SOLVED: Different serial streams - compiler warning
JackB
PostPosted: Fri Mar 18, 2016 4:52 pm     Reply with quote
I use two streams: DMX and STD.
#use rs232(UART1, BAUD=250000,BITS=9,PARITY=N,STOP=1,ERRORS,stream=DMX, LONG_DATA)
#use rs232(uart2, baud=9600, stream=STD)
When I print to the STD stream, I do this:
fprintf(STD, "Hello there!\r\n");
That works, but I get a compiler warning: "Unable to resolve identifier STD.".
How to I solve this warning?
newguy
PostPosted: Fri Mar 18, 2016 4:59 pm     Reply with quote
What happens if you change STD to STDRD (or anything else, just not STD)?
PostPosted: Fri Mar 18, 2016 5:01 pm     Reply with quote
Always post your PIC and your compiler version.
PostPosted: Sat Mar 19, 2016 3:25 am     Reply with quote
PCM_programmer pointed out a little while ago, in another thread, that the stream identified has to be completely 'unique'. In this case the user had a subroutine that used the same name. Because of this I've tended to standardise now on using 'informative' names, which then reduce the risk of clashes.
So call streams, 'streams'. So : DMX_STREAM, and STD_STREAM. Then use variable names with codes in to say whether they are strings, floats etc..
As projects get larger this massively helps reduce naming problems.
Agree with Newguy's comment here.
JackB
PostPosted: Sat Mar 19, 2016 1:20 pm     Reply with quote
Now I changed it to DMX_STREAM and STD_STREAM, that makes sense.
But the compiler warnings are still there.
Is there a way to avoid those?
PostPosted: Sat Mar 19, 2016 2:00 pm     Reply with quote
Have to ask if you rename them as
DMX_UNIT_STREAM and STANDARD_STREAM
do you still get the warnings?
I recall in the MSBASIC days than equal lengths variables could cause 'problems',especially if part of them were the same or had 'keywords' embedded in them.
Jay
PostPosted: Sat Mar 19, 2016 2:59 pm     Reply with quote
Again, post your PIC and your compiler version.
PostPosted: Sat Mar 19, 2016 3:11 pm     Reply with quote
I'd suspect your #USE lines are not being parsed before your serial code. The sequence in CCS should be:
Processor include
#device statements
#fuse statements
Clock settings
#pin select statements
Then setups for RS232/I2C etc. (#USE).
Only then include other files
Then the rest of the code.
If things are in other files, they must still be read in this order.
What you are describing would happen if you had serial I/O routines being 'included', before the #USE stuff is defined.
The compiler does not use recursion to solve any definition.
JackB
PostPosted: Sat Mar 19, 2016 6:31 pm     Reply with quote
main.c starts with #include "project.h"
project.h:
#ifndef PROJECT_H
#define   PROJECT_H
#include <18F67K90.h>
#include "types.h"
#case
#device ADC=12
#fuses MCLR,HSH,NOPLLEN
#use delay(crystal=20mhz)
#use rs232(UART1, BAUD=250000,BITS=9,PARITY=N,STOP=1,ERRORS,stream=DMX_STREAM, LONG_DATA)
#use rs232(uart2, baud=9600, stream=USB_STREAM)
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3)
enum errors { err_range, err_too_far, err_too_many };
#endif   /* PROJECT_H */
Is this the right order?
ezflyr
PostPosted: Sat Mar 19, 2016 10:22 pm     Reply with quote
Hi All,
I say ignore this joker until he posts his compiler version. It may not even be relevant, but he's been asked TWICE to do it and he's ignored the request both times. If no one responds, maybe that will get his attention? Doubtful, but maybe!
John
If it's worth doing, it's worth doing in real hardware!
JackB
PostPosted: Tue Mar 22, 2016 6:29 am     Reply with quote
Hi John,
my compiler version is CCS PCH C Compiler, Version 5.055. I'm using Linux.
Learning from the other people here, I don't think that changes the PIC18F hardware capabilities, though.
I mentioned the PIC18F67K90 in the code, but maybe that was not obvious enough, I'm sorry.
Hi the others,
Thank you very much for your continued help!
Regards,
Jack (not a joker)
jeremiah
PostPosted: Tue Mar 22, 2016 8:56 am     Reply with quote
JackB,
I just tested out a test program in 5.055 with no problems:
#case
void main(void) {
   fprintf(USB_STREAM,"Hello World\r\n");
   fprintf(DMX_STREAM,"Hello World\r\n");
   while(TRUE){
      if(kbhit(DMX_STREAM)){
         fputc(fgetc(DMX_STREAM),USB_STREAM);
      if(kbhit(USB_STREAM)){
         fputc(fgetc(USB_STREAM),DMX_STREAM);
No warnings or errors generated (I even tried the same code with STD and no errors/warnings). This means something else in your code is causing the error and the compiler parser is probably just generating an error because it is nearby.
You need to take a step back and start with a small compilable program and slowly add in code until the error occurs. That will help you if all else fails.
Also as a note, you have generated a lot of threads recently (not a bad thing), but you need to consider the forum rules. For things like this they ask that you provide a small program that we can copy paste into a blank project and compile so that we can better help you. You haven't been doing this. It is not only a great debugging tool for you to do it this way, but it helps others help you better. Just as a reference, the forum posting rules are found at: http://www.ccsinfo.com/forum/viewtopic.php?t=47549
In this case I generated one for you, but it is still a good idea for you to do in future threads that you may create.
This is not meant to be rude, so please don't take it that way. I just want to make sure you get the help you need. As you can see, even something as leaving out the compiler version can turn off other users from helping.
PostPosted: Tue Mar 22, 2016 2:04 pm     Reply with quote
As a comment, I 'worry' about the way the poster here is encapsulating this setup. Now encapsulation of this sort is used in includes, to prevent things being done multiple times. Standard. However the setups involved here, _must_ always be ahead of anything else. As such this encapsulation is then pointless. This could be causing some problems. It's an approach that should not be used for this stuff.
May be part of the problem.
JackB
PostPosted: Thu Mar 24, 2016 6:14 am     Reply with quote
For the moment, I accept the compiler Version 5.055 on Linux can't do without these warnings, I think I tried everything.
But it works just fine.
Thank you again for your help!
