oscillator pins in 16f676[SOLVED]
Madhu_k_r
PostPosted: Mon Mar 14, 2016 7:07 am     Reply with quote
hi..
how to use oscillator pins as a normal i/o's in pic16f676
i have tried INTRC_IO flag but still not working
i am using ccs5.008 version and crystal 4MHZ
thanks in advance ...
KaalaayaTasmaiNamah:
PostPosted: Mon Mar 14, 2016 7:25 am     Reply with quote
Please post your program. We need to see what you're doing to tell you what is wrong.
Jay
PostPosted: Mon Mar 14, 2016 7:28 am     Reply with quote
post your program including #fuses and you #use delay statement so i can see what all you have going on.
Madhu_k_r
PostPosted: Mon Mar 14, 2016 7:31 am     Reply with quote
this is my main program
#include <CHAIR_CONTROL_ONLY.h>
delay_ms(200);
output_low(pin_a4);
delay_ms(200);
output_high(pin_a4);
#include <16F684.h>
#FUSES NOPROTECT //Code protected from reads
#FUSES INTRC_IO //Internal RC Osc,no CLKOUT
#FUSES NOMCLR
#use delay(crystal=4000000)
PostPosted: Mon Mar 14, 2016 7:36 am     Reply with quote
comments
1) the order of the code is totally wrong ! Please consult either the CCS manual,any of the examples int he examples folder or the code library here
2) your subject says 16F676 yete the processor header is for 16F684A. THAT is troubling... WHICH is it ?
3) chair_control_only.h is not known to me, it COULD be affecting your program.
Jay
Madhu_k_r
PostPosted: Mon Mar 14, 2016 7:42 am     Reply with quote
temtronic wrote:
comments
Jay
i am sorry it's 16f676.h
Madhu_k_r
PostPosted: Mon Mar 14, 2016 7:43 am     Reply with quote
#include <16F676.h>
Madhu_k_r
PostPosted: Mon Mar 14, 2016 7:45 am     Reply with quote
[quote="Madhu_k_r"][quote="temtronic"]comments
thanks for your reply
but what is wrong with the order
i just want to make that pin high and low
i coudn't make it
i have tried it in proteus simulation
Madhu_k_r
PostPosted: Mon Mar 14, 2016 7:46 am     Reply with quote
and chair_control is just a project name
PostPosted: Mon Mar 14, 2016 8:06 am     Reply with quote
read the CCS manual please --
the line above contradicts what your fuses say!!
RTFM and your problem will go away.......
Madhu_k_r
PostPosted: Mon Mar 14, 2016 11:00 pm     Reply with quote
thank you "asmboy" and all
i have changed to #use delay(internal=4000000)
and working now
Madhu_k_r
Re: oscillator pins in 16f676 [SOLVED]
PostPosted: Mon Mar 14, 2016 11:11 pm     Reply with quote
Madhu_k_r wrote:
hi..
