rikotech8
Joined: 10 Dec 2011 Posts: 376 Location: Sofiq,Bulgariq
How to print rom value on 16F628A |
Posted: Sun Jan 24, 2016 10:05 am |
Is there any (direct or indirect) to print the value of ri?
#include <16f628A.h>
#include <stdint.h>
#fuses INTRC_IO, NOWDT, MCLR, NOPROTECT, BROWNOUT
#device *=16
#device PASS_STRINGS=IN_RAM
#use delay(clock=4M)
#USE RS232 (UART1, BAUD=9600, ERRORS)
rom int ri = 8;
setup_oscillator(OSC_4MHZ);
output_toggle(PIN_B5);
printf("Hello, %d\n",ri);
There is no build error, instead code crashes on printf line. I see "Hello" and then processor hangs. _________________ A person who never made a mistake never tried anything new.
Posted: Sun Jan 24, 2016 11:15 am |
Er.
Where is p_ri declared?.
You have two different declarations of 'ri'. You do understand that in C if you have a local variable and a global variable of the same name, the local will be used?.
What you have posted, won't compile. It'll complain immediately that p_ri is undefined. |
rikotech8
Posted: Sun Jan 24, 2016 11:32 am |
Yes, it was a mistyping. I edited my original post. Everything else is same. _________________ A person who never made a mistake never tried anything new. |
Posted: Sun Jan 24, 2016 1:48 pm |
I don't think 'rom' will work with the 16F628A because it doesn't support
read/write of it's own flash memory under program control.
For example, the program below produces no output in MPLAB (vs. 8.92)
simulator with the 16F628A. But with 16F877 and 16F1847, it produces this:
Test program:
Code: | #include <16F628A.h>
#fuses XT,NOWDT,PUT,BROWNOUT,NOLVP
rom int ri = 8;
int8 temp;
printf("%x \r", ri);
temp = ri;
printf("%x \r", temp);
while(TRUE);
Posted: Sun Jan 24, 2016 2:41 pm |
That makes sense.
And obvious comment, if you just want to store values in the ROM and print them, use const. For this the compiler will create a program able to return the required values, which allows this to work even on chips without ROM access. |
rikotech8
Posted: Tue Jan 26, 2016 11:39 am |
Thanks. It answers a lot of my questions. _________________ A person who never made a mistake never tried anything new. |
