picker
Keyb.C and 18F452!!! |
Posted: Fri Dec 05, 2003 6:43 am |
Has any one had any problems using the keyb.c and a 18F452. I get it to work, but it reacts very strangly. I press a button and nothing happens, I then press several and then suddenly a character is displayed. Then it works well for two or three characters (Shows the chars correctly on the LCD) and then nothing happens again when I press a key. I then press several keys and again it would display all the keys and the hook again.
I have had the same reaction on a 18F7820 and I though it was a silicon bug, but obviously its something in the software. I have checked the connections to the Pic and all seems fine. Also the mapping to the PIC is the same as in Keyb.c (I changed Keyb.c to suit the keyboard I am using.)
I have commented all the code of the Keyb.c which selects the port and the key mapping and replaced it with the following...
#byte kbd = 0xF83
#define set_tris_kbd(x) set_tris_d(x)
#define COL0 (1 << 2)
#define COL1 (1 << 1)
#define COL2 (1 << 0)
#define ROW0 (1 << 6)
#define ROW1 (1 << 5)
#define ROW2 (1 << 4)
#define ROW3 (1 << 3)
Here follows my code in the main program...
In header file ....
#include <18F452.h>
#device adc=8
#use rs232(baud=9600,parity=n,xmit=PIN_C6,rcv=PIN_C7)
#fuses HS,NOWDT,WDT1,NOLVP
In C file ........
#device PIC18F452
#include "C:\Program Files\Picc\R50_keyboard\r50_key.h"
#include "c:\Program Files\Picc\R50_keyboard\LCD.C"
#include "c:\Program Files\Picc\R50_keyboard\kbd.C"
char k;
void main() {
output_high(PIN_E1);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
kbd_init();
lcd_putc("\fReady...\n");
while (TRUE)
delay_ms(10);
k=kbd_getc();
if(k!=0)
printf(lcd_putc,"\f");
printf(lcd_putc,"Char :%C",k);
Posted: Fri Dec 05, 2003 11:04 am |
The file KBD.C has the following comment:
Quote: | // Make sure the port used has pull-up resistors (or the LCD) on
// the column pins |
I see that you're using Port D for the keypad. Port D doesn't have
built-in optional pull-ups (as Port B does). I suggest that you add
a 10K pullup resistor on COL0, COL1, and COL2. |
picker
Pull-up resistors... |
Posted: Sun Dec 07, 2003 11:57 pm |
I thought I'd add this to the topic....
I did have resistors on the cols, but they were 5k resistors and as a last resort I tried 10k resistors and IT WORKED!!!!!!!!!!!!!!!!! Thanks to PCM Programmer!!!!
I realise if I read the datasheets of the PIC I would have noticed that the 5k resistors would be too low for the PIC to pull the output down to 0.
picker
![Very Happy](images/smiles/icon_biggrin.gif) |
