uart stop TX when connect wifi
sebalitter
PostPosted: Fri Jan 08, 2016 5:38 am     Reply with quote
i am using a pic18f26j50 that communicates with a WIFI module( RN-171) by UART.
RN171 module cant receive commands in CMD mode.
detail.
PIC18F26J50
CCS 5.015
MPLAB X 3.35
#include <18F26J50.h>   // -> PCH
#device adc=16
#include <string.h>
#include <ctype.h>
#include <stdlib.h>
#include <stdio.h>
#include <pic18_usb.h> //Microchip PIC18Fxx5x Hardware layer for CCS's PIC USB driver
#include <usb_cdc.h> // Descripción de funciones del USB.
#include <usb_desc_cdc.h> // Descriptores del dispositivo USB.
#FUSES NOWDT      //No Watch Dog Timer
//#FUSES NODEBUG    //No Debug mode for ICD
#FUSES NOXINST    //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NOPROTECT  //Code not protected from reading
#FUSES NOFCMEN
#FUSES NOIESO
#FUSES NOCPUDIV
//#FUSES HSPLL      //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES PLL3
#FUSES RTCOSC_INT
#use delay(crystal=12Mhz, clock=48Mhz)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, parity=N ,stop=1, bits=8, stream = RN171)  //// RS232 Configuration with RN171
#use rs232(baud=9600, xmit=PIN_C4, rcv=PIN_C5, parity=N, stop=1,  bits=8, stream = PC)  // RS232 Configuration with PC
#use standard_io(c)
#use fast_io(b)
#define CTS PIN_B2     //wake RN171 to receive data RX  GPIO_12  clear to send
#define RTS PIN_B1     //wake RN171 to receive data RX  GPIO_13  ready to send
#define BUFFER_SIZE 90
char buffer[BUFFER_SIZE];
char palabra[BUFFER_SIZE];
char delimitar[] = "- ||/|| -";
int next_in = 0;
int next_out = 0;
char *tokens[10];
int cmdON = 0;
int segundos=0 , segundos_ant = 0 ;      // A running seconds counter
//int8 int_count = 0;    // Number of interrupts left before a second has elapsed
int cant_tokens=0;
//Functions
void inicbuff(void){ // Inicia a \0 cbuff -------------------
  int i;
  for(i=0;i < BUFFER_SIZE;i++){   // Bucle que pone a 0 todos los
    buffer[i]=0x00;          // caracteres en el buffer
void inicpalabra(void){ // Inicia a \0 cbuff -------------------
  int i;
    palabra[i]="";          // caracteres en palabra
#define bkbhit (next_in!=next_out)
BYTE bgetc()
   BYTE c;
   while(!bkbhit) ;
   c = buffer[next_out];
   next_out=(next_out+1) % BUFFER_SIZE;
   return(c);
int almacenarDatos(char *string, char *delim) //, char *tokens[])
    int count=0;
    char *stringp;
    stringp = string;
    char* token;
    for (token = strtok(stringp, delim); token; token = strtok(NULL, delim))
        tokens[count]= token;
        //printf(usb_cdc_putc,"\n\r%s ", tokens[count]);
        count++;
    //for (i = 1; i < count-1; i++)   //  condicion final   MIENTRAS QUE i sea menor a count
    //    printf(usb_cdc_putc,"\n\r%s ", tokens[i]);
    return count;
void comando(char* comanda)
    char comand[]="$$$";
    char salida[]="exit";
    if( strcmp(palabra,comand) == 0 )
        printf(usb_cdc_putc,"\n\r :--------------Ingrese comando-----------------:\n\r");
        delay_ms(260);
        fprintf(RN171,"$$$");    //entra en modo comando
        //puts("$$$",RN171);                  //  manda la palabra del teclado al modulo
        delay_ms(260);
        cmdON =1;
        //output_low(CTS);
        while( cmdON==1 )
            while(bkbhit)
                putc( bgetc() );
            //printf(usb_cdc_putc,"\n\r Buffer: %s\n\r",buffer);
            inicpalabra();
            //inicbuff();
            get_string_usb(palabra,BUFFER_SIZE);     //obtiene la palabra escrita en el teclado
            if(strcmp(palabra,salida) == 0)
                fprintf(RN171,"exit\r");    //sale del modo comando
                //puts(salida,RN171);                  //  manda la palabra del teclado al modulo
                output_high(CTS);
                cmdON=0;
            }else{
                fprintf(RN171,"%s",palabra);   //  manda la palabra del teclado al modulo
        printf(usb_cdc_putc,"\n\r :--------------Salio del modo comando-----------------:\n\r");
void mostrarDatos( int cant)   //char *dat[],
    int i;
    //printf(usb_cdc_putc,"\n\rcount %d, %s , %s , %s , %s", cant, tokens[0], tokens[1], tokens[2], tokens[3]);
    for (i = 0; i < cant; i++)   //  condicion final   MIENTRAS QUE i sea menor a count
        printf(usb_cdc_putc,"\n\r %d/%d - %s ",i,cant, tokens[i]);
ps:Pre escaler   256
tinst:4/frecuencia del cristal   (4/4000000)    PLL3 -> 12000000/3  = 4000000 Hz
carga:Valor a cargar en el timer 0
temp: tiempo deseado a temporizar   1 seg
 * temp = tinst * 256 * (65536 - carga)
 * 1seg = 4/4000000 * 256 * (65536 - carga)
//interrupts
#int_timer0
void  TIMER0_isr(void)
    segundos++;
    if(segundos > 59)
        segundos=0;
#int_rda
void serial_isr() {
    int t=0;
    buffer[next_in]= getc();
    t=next_in;
    next_in=(next_in+1) % BUFFER_SIZE;
    if(next_in==next_out) {
        next_in=t;           // Buffer full !!
void main() {
   //inputs 1, outputs 0
   SET_TRIS_C( 0b11010111 );   // pone C como entradas y C4 y C6 como salidas (Sensor)
   SET_TRIS_B(0x00 );           //Configuramos el puerto b como salidas
   output_b(0x00);
   usb_cdc_init(); // Configuramos al puerto virtual.
   usb_init();        // Inicializamos el stack USB.
   usb_task();                      //habilita periferico usb e interrupciones
   usb_wait_for_enumeration();      //esperamos hasta que el PicUSB sea configurado por el host
    //usb_init_cs();
   //delay_us(100);
   while(!usb_cdc_connected()) {} // espera a detectar una transmisión de la PC
   inicbuff(); // Borra buffer al inicio
   inicpalabra();
   setup_oscillator (OSC_PLL_ON);   //IMPORTANTIIIISIMO SI NO NO FUNCIONA USB NI USART
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256);
   set_timer0(3906);
   //interrupts
   enable_interrupts(int_rda);
   enable_interrupts(global);
   cmdON=0;
   output_high(CTS);   //ready to send
   printf(usb_cdc_putc,"\n\r :--------------Start-----------------:\n\r");
        while(bkbhit)
            putc( bgetc() );
        delay_us(100);
        usb_task();
        if( !bkbhit )
            //delay_ms(200);
            cant_tokens = almacenarDatos(buffer,delimitar); //,tokens);
            //delay_us(100);
            if (usb_enumerated())   //Returns a 1 if device is configured
                if (usb_cdc_kbhit())
                    comando(palabra);
            //inicbuff(); // Borra buffer al inicio
        if(segundos != segundos_ant && cmdON==0)
            mostrarDatos(cant_tokens);
            segundos_ant=segundos;
PostPosted: Fri Jan 08, 2016 6:25 am     Reply with quote
quick answer..
fputs(palabra,WIFI);
says to me.. take the STRING formatted data at palabra and send it to WIFI..
Odds are that you haven't delimited (ended) the data with a 0.
Others will know for sure but I suspect the PIC is 'looking' for the delimiter (the 0) at the end of the string 'palabra' and will wait until the cows come home for it.
Easy to fix, just load the last cell of the array with a 0.
Jay
sebalitter
PostPosted: Fri Jan 08, 2016 4:36 pm     Reply with quote
thanks for the kick answer.
i try it. still don't work.
largo = strlen(palabra);
palabra[largo]='\0';
                i=0;
                while(largo<BUFFER_SIZE && i<largo){
                    fputc(palabra[i],WIFI);
                    //delay_ms(50);
                    i++;
                fputc('\0',WIFI);
PostPosted: Fri Jan 08, 2016 5:35 pm     Reply with quote
RN-171 is a Microchip product. I'm not sure why you're asking about it
here. You can Google the Microchip forum and find many threads on it:
Google this:
site:microchip.com/forums RN-171 no output
There are hundreds of threads discussing problems with the RN-171.
PostPosted: Sat Jan 09, 2016 7:02 am     Reply with quote
I would configure a 'test serial port' to send the data going to the 'WIFI' device to a PC terminal program. This way you can verify that the data is correct and in the proper format for that WIFI device.
Simply take a spare PIC I/O pin, set for uses rs232(....) ,connect a USB<>TTL module, configure PC term pgm as required.
Most PCs today have 4 or 6 USB ports, so this should be possible.
Do NOT use the current USB setup as your 'test serial port'. You need a separate port for testing.
Jay
PostPosted: Sat Jan 09, 2016 9:37 am     Reply with quote
There are also some little syntax errors, that were pointed out to him in his previous thread. He has fixed some, but not other. So (for instance) fgetc, without a stream name.
Read the manual for each instruction, and make sure your code is using it right.
