Serial Communication between 2 PIC16F877a
kookee
PostPosted: Thu Feb 11, 2016 10:21 am     Reply with quote
Hi friends,
I am a new in MCU programming and I use CCS C compiler. Friends I want to communicate between two PIC16F877A MCU using serial port with serial interrupt but I can’t do it.
Please help me in this regard. It’s more easy for me if share with Proteus circuit.
When we give cheerfully and accept gratefully, everyone is blessed
ezflyr
PostPosted: Thu Feb 11, 2016 11:36 am     Reply with quote
Please post the code that you can't get to work, and we'll help you get it running. This is easier for us, and is a much better way for you to learn than just giving you a piece of code!
John
If it's worth doing, it's worth doing in real hardware!
PostPosted: Thu Feb 11, 2016 12:04 pm     Reply with quote
Obvious place to start is with the ex_sisr that CCS supplies in the examples folder but HOW you connect to 2 PICs is very important !
You don't specify if you want full duplex, half duplex, single wire, or ??? it is possible to connect both PICs without any logic level translation( no MAX232) but we'd need more information from you.
Jay
Mike Walne
PostPosted: Fri Feb 12, 2016 2:44 am     Reply with quote
Like others have said, we need more info.
See the sticky about Proteus on this forum.
I'd begin by getting each device to talk to a PC, (will need a MAX232 which you can remove later if you don't need it).
Jay suggests using one of the CCS supplied examples as a good starting point.
Mike
kookee
PostPosted: Fri Feb 12, 2016 11:04 am     Reply with quote
Thanks for reply
I connect
TX of PIC#1 to RX of PIC#2
RX of PIC#1 to TX of PIC#2
with 20MHz clock and RS232 setting is
#use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7)
My code for both PICs are under please. and i use CCS C compiler 4.114.
/* USE FOR PIC # 1*/
#include <main.h>
#include "Flex_LCD420.C"
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_rda
void serial_isr() {
   int t;
   buffer[next_in]=getc();
   t=next_in;
   if(next_in==next_out)
     next_in=t;           // Buffer full !!
BYTE bgetc() {
   BYTE c;
   while(!bkbhit) ;
   c=buffer[next_out];
   return(c);
  lcd_init();
//  setup_adc_ports( RA0_RA1_RA3_ANALOG );    // set AN0, AN1 & AN3 as a Analog
//  setup_adc(ADC_CLOCK_INTERNAL);
  lcd_gotoxy(1,1);
  printf(lcd_putc,"ASDF");
  printf("CAN I READ IT");
  while(true)
    output_toggle(LED);
    delay_ms(DELAY);
    printf("H");
/* USE FOR PIC # 2 */
#include <main.h>    //PIC2
BYTE next_in = 0;
BYTE next_out = 0;
#int_rda
void serial_isr()
  int t;
  t=next_in;
  //lcd_gotoxy(3,3);
  //printf(lcd_putc,"RS232 Read %d",buffer);
BYTE bgetc()
   BYTE c;
   while(!bkbhit) ;
   c=buffer[next_out];
   return(c);
  lcd_init();
  lcd_gotoxy(1,1);
  //printf("CAN I READ IT");
  while(true)
    //lcd_gotoxy(2,2);
    //printf(lcd_putc,"RS232 Read");
    output_toggle(LED);
    delay_ms(DELAY);
    lcd_gotoxy(1,1);
    printf(lcd_putc,"1232456"); //%c",bgetc());
Mike Walne
PostPosted: Fri Feb 12, 2016 12:22 pm     Reply with quote
Please use the code button, it preserves the formatting and makes code easier to read.
A simple guide as to what's supposed to happen would help.
Also you're not telling us what you can/cannot see.
Like I said before it's simpler to start by getting each processor to talk/listen to a PC via a MAX232 chip.
That way you get a better feel for what's going on.
You can send known signals to the PIC and see what it does with them, and monitor what's coming back, (assuming it's all in ASCII).
Mike
kookee
PostPosted: Fri Feb 12, 2016 1:17 pm     Reply with quote
Mike
thanks
i test my code in Proteus.
in it PIC 1 send data but PIC 2 not show it on LCD
PostPosted: Fri Feb 12, 2016 1:33 pm     Reply with quote
Proteus is BUSTED !!!
get real hardware, wire it up,test, report back
No one here wants to FIX busted Proteus
Jay
PostPosted: Fri Feb 12, 2016 8:46 pm     Reply with quote
This schematic shows the serial pin connections between the two PICs:
https://electrosome.com/wp-content/uploads/2014/09/PIC-to-PIC-
Tx on the first PIC goes to Rx on the 2nd PIC, etc. The DIP switch on
the first PIC is read by a program and the value is sent by serial to the
2nd PIC. The 2nd PIC displays the DIP switch setting on the LEDs.
There are no MAX232A chips in the circuit, so this schematic is only for
short range - basically, two boards on your workbench.
