need MGC3030 driver code
Madhu_k_r
PostPosted: Sat Apr 30, 2016 2:24 am     Reply with quote
Hi..
i want to interface mgc3030 driver code does anyone have this ??
thanks in advance
KaalaayaTasmaiNamah:
PostPosted: Sat Apr 30, 2016 5:03 am     Reply with quote
When asking a question about a 'driver', you should post a link to the actual device you are using, either the mfr datasheet if you are making the PCB or the 'module' that you've bought for the device.
Also post compiler version and PIC you've chosen as that will affect the driver as well.
edit. Had a quick look at the datasheet, seems to be an I2C device AND is 3 volts, so choose a PIC that is rated for 3 volts ( xxxLFyyyyy) to make it easy to interface with. Also the 'driver' will of course depend upon your analog sensor.... I'd suggest buyng a complete 'developement' kit unless you're skilled at SMD PCB mfg !
Jay
