String Constructors
scanan
String Constructors
PostPosted: Tue May 17, 2016 6:09 am     Reply with quote
I would like to know how I can replace the String constructor found in arduino programs into CCS C any comments ?
some examples below
void push(String* str, String s) {
  // loop for find space that can be collect the data
  for (int i = 0; i < sizeof(*str); i++) {
    if (str[i].equals("")) { //found space
      str[i] = s; // store in that slot
      break; // stop loop
String pop(String* str) {
  if (str[0].equals("")) { // empty data
    return ""; // return empty string
  // loop for find lastest data
  for (int i = 0; i < sizeof(*str) - 1; i++) {
    if (str[i + 1].equals("")) { // found next slot that is empty space
      String s = str[i]; // get lastest data into s String variable
      str[i] = ""; // clear that slot into empty space
      return s; // return data
Dr Suleyman CANAN
R&D Electronic Engineer
https://suleymancanan.wordpress.com
Do whatever you do with amateur spirit -
But always feel professional.
PostPosted: Tue May 17, 2016 7:29 am     Reply with quote
A string in C (generic, not just CCS), does not have a 'size' when passed to a function. There is _not_ actually a 'string' type in C. A string in C, is just an array of characters. You have to use strlen to find the size of a string, not sizeof. The PIC does not have a RAM stack, so this has to be emulated. CCS has the standard C memory handling functions, so you can even emulate a dynamic stack, or use a fixed size one.
There are standard C libraries to do this type of thing.
So:
<http://www.cprograms.in/Stack/string-stack.html>
Shows push and pop, on a fixed 80byte string stack.
Look at this thread as well:
<http://www.ccsinfo.com/forum/viewtopic.php?t=55157> for why you should really only specify the elements per row in the calls.
