3 volt PIC and 5 volt LCD
PostPosted: Wed Apr 13, 2016 5:16 pm     Reply with quote
As most of you are aware there are a LOT of 5 volt LCD modules at great prices. The problem is trying to run them with a 3 volt PIC. Seems every other add-on peripheral these days IS 3 volts (GPS, RFID, etc.)
So if you can spare a PWM output, even at 4KHz I've come up with a solution. Right now I've got an 18F46K22 running on 3V attached to a 4x20 LCD. I'm using the 'flex_LCD_420' driver. The only hardware mod is to add 2 diodes and 2 caps to form a 'Dickson doubler'. The PIC supplies a free running, 50% duty cycle square wave to the doubler which produces a good 5 volts to power the LCD.
I did this to test a new 4x20 LCD driver, that displays 4 characters, each 4 pixels high. Once I clean up the code, I'll post it in the code library.
Jay
ezflyr
PostPosted: Thu Apr 14, 2016 7:04 am     Reply with quote
Hi Jay,
Hmmm, that seems to address the supply to the +5V display, but what about the I/O? Are +5V displays happy with +3.3V I/O signals?
I've got a lot of mixed voltage designs. +12V in is regulated down to +5V and +3.3v with individual regulators. Seems easier and cleaner to me??
It seems rare that you're starting with only +3.3V anyway, almost always something higher, right?
John
If it's worth doing, it's worth doing in real hardware!
PostPosted: Thu Apr 14, 2016 9:45 am     Reply with quote
The PIC's being powered through TTL<>USB which has 3V output. The LCD seems quite happy with 3V on the data+cmd pins. Almost a week 24/7. ZERO missed data!
This all comes about with trying to get some nRF24L01+ to talk to each other for the wife's greenhouse.
I've yet to find economical, SIMPLE RF 2way transceivers (serial<>RF). Zigbee is too powerful (overkill), Bluetooth can't go the distance. RF Digital have them but $$$. sigh....
Jay
gpsmikey
PostPosted: Thu Apr 14, 2016 10:59 am     Reply with quote
I liked the level shifter that Sparkfun has for sale ( https://www.sparkfun.com/products/12009 ) and was planning on using that system with my next little project. (you still need Jay's voltage step up for the supply though).
mikey
mikey
PostPosted: Fri Apr 15, 2016 10:47 am     Reply with quote
A 3v PIC would work with this LCD because it has ~TTL i/o levels (ie., the
lcd pins have 2.2v input, and 2.4v output levels): https://www.crystalfontz.com/products/document/456/CFAH1602AYYHJP.pdf
This one has ~CMOS i/o levels, with an input voltage requirement of 3.5v
and an output voltage of 3.7v. In fact those levels are for a 4.5v Vdd on
the LCD. The actual levels with a 5v Vdd on the LCD would be even
higher. This LCD would not be reliable with a 3.3v PIC.
https://www.crystalfontz.com/products/document/960/CFAH1602LNFHJT_v1.0.pdf
These are both 5v lcds. I am looking at the Vih and Voh parameters in the
Electrical Specifications / DC characteristics section of the lcd data sheets.
PostPosted: Fri Apr 15, 2016 11:09 am     Reply with quote
This is a nifty idea --
i tried it - this morning with a devel board on hand
already set up with an LED illuminated LCD.
as somebody who has a LOT of analog circuitry in my pic work -there is an unsavory aspect of this means of voltage generation.
i was drawing 55ma with a 5.1 ohm series I limiter -series with the led at doubler output -
If you build this circuit - add a small sense resistor
Look at the input current waveform to the doubler to see what i mean
i used .47 ohms I-sense resistor in series with Vdd 3.3v and
a 330uf/10v ( $$ ) tantalum cap , which HELPS but ..........
Gabriel
PostPosted: Fri Apr 15, 2016 1:42 pm     Reply with quote
For low cost, reliable data, "good" range, go for the ESP8266!... and guess what! they are 3.3V... who says you cant transmit small bits of data via WIFI.
as for the Power generation, i posted a "driver" for an LM35 a looong time ago using a charge pump (voltage doubler, or other fancy names) ... same solution as you.
Just dont read data from the LCD!
Its incredibly simple.... its good to know it can drive a whole LCD!
G.
CCS PCM 5.078 & CCS PCH 5.093
PostPosted: Fri Apr 15, 2016 2:27 pm     Reply with quote
Just a 'point of clarification'...
The 3>5 doubler feeds the LCD 'VCC' only
The regular 3 volts powers the backlighting LEDS.
I didn't even look with a scope, just grabbed what was lying on the bench and it worked! I suppose I should properly engineer it, heck i didn't even put a resistor in the 'I'm alive ' flashing green test LED.
To do it 'right' I'll have to get the magnifying glass out, can't read nothing on little parts any more, sigh.......
Jay
