USB_CDC enum
Slim PICins
USB_CDC enum
PostPosted: Thu Feb 04, 2016 10:29 am     Reply with quote
Compiler 4.128
PIC18F87J50
This code allows fairly reliable enumerations (USB To UART COM10) upon cable connection, as long as I have the "delay_ms(250)" line in. If I lower the delay or remove this line, I get "Device not Recognized" or "Device won't Start".
Any ideas? Thanks
   InitSystem();
   //setup_adc_ports(NO_ANALOGS);
   setup_timer_3(T3_DISABLED | T3_DIV_BY_1);
   setup_timer_4(T4_DISABLED,0,1);
   // Use usb_init_cs()'connection sense' instead of usb_init()
   usb_init_cs(); //Original
   //usb_cdc_init();//Original
   do
      if(usb_attached())
         usb_task();
         delay_ms(250);
         if(usb_enumerated())
            OUTPUT_HIGH(LED_PIN);
            if((usb_cdc_carrier.dte_present) && (bEnumeratedFlag == FALSE))
               printf(usb_cdc_putc,"Hello, Universal Controller USB!\n\r");
               printf(usb_cdc_putc,"Enter ASCII command or '?'\n\r");
               bEnumeratedFlag = TRUE;
            UsbReceiveTask();
            OUTPUT_LOW(LED_PIN);
            usb_init_cs();
      {  // The cable has been disconnected
         bEnumeratedFlag = FALSE;
         usb_cdc_init(); //clear buffers if disconnected
   }while(TRUE);
PostPosted: Thu Feb 04, 2016 3:30 pm     Reply with quote
The problem is that you keep calling init_cs.
This only needs to be called once.
What is happening, is it sees the cable as attached, but it is not enumerated (yet). Your code then calls init_cs again, which resets the hardware, and prevents enumeration. So it keeps looping round not enumerating.
By adding the delay you give it time to enumerate....
