAIL; // FAIL
esp_state = 2;
esp_state = 0;
case 100 : { // We have 'I', it could be "+IPD"
if(esp_tmp == 'I')esp_state = 101;
else esp_state = 0;
case 101 : { // We have 'P', it could be "+IPD"
if(esp_tmp == 'P')esp_state = 102;
else esp_state = 0;
case 102 : { // We have 'D', it could be "+IPD"
if(esp_tmp == 'D')esp_state = 103;
else esp_state = 0;
case 103 : { // wait to read id the first
if(esp_tmp == ',' )
esp_state=104;
else esp_state=0;
case 104 : { // read id .
if(esp_tmp>='0' && esp_tmp<='5')
esp8266_id=esp_tmp-'0';
esp_state=105;
else esp_state=0;
case 105 : {
if(esp_tmp !=':' )
esp_state=105;
esp_i=0;
esp8266_received_data[0]=0; // reset esp8266_received_data for store new data
esp_DataReady_received=0; // reset flag for compelete received data
esp_state=106;
case 106 : {
if(esp_tmp !='H' ) // wait until read 'H' from word "HTTP"
esp_i++;
if(esp_i>esp8266_rec_max)
esp_i=esp8266_rec_max;
else esp8266_received_data[esp_i-1] = esp_tmp;
{ // compelete received data
esp_DataReady_received=1;
esp8266_received_data[esp_i ]=0;// reset pointer for esp8266_received_data this very importment
esp_state=0;
case 2: {
if (esp_tmp == 13)esp_state = 3;
else esp_state = 0;
case 3: {
if (esp_tmp == 10)
esp_response_rcvd = 1;
esp_responseID = esp_response;
esp_state = 0;
else esp_state = 0;
default: {
esp_state = 0;
example on using esp8266 as server using the library
#include "Library_ESP8266_2.h"
sbit led_connected at LATE0_bit;
sbit led_connected_dir at TRISE0_bit;
// Lcd module connections
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
sbit LCD_RS at LATB4_bit;
sbit LCD_EN at LATB5_bit;
sbit LCD_D4 at LATB0_bit;
sbit LCD_D5 at LATB1_bit;
sbit LCD_D6 at LATB2_bit;
sbit LCD_D7 at LATB3_bit;
// End Lcd module connections
//************** ESP8266 parameter*********//
sbit RST_ESP8266 at LATC0_bit;
sbit RST_ESP8266_dir at TRISC0_bit;
// Change following information to match your network settings
unsigned char *SSID_STA = "your name network";
unsigned char *password_STA = "your password network";
unsigned char *port = "1234";
unsigned char *SSID_AP = "ESP8266";
unsigned char *password_AP = "ESP12345";
unsigned char *IP_address="192.168.1.11";// choice IP acording IP for your router
// if you change this ip please change ip in array indexPage1[] mean this "url=http://192.168.1.11\">\ "
const char chanel = 6;
const char enc = 4;
char ESP_id =0;
const char esp8266_rec_max=16;// this array store GET /?+data then 6 for GET /? and 10 for max.data //
unsigned char esp8266_received_data[esp8266_rec_max+1];
// default html page
const char indexPage1[] =
"HTTP/1.1 200 OK\nContent-type: text/html\n\n <meta http-equiv=\"refresh\" content=\"10;url=http://192.168.1.11\">\
<html>\
<head>\
<title>Sheimy Micro Systems</title>\
</head>\
<body bgcolor=\"#CCFF00\">\
<h2 align=\"center\"><font size=\"6\" color=\"#0066FF\">Sheimy Micro Systems Min-Webserver Using PIC18F45k22</font></h2>\
<form action=\"\" method=\"get\" name=\"sheimy\"> \
<table width=\"200\" border=\"2\" align=\"center\" cellpadding=\"2\" cellspacing=\"3\">\
<tr >\
<td colspan=3 bgcolor=#000000><marquee behavior=alternate direction=left scrollamount=5><font color=#00FF33>Sheimy Home Automation Controller Based Ethernet</font></marquee></td>\
</tr>\
<tr>\
<td width=\"200\">Device 1</td>\
char indexPage2[]=
"<td bgcolor=#CCFF00><center><input name=\"dev1\" width=\"200\" type=\"submit\" value=\"d1on\"/></center></td>\
<td bgcolor=#FF0000><center><input name=\"dev1\" width=\"200\" type=\"submit\" value=\"d1off\"/></center></td>\
</tr> \<tr> \<td width=\"200\">Device 2</td>\<td bgcolor=#CCFF00><center><input name=\"dev2\" width=\"200\" type=\"submit\" value=\"d2on\"/></center></td>\
<td bgcolor=#FF0000><center><input name=\"dev2\" width=\"200\" type=\"submit\" value=\"d2off\"/></center></td>\</tr>\
<tr><td width=\"200\">Volt </td><td colspan=2> mV</td></tr>\
</table>\
</form> \
<h2 align=\"center\"><a href=\"http://sheimymicro.freehostia.com/\" rel="nofollow" target=\"_new\"><font size=\"6\" color=\"#0066FF\">Sheimy Micro Systems Website</font></a></h2> \
<h2 align=\"center\"><font color=#FF9900>By Eng Ahmed Sheimy</font></h2>\
</body> \
</html>";
//768
// network parameters
long t;
char x,y;
char volt[6];
void ESP8266_UserTCP()
//GET /?dev2=d2off
if(!memcmp(esp8266_received_data+11, "d1on", 4)) // do we have ON command
PORTD.F0 = 1; // set PORTD bit0
if(!memcmp(esp8266_received_data+11, "d1off", 5)) // do we have OFF command
PORTD.F0 = 0; // clear PORTD bit0
if(!memcmp(esp8266_received_data+11, "d2on", 4)) // do we have ON command
PORTD.F1 = 1; // set PORTD bit0
if(!memcmp(esp8266_received_data+11, "d2off", 5)) // do we have OFF command
PORTD.F1 = 0; // clear PORTD bit0
memcpy(indexPage2+495,volt, 4);
if (PORTD.F0)
memcpy(indexPage2+13, "#00FF00", 6); // highlight (red) ON
memcpy(indexPage2+114, "#FF0000", 6); // clear OFF
memcpy(indexPage2+13, "#FF0000", 6); // clear ON
memcpy(indexPage2+114, "#00FF00", 6); // highlight (yellow) OFF
if (PORTD.F1)
memcpy(indexPage2+256, "#00FF00", 6); // highlight (yellow) ON
memcpy(indexPage2+357, "#FF0000", 6); // clear OFF
memcpy(indexPage2+256, "#FF0000", 6); // clear ON
memcpy(indexPage2+357, "#00FF00", 6); //
Send_ESP8266_data(indexPage1,indexPage2,1309); // 1309 = length for indexPage1 + lenght for indexPage2
//==================================main entry===========================================
ANSELA=0;
ANSELB=0;
ANSELC=0;
ANSELD=0;
ANSELE=0;
SLRCON=0;
ANSELA=1; // AN0
trisd.f0=0; trisd.f1=0;
portd.f0=0;portd.f1=0;
TRISA0_bit=1;
Lcd_Init();
lcd_cmd(1);
lcd_cmd(_LCD_CURSOR_OFF);
lcd_out(1,1,"Wait Please..");
led_connected=0;
led_connected_dir=0;
UART1_Init(115200);
Delay_ms(300);
// Setup interrupts
RC1IE_bit = 1; // Enable Rx1 intterupts
PEIE_bit = 1; // Enable peripheral interrupts
GIE_bit = 1; // Enable global interrupts
configuration_esp8266();
led_connected=1;
lcd_out(1,1," CONNECTED ");
lcd_cmd(1);;
{ // endless loop
if(esp_DataReady_received)
lcd_out(1,1,"ID=");
lcd_chr(1,4,esp8266_id+48);
lcd_out(2,1,"DATA:");
for (y=0;y<esp_i-6;y++)lcd_chr(2,y+6,esp8266_received_data[y+6]);
ESP8266_UserTCP();
t=ADC_Read(0);
t=t*3300/1024;
volt[0]=t/1000+48;
volt[1]=t/100%10 +48;
volt[2]=t/10%10 +48;
volt[3]=t%10 +48;
volt[4]=0;
lcd_out(1,6,"VOLT=");
lcd_out(1,11,volt);
delay_ms(250);
// state machine
void interrupt()
if (RCIF_bit == 1)
{ // Do we have uart rx interrupt request?
esp8266_read_message();
//====================================End OF Program======================================
//==================================All Thanks To Allah===================================
Thanks in advance ![Smile](images/smiles/icon_smile.gif) |
asmboy
Posted: Mon Jun 27, 2016 2:02 pm |
here is a hint
- all the silly pointer based UART_ fragmented code can be replaced with
CCS printf() statements that print explicit data.
Have you read the CCS manual and tried to do anything for your self?
Experienced posters here expect that you did SOMETHING to try to help your own cause before throwing yourself on the tender mercy of the forum
to do it all for you. |
Joined: 01 Jul 2010 Posts: 9170 Location: Greensville,Ontario
Posted: Mon Jun 27, 2016 2:26 pm |
gee I was thinking of getting some of them but have yet to see a 'distance' spec...
I'd like something good for 100' ( 30m)....
Jay |
Posted: Mon Jun 27, 2016 2:35 pm |
<https://www.youtube.com/watch?v=KYLN9qH0C84>
<http://hackaday.com/2014/09/26/esp8266-distance-testing/>
Certainly well over 100metres in clear air. |
Posted: Mon Jun 27, 2016 4:04 pm |
Thanks Mr. T.
I find it odd that sellers never post even 'clear air' distance.....
guess I'll have to buy a few and see !
Jay |
sareehy
Posted: Mon Jun 27, 2016 7:53 pm |
asmboy wrote: | here is a hint
Thanks for reply
Could you tell me how can i convert these statements ?
Code: | extern sfr sbit RST_ESP8266 ;
extern sfr sbit RST_ESP8266_dir; |
Regards |
dyeatman
Gabriel
Posted: Mon Jun 27, 2016 9:49 pm |
I have a library for it i made.
Planning on posting soon, "thingspeak ready".
G. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
ezflyr
Posted: Thu Jun 30, 2016 10:30 am |
Proceed with a bit of caution using the referenced code! Here is the first thing I found:
#int_RDA
void RDA_isr(void)
gets(ESP8266Buf);
Kinda stopped looking after that..... ![Shocked](images/smiles/icon_eek.gif) _________________ John
If it's worth doing, it's worth doing in real hardware! |
mutthunaveen
Joined: 08 Apr 2009 Posts: 100 Location: Chennai, India
Posted: Wed Nov 16, 2016 1:43 am |
Hello Gabriel
Gabriel wrote: | I have a library for it i made.
G. |
Have you developed your code? Can i have it? Can you please post your work so i can make use?
Thank you |
leaveme
Posted: Thu Feb 20, 2020 11:32 am |
G. |
Though it is a very old thread, but did you manage to make the library for esp8266?
regards |
colesha
Posted: Wed Mar 24, 2021 1:19 pm |
leaveme wrote: | Gabriel wrote: | I have a library for it i made.
G. |
regards |
Man, I too really need this driver, but I can not find it anywhere, CCS version. We need to know or a recommendation for which wifi module can be used with ccs |
Posted: Wed Mar 24, 2021 2:13 pm |
You could take the driver posted at the top of this thread 5 YEARS ago..and in less than 5 hours ,convert it into CCS C code.
it's really not that hard or complicated.... |
