matrixofdynamism
How to use #INT_RDA with PIC18F with 2 EUSARTs inside? |
Posted: Wed Jun 01, 2016 7:52 pm |
I have a PIC18F MCU that has 2 EUSART inside.
I have written this code:
Code: | #include <main.h>
volatile unsigned int16 bcount = 0;
volatile bool brx = FALSE;
#INT_RDA1
void RDA_isr(void)
bcount++;
brx = TRUE;
enable_interrupts(INT_RDA);
setup_uart(9600, PORT1);
putc(XON);
set_tris_b(0);
if (brx==TRUE)
getc();
brx = FALSE;
//TODO: User Code
if (bcount==64)
putc(XOFF);
output_b(bcount);
It is clear that the interrupt is not being launched. I am sending characters from the PC. Testing demonstrates both above statements to be true.
I am using EasyPIC Pro board with PIC18F87K22 and CCS compiler. The second EUSART of the PIC (pins G1 and G2) is connected to the MAX232 in this case.
When I try to use #INT_RDA0 or #INT_RDA1, my program does not compile even though the documentation does say that there are things called #INT_RDA0 and #INT_RDA1. What nonsense is this?
Note that in the main.h, I have written:
#use rs232(baud=9600,parity=N,xmit=PIN_G1,rcv=PIN_G2,bits=8,stream=PORT1)
typedef unsigned int8 bool;
#define XOFF 0x13
#define XON 0x11 |
Finally, I must say that when I use kbhit() in the while loop in main routine, IT WORKS! But not with interrupt! |
Posted: Wed Jun 01, 2016 9:47 pm |
called #INT_RDA0 and #INT_RDA1. What nonsense is this? |
Look at the end of the 18F87K22.h file. It lists all the correct names for
the interrupts. |
Posted: Wed Jun 01, 2016 11:06 pm |
PCM_programmer has given you the first key piece of data.
As a further comment though the names must be the same everywhere you use them. INT_RDA, enables INT_RDA, and the routine to handle this must use #INT_RDA as it's name.
Each interrupt is separate. So INT_RDA enables the interrupt for UART1 _only_. You seem to be thinking that this will enable both UART's it doesn't.
Then to use more than one port at the same time, you need to be using streams. So two #use rs232 declarations, one for the first UART, and one for the second, with different stream names. (Perhaps PORT1, and PORT2). Then in the INT_RDA, you must read from the stream corresponding to this UART (fgetc(UART1)....). Similarly if using kbhit, you again use the stream name so it tests the right port. (kbhit(UART1)). Similarly for sending data, you use fputc, and fprintf. |
matrixofdynamism
Note using UART1 |
Posted: Thu Jun 02, 2016 4:09 am |
I am only using the UART2 since I am forced to do so. UART1 of the PIC is not connected to the MAX232 chip.
Also, it seems rather unfortunate that both the UARTs are to be serviced via #INT_RDA, very strange. I will check the header file and see what it says.
Do I understand correctly that the reason the program does not even compile when I use #INT_RDA0 or #INT_RDA1 is because they are not defined in the header file? |
RF_Developer
Re: Note using UART1 |
Posted: Thu Jun 02, 2016 4:43 am |
matrixofdynamism wrote: | Also, it seems rather unfortunate that both the UARTs are to be serviced via #INT_RDA, very strange. |
No. The first uart, UART1, is serviced by #INT_RDA (no 0, no 1 or anything else - this is for backwards compatiliblty reasons with/when PICs had only one UART). The second, through #INT_RDA2.
Quote: | Do I understand correctly that the reason the program does not even compile when I use #INT_RDA0 or #INT_RDA1 is because they are not defined in the header file? |
No. It would not work even if you defined them in the header file - and please DO NOT edit or add to those headers.
#INT_RDA - receive interrupt for the first UART
#INT_RDA2 - receive interrupt for the second UART
#INT_RDA3 - receive interrupt for the third UART
etc.
The interrupt routine MUST read the character. The interrupt tells the code that a character is available to be read. The ISR will be continually re-entered if it is NOT read. Your ISR doesn't read the character, so would not work even if it was correctly called.
When using more than one UART, or when using one that is NOT the first, as you re doing, it is best to use stream names. The compiler can't read your mind; it doesn't know that when you call getc(), without a stream name, that you want it to read the second UART. Instead it will/may try to get a character, which isn't there, from the first UART. As your code stands, you DO define a stream name for the UART, which is good, but you don't use that in your getc() and putc() calls, which is not so good. |
matrixofdynamism
Posted: Fri Jun 03, 2016 7:12 am |
Quote: | The interrupt routine MUST read the character. |
Really? This means that if I set a flag in the interrupt and use the main subroutine to read the character (similar to using kbhit for polling), the program will not function as expected? |
jeremiah
Posted: Fri Jun 03, 2016 7:48 am |
What happens on most microcontrollers is if you don't read the byte in the ISR, then even if you manually clear the interrupt condition, the hardware will re-assert it, triggering the interrupt to fire again immediately as soon as you leave it...putting you in an infinite loop of ISR calls. |
newguy
Posted: Fri Jun 03, 2016 7:52 am |
matrixofdynamism wrote: | Quote: | The interrupt routine MUST read the character. |
Why bother using interrupts at all? Just poll for received characters in main().
Sort of like saving for years to buy a vehicle, finally being able to afford the one you want, purchasing it, then parking it in the garage so you can continue to ride the bus. ....Why did you bother buying it? |
Posted: Fri Jun 03, 2016 8:15 am |
Have a look at ex_sisr.c
This shows how to use the interrupt to give an interrupt driven software buffer. You then use 'bkbit' to see if a character is waiting.
Key point is that the UART has just under two characters of buffering. One 'buffered' character, and one 'in transit' (being assembled in the receive buffer). If you don't handle a character before these overflow, then a character is lost. Add the interrupt buffer and you can extend buffering by another 4, 8, 16, 32 characters (binary values are slightly better - search here for 'why').
Then if your code can poll for a few mSec, the date gets buffered and is waiting for you when you do reach the poll point.
If you want to poll without buffering, then having the interrupt is a waste of code, and time. |
