PIC16F648A configuration problem
gjs_rsdi
PostPosted: Tue Mar 29, 2016 7:24 pm     Reply with quote
Hi
My compiler is CCS PCM C Compiler, Version 3.249
I have the configuration set using CCS wizard and my additions as below:
#FUSES WDT
//***************FUSES for 8MHz external clock*********************
#FUSES EC_IO//for external clock
#use delay(clock=8000000,RESTART_WDT)//for external clock
//***************FUSES for 4MHz internal RC oscilator**************
//#FUSES INTRC_IO//for internal oscilator
//#use delay(clock=4000000,RESTART_WDT)//for internal oscilator
#FUSES BROWNOUT,MCLR,NOLVP,PUT
//#FUSES PROTECT//for code protection
#FUSES NOPROTECT//no code protection
#FUSES NOCPD//Data EEPROM NOT Code Protected
//#FUSES CPD//Data EEPROM Code Protected
#use rs232(baud=9600,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8,restart_wdt)//for external clock
//#use rs232(baud=4800,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8,restart_wdt)//for internal oscilator
When opening MPLAB v8.85 > Configure >Configuration Bits...
I am getting some of the bits wrong:
WDTE WDT disabled
BOREN BOD disabled
In C:
   setup_timer_0(RTCC_EXT_L_TO_H);
   setup_wdt(WDT_144MS);
Testing physically the board with 2.2V, everything functioning so BOD really disabled.
Can somebody tell me what I am doing wrong?
Best wishes
Joe
PostPosted: Tue Mar 29, 2016 7:53 pm     Reply with quote
You probably have MPLAB vs. 8.85 set for Debug mode. Using Debug
mode will disable some of the fuses. Change it to Release mode and
re-compile. There is a drop-down box at the top of the MPLAB window to do this.
gjs_rsdi
PostPosted: Tue Mar 29, 2016 8:01 pm     Reply with quote
Thank you very much PCM programmer
It solved the problem, all the fuses are OK now Smile
Best wishes
Joe
