Commodore 64 ROM emulator using an 18F PIC
RetroBytes
PostPosted: Sun Jun 19, 2016 12:00 pm     Reply with quote
I have a dead ROM chip in my Commodore 64 (checked with working chip), I was hoping to emulate the ROM chip (2364) using a PIC18F66K80. I’m not sure if it’s possible...
CE is connected to RB0
Data bus to Port C
Address bus to Port D & F
I am using an 8 port logic analyser to look at VCC, CE, D0-2 & A0-2, it’s hard to see what is going on. I set the analyser going from power up, the working chip and PIC look a little different, which is obviously why it’s not working.
I’m new to CCS and C so I thought I would post my code here for suggestions and any errors I might have made.
My thoughts are... try to use an interrupt on the CE pin, or maybe some delays... I’m not sure on the spec of the 2364 ROM.
Hopefully I have attached three files…
main.c, main.h and RomArray.h
Any suggestions welcome...
main.c
#include <main.h>
#include <RomArray.h>
unsigned int16 AB16;
unsigned int8 x;
set_tris_c(0xFF);
setup_wdt( WDT_OFF );
setup_oscillator ( OSC_PLL_ON | 2);         // 64MHz
setup_adc_ports( NO_ANALOGS );              // Turn all ADC's off
setup_adc( ADC_OFF );
setup_ccp1( CCP_OFF);
setup_ccp2( CCP_OFF);
setup_ccp3( CCP_OFF);
setup_ccp4( CCP_OFF);
setup_ccp5( CCP_OFF);
setup_psp( 0 );
setup_spi( SPI_DISABLED );
setup_comparator ( NC_NC_NC_NC );
port_b_pullups(0b00000001);
//port_c_pullups(0b11111111);
//port_d_pullups(0b11111111);
//port_f_pullups(0b11111111);
delay_us(100);
        //set_tris_c(0xFF);
        if ( input(PIN_B0) == 0 )  // Chip selected
            set_tris_c(0x00);
            output_high(LED);
            //AB16 = 0;                     // For testing
            AB16 = input_f();               // Address bus high - Port F
            //AB16 = 0x0;
            AB16 <<= 8;
            AB16 += input_d();              // Address bus low - Port D
            //AB16 += 0x0;                  // For testing
            //delay_us(1);
            //set_tris_c(0x00);
            x = (RomArray[AB16]);
            //output_c(RomArray[AB16]);       // Data bus - Port C
            output_c(x);
            //delay_us(1);
            output_low(LED);
        else  // Chip NOT selected
            set_tris_c(0xFF);
            //delay_us(1);
main.h
#include <18F66K80.h>
#use delay(internal=64000000)
#use fast_io(c)
#fuses NOWRT
#define LED     PIN_G1
#define DELAY   1000
RomArray.h (first 46 lines):-
// C64 - Kernel - 8KB - 901227-03
rom unsigned char RomArray[] = {
0x85,0x56,0x20,0x0F,0xBC,0xA5,0x61,0xC9,0x88,0x90,0x3,0x20,0xD4,0xBA,0x20,0xCC,
0xBC,0xA5,0x7,0x18,0x69,0x81,0xF0,0xF3,0x38,0xE9,0x1,0x48,0xA2,0x5,0xB5,0x69,
0xB4,0x61,0x95,0x61,0x94,0x69,0xCA,0x10,0xF5,0xA5,0x56,0x85,0x70,0x20,0x53,0xB8,
0x20,0xB4,0xBF,0xA9,0xC4,0xA0,0xBF,0x20,0x59,0xE0,0xA9,0x0,0x85,0x6F,0x68,0x20,
0xB9,0xBA,0x60,0x85,0x71,0x84,0x72,0x20,0xCA,0xBB,0xA9,0x57,0x20,0x28,0xBA,0x20,
0x5D,0xE0,0xA9,0x57,0xA0,0x0,0x4C,0x28,0xBA,0x85,0x71,0x84,0x72,0x20,0xC7,0xBB,
0xB1,0x71,0x85,0x67,0xA4,0x71,0xC8,0x98,0xD0,0x2,0xE6,0x72,0x85,0x71,0xA4,0x72,
0x20,0x28,0xBA,0xA5,0x71,0xA4,0x72,0x18,0x69,0x5,0x90,0x1,0xC8,0x85,0x71,0x84,
0x72,0x20,0x67,0xB8,0xA9,0x5C,0xA0,0x0,0xC6,0x67,0xD0,0xE4,0x60,0x98,0x35,0x44,
0x7A,0x0,0x68,0x28,0xB1,0x46,0x0,0x20,0x2B,0xBC,0x30,0x37,0xD0,0x20,0x20,0xF3,
0xFF,0x86,0x22,0x84,0x23,0xA0,0x4,0xB1,0x22,0x85,0x62,0xC8,0xB1,0x22,0x85,0x64,
0xA0,0x8,0xB1,0x22,0x85,0x63,0xC8,0xB1,0x22,0x85,0x65,0x4C,0xE3,0xE0,0xA9,0x8B,
0xA0,0x0,0x20,0xA2,0xBB,0xA9,0x8D,0xA0,0xE0,0x20,0x28,0xBA,0xA9,0x92,0xA0,0xE0,
0x20,0x67,0xB8,0xA6,0x65,0xA5,0x62,0x85,0x65,0x86,0x62,0xA6,0x63,0xA5,0x64,0x85,
0x63,0x86,0x64,0xA9,0x0,0x85,0x66,0xA5,0x61,0x85,0x70,0xA9,0x80,0x85,0x61,0x20,
0xD7,0xB8,0xA2,0x8B,0xA0,0x0,0x4C,0xD4,0xBB,0xC9,0xF0,0xD0,0x7,0x84,0x38,0x86,
0x37,0x4C,0x63,0xA6,0xAA,0xD0,0x2,0xA2,0x1E,0x4C,0x37,0xA4,0x20,0xD2,0xFF,0xB0,
0xE8,0x60,0x20,0xCF,0xFF,0xB0,0xE2,0x60,0x20,0xAD,0xE4,0xB0,0xDC,0x60,0x20,0xC6,
0xFF,0xB0,0xD6,0x60,0x20,0xE4,0xFF,0xB0,0xD0,0x60,0x20,0x8A,0xAD,0x20,0xF7,0xB7,
0xA9,0xE1,0x48,0xA9,0x46,0x48,0xAD,0x0F,0x3,0x48,0xAD,0x0C,0x3,0xAE,0x0D,0x3,
0xAC,0x0E,0x3,0x28,0x6C,0x14,0x0,0x8,0x8D,0x0C,0x3,0x8E,0x0D,0x3,0x8C,0x0E,
0x3,0x68,0x8D,0x0F,0x3,0x60,0x20,0xD4,0xE1,0xA6,0x2D,0xA4,0x2E,0xA9,0x2B,0x20,
0xD8,0xFF,0xB0,0x95,0x60,0xA9,0x1,0x2C,0xA9,0x0,0x85,0x0A,0x20,0xD4,0xE1,0xA5,
0x0A,0xA6,0x2B,0xA4,0x2C,0x20,0xD5,0xFF,0xB0,0x57,0xA5,0x0A,0xF0,0x17,0xA2,0x1C,
0x20,0xB7,0xFF,0x29,0x10,0xD0,0x17,0xA5,0x7A,0xC9,0x2,0xF0,0x7,0xA9,0x64,0xA0,
0xA3,0x4C,0x1E,0xAB,0x60,0x20,0xB7,0xFF,0x29,0xBF,0xF0,0x5,0xA2,0x1D,0x4C,0x37,
0xA4,0xA5,0x7B,0xC9,0x2,0xD0,0x0E,0x86,0x2D,0x84,0x2E,0xA9,0x76,0xA0,0xA3,0x20,
0x1E,0xAB,0x4C,0x2A,0xA5,0x20,0x8E,0xA6,0x20,0x33,0xA5,0x4C,0x77,0xA6,0x20,0x19,
0xE2,0x20,0xC0,0xFF,0xB0,0x0B,0x60,0x20,0x19,0xE2,0xA5,0x49,0x20,0xC3,0xFF,0x90,
0xC3,0x4C,0xF9,0xE0,0xA9,0x0,0x20,0xBD,0xFF,0xA2,0x1,0xA0,0x0,0x20,0xBA,0xFF,
0x20,0x6,0xE2,0x20,0x57,0xE2,0x20,0x6,0xE2,0x20,0x0,0xE2,0xA0,0x0,0x86,0x49,
0x20,0xBA,0xFF,0x20,0x6,0xE2,0x20,0x0,0xE2,0x8A,0xA8,0xA6,0x49,0x4C,0xBA,0xFF,
0x20,0x0E,0xE2,0x4C,0x9E,0xB7,0x20,0x79,0x0,0xD0,0x2,0x68,0x68,0x60,0x20,0xFD,
0xAE,0x20,0x79,0x0,0xD0,0xF7,0x4C,0x8,0xAF,0xA9,0x0,0x20,0xBD,0xFF,0x20,0x11,
0xE2,0x20,0x9E,0xB7,0x86,0x49,0x8A,0xA2,0x1,0xA0,0x0,0x20,0xBA,0xFF,0x20,0x6,
0xE2,0x20,0x0,0xE2,0x86,0x4A,0xA0,0x0,0xA5,0x49,0xE0,0x3,0x90,0x1,0x88,0x20,
0xBA,0xFF,0x20,0x6,0xE2,0x20,0x0,0xE2,0x8A,0xA8,0xA6,0x4A,0xA5,0x49,0x20,0xBA,
0xFF,0x20,0x6,0xE2,0x20,0x0E,0xE2,0x20,0x9E,0xAD,0x20,0xA3,0xB6,0xA6,0x22,0xA4,
0x23,0x4C,0xBD,0xFF,0xA9,0xE0,0xA0,0xE2,0x20,0x67,0xB8,0x20,0x0C,0xBC,0xA9,0xE5,
0xA0,0xE2,0xA6,0x6E,0x20,0x7,0xBB,0x20,0x0C,0xBC,0x20,0xCC,0xBC,0xA9,0x0,0x85,
0x6F,0x20,0x53,0xB8,0xA9,0xEA,0xA0,0xE2,0x20,0x50,0xB8,0xA5,0x66,0x48,0x10,0x0D,
0x20,0x49,0xB8,0xA5,0x66,0x30,0x9,0xA5,0x12,0x49,0xFF,0x85,0x12,0x20,0xB4,0xBF,
0xA9,0xEA,0xA0,0xE2,0x20,0x67,0xB8,0x68,0x10,0x3,0x20,0xB4,0xBF,0xA9,0xEF,0xA0,
0xE2,0x4C,0x43,0xE0,0x20,0xCA,0xBB,0xA9,0x0,0x85,0x12,0x20,0x6B,0xE2,0xA2,0x4E,
PostPosted: Sun Jun 19, 2016 1:44 pm     Reply with quote
Probably just speed. Odds are you are taking too long.
However you can speed things up quite a bit:
1) Use fast_io on the ports. This means each I/O operation just involves reading or writing the data register, whereas with standard I/O the TRIS is accessed as well.
2) Use make16:
AB16 = make16(input_f(),input_d());
With fast_io, this will just involve two byte moves. Probably several times faster.
3) You then should wait for the input to go high before exiting the loop. Currently so long as B0 is low, it'll keep looping and outputting the same value.
So:
   set_tris_c(0xFF);
            output_c(RomArray[make16(input_f(),input_d())]);
            //get the byte as fast as possible
            set_tris_c(0):
            //then set the TRIS
            output_high(LED); //Only waste time for this after the data is sent.
            while (input(PIN_B0)==0)
                ; //wait for the de-select
            set_tris_c(0xFF);
            //turn off the TRIS and the LED
            output_low(LED);
