nailuy
| ADC problem |
Posted: Sun Mar 27, 2016 2:08 pm |
Hy,
I try to make reading from pin RB3 and not all result of commands are the same.
Controller is 16F1788.
in main:
| Code: | setup_adc(ADC_CLOCK_DIV_8);
setup_adc_ports(ALL_ANALOG);
SETUP_ADC_REFERENCE (VSS_FVR);
setup_vref(VREF_ON|VREF_ADC_4v096);
output_bit(PIN_B3,0);
input(U1);
in header:
| Code: | #device ADC=16 //10 and 12 are the same for reading in 10 bit ADC and for 12 bit ADC I use 16 (I don't know why?)
#use delay(internal=1MHz)
#define U1 PIN_B3
static unsigned int16 VAL
code testing:
| Code: | set_adc_channel(9);
delay_us(100);
VAL=read_adc();
printf(LCD_SEND_C,"%Lu ",VAL);
set_adc_channel(9);
this line show real value measured in 12bit but,
set_adc_channel(PIN_B3); //not working no error message
set_adc_channel(U1); //not working no error message and have same value as PIN_B3 and value is not true as applied to pin.
I want to use like U1 it help me for debugging in the future.
Can any body help me? |
Posted: Sun Mar 27, 2016 2:27 pm |
The set_adc_channel command accepts an ADC channel number.
It'll actually accept _any_ number, they just won't be right. PIN_B3, is a #define as a number, so will be accepted, it just will be wrong....
The pin you are reading will be floating, so 'of course' the values will change. Driving the pin, sets TRIS to 0, which disconnects the ADC from the pin. This is necessary, since otherwise you could damage the input (driving the pin high, would overdrive the ADC input if it was on the pin....). To drive a pin, then read it, you have to have something like a capacitor on it, then drive it, wait a while, then set the pin to float, select the adc channel and read. You read from the pin, so from that point TRIS is set to 1, and the pin is floating.
Put a pull down resistor on the pin if you want it to read 0. |
nailuy
Posted: Sun Mar 27, 2016 11:44 pm |
Thank you.
What I'm understand is not so simple to read analog input as I like to do it. "U1"
Have you example code?
Best regards. |
Posted: Mon Mar 28, 2016 2:37 am |
You already are.
AN9, is the analog channel connected to pin B3.
That's why it works when you use 'set_adc_channel(9)....
If you want to give this a name, just define it. So something like:
#define ANALOG_ON_A0 (0)
#define ANALOG_ON_A1 (1)
#define ANALOG_ON_A2 (2)
#define ANALOG_ON_A3 (3)
#define ANALOG_ON_A5 (4)
#define ANALOG_ON_B2 (8)
#define ANALOG_ON_B3 (9)
#define ANALOG_ON_B4 (11)
#define ANALOG_ON_B0 (12)
#define ANALOG_ON_B5 (13)
//Then when you want to read from B3:
set_adc_channel(ANALOG_ON_B3);
Normally however, since the mapping is chip specific, CCS leave it to you to connect the voltages to the pins in the order you want, and then just have an array or define(s) of the pin number(s) versus what you are actually connecting to them.
So if you were using this for a voltage from a current sensor:
#define CURRENT_INPUT (9)
//then you can read your current with:
set_adc_channel(CURRENT_INPUT);
nailuy
Posted: Mon Mar 28, 2016 4:41 am |
Thank you.
I will test later new code, now I can't.
Also I don't know if is problem but now is working normal I think.
#device ADC=16 //10 and 12 are the same for reading in 10 bit ADC and for 12 bit ADC I use 16 (I don't know why is working like this?) |
