Madhu_k_r
PIC18F45K80 internal eeprom problem |
Posted: Tue Jan 12, 2016 6:45 am |
hi...
how to use internal memory in pic18f45k80 in order to write and read
for that do i need to set any fuse ???
Posted: Tue Jan 12, 2016 8:10 am |
No.
You have to make sure that the WRT write protection bits are off. and that code protection is not enabled.
You have to think in terms of pages (64bytes on these chips).
To write a location it must first be erased. A write to the first byte of a page, erases the page. So to change a byte in the middle of a page, you have to read the entire page, change the byte, and then write the whole page back. If you want to use this in a manner like EEPROM, there is a library 'virtual_eeprom.c', which does this.
Beware that the write life of the flash is smaller than the EEPROM. Only 1000 cycles guaranteed. Given that your chip has 1KB EEPROM, why use the flash?. |
Madhu_k_r
Posted: Wed Jan 13, 2016 1:12 am |
Sorry...
it's not internal memory, i meant internal EEPROM, so how to use internal EEPROM and my code looks like:
int8 value=0,value1=0;
int8 address=10;
delay_ms(10);
value1=read_eeprom(address);
if(!input(pin_b0))
delay_ms(250);
value++;
write_eeprom(address,value);
delay_ms(10);
and i am displaying value1 on lcd
and when i try to read the stored value, i.e value1, I am getting 64. _________________ KaalaayaTasmaiNamah: |
Posted: Wed Jan 13, 2016 2:43 am |
First little thing, how large is the EEPROM on this chip?. int8 is not large enough for the address. The EEPROM is 1KB.
The data EEPROM can be read, even if code protection is enabled. WRTD is the only bit that will stop write access. You need NOWRTD. |
Madhu_k_r
Posted: Wed Jan 13, 2016 7:26 am |
Ttelmah wrote: | First little thing, how large is the EEPROM on this chip?. int8 is not large enough for the address. The EEPROM is 1KB.
THANKS FOR YOUR REPLY Ttelmah
i tried with even changing these stuff but still not working
these are the valid fuses what i have used
#include <18F45K80.h>
#FUSES VREGSLEEP
#FUSES INTRC_HP
//#FUSES SOSC_HIGH
//#FUSES NOXINST //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES HSH
#FUSES NOPLLEN
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES BORV18
#FUSES ZPBORM
#FUSES WDT_NOSLEEP
#FUSES WDT1048576
#FUSES CANB
#FUSES MSSPMSK7
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES BBSIZ2K //2K words Boot Block size
#FUSES PROTECT //Code not protected from reading
#FUSES CPD // EE protection
#device adc=12
//#device const=ROM
#use delay(clock=16000000)
and my full code is
#include <main.h>
#include "lcd4bit.c"
int8 b=0,a=0;
int8 i=0;
delay_ms(200);
lcd_display(0x80);
printf(lcd_data,"hi");
delay_ms(200);
b=read_eeprom(50);
delay_ms(10);
lcd_display(0xc0);
printf(lcd_data,"%d",b);
if(!input(pin_B0))
delay_ms(450);
a++;
lcd_display(0xc6);
printf(lcd_data,"%d",a);
write_eeprom(50,a);
delay_ms(10);
Posted: Wed Jan 13, 2016 8:50 am |
Comment.
Writing to the EEPROM every half second, will kill the chip in under 5 days.
Though the EEPROM life is much better than the flash, it is still limited. It is designed for things like configuration parameters that change 'occasionally', not for counts. If you want a count like this, keep it in RAM, and only write it to the EEPROM at the moment the power fails (this is done by using an interrupt on power fail, and having sufficient capacitance to maintain the supply long enough to perform the write).
You should not be getting 64. The EEPROM on the first pass will contain 0xFF (256). The code as posted - removing the LCD stuff and just sending the output to a serial, works.
However do you really want to read protect what is in the EEPROM?. (CPD).
Currently you have lots of protection bits set, but in fact the system is not protected at all.... You have the bootloader _unprotected_ from writes, so anyone wanting to read the chip could just write their own bootloader into it, and then read everything else in memory. If you are trying to protect code using a bootloader, the first thing to protect is the bootloader. Start with the protection all off. Get the code working. Then work out what the bits do, and enable the ones that actually protect what you want.
You also have the watchdog enabled, and are never resetting it.... |
Madhu_k_r
Posted: Sun Jan 17, 2016 11:47 pm |
But if i try to write to internal eprom then I am getting a warning like this
HIGH/LOW voltage detection is not modelled, writing to HLVDCON/LVDCON just stores the data in the register.
So i couldn't encounter the problem so what might be the problem..?
expecting some help _________________ KaalaayaTasmaiNamah: |
Posted: Mon Jan 18, 2016 2:18 am |
Look at the second sticky at the top of the forum.
This is a Proteus problem.
Their DRC for the chip is wrong. |
Madhu_k_r
Posted: Mon Jan 18, 2016 3:44 am |
Ttelmah wrote: | Look at the second sticky at the top of the forum.
thank you Ttelmah
yeah..but i tried with development board still it is not writing to the addressed location any idea about this ??? _________________ KaalaayaTasmaiNamah: |
Posted: Mon Jan 18, 2016 4:30 am |
CPD..... |
Madhu_k_r
Posted: Sat Jan 23, 2016 12:46 am |
i tried with even CPD but still no improvements and same thing is happening even with 18f65k22 _________________ KaalaayaTasmaiNamah: |
Posted: Sat Jan 23, 2016 2:30 am |
Sort out your fuses first, and check the chip is actually running, and at the right speed.
You have several 'dubious' fuses. Two different master oscillators both selected, STVREN turned off (this should always be enabled, unless you are adding stack checking code to your program). NOXINST removed (this is _required_ by the compiler. Two different watchdog divisions both selected. A bootblock enabled, though there is no sign you are using a bootloader.
You have never told us your compiler version that I can see?. The read and write functions work on this chip with the current versions, but did have problems a while ago. So how old is your compiler?. |
Madhu_k_r
Posted: Mon Jan 25, 2016 3:35 am |
Ttelmah wrote: | Sort out your fuses first, and check the chip is actually running, and at the right speed.
am using 4.114 _________________ KaalaayaTasmaiNamah: |
Posted: Mon Jan 25, 2016 4:48 am |
Ooh!. That is old. About December 2010. That was just about the first compiler to feature that chip (I think it was about October they added these chips). Not surprising it doesn't work. You'd have to go DIY on the access code for a compiler this old. I've posted similar routines here before for some chips with problems. |
Madhu_k_r
Posted: Wed Jan 27, 2016 2:51 am |
Thank you Ttelmah ,,
i have changed my compiler version to 5.008 and it's working now thanks for your help _________________ KaalaayaTasmaiNamah: |
