joseph20480
SOLVED - dsPIC33fj64GS610 - PWM generation |
Posted: Sun Mar 20, 2016 9:08 am |
I'm trying to generate a pwm signal but nothing...
I use for that an Explorer 16 dev. board + dsPIC33fj64gs610.
I give you my code:
setup_timer3(TMR_INTERNAL|TMR_DIV_BY_1|TMR_CONTINUE_IDLE);
setup_capture(1, capture_off);
setup_compare(1,COMPARE_PWM_FAULT|COMPARE_TIMER3);
set_pwm_duty(1,1000); ;
If you see a big mistake, tell me please !
Posted: Sun Mar 20, 2016 10:02 am |
You are not giving the timer a 'time'. Second value for the setup, is the count at which it is to reset. So assuming (say) a 50% duty cycle:
setup_timer3(TMR_INTERNAL|TMR_DIV_BY_1, 2000);
Without this it'll default to 65535, so the actual pulse would be tiny.
I'm ignoring idle at the moment.
Then you have fault enabled. With this, the PWM will go off, unless the fault pin is in the clear state. Is it?. (OCFA). |
joseph20480
Posted: Mon Mar 21, 2016 2:05 am |
sure.....
thanks ! |
