Hardware I2C on 16F18313
dezso
PostPosted: Sat Nov 28, 2015 12:21 pm     Reply with quote
Datasheet say its on PIN RA1 SCK and RA2 SDA
Compiler "ver 5.050" gives me this error Error#99 Option invalid Wrong pins for H/W
Tried to swap many pin combination all say the same, ICD disabled
How would I make this work using HW i2c.
Any tip ?
Ty
//#device ICD=TRUE
#FUSES RSTOSC_HFINTRC_PLL
#FUSES NOCLKOUT                 //I/O function on OSC2
//#FUSES CKS
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOLPBOR                  //Low-Power Brownout reset is disabled
#FUSES BORV24                   //Brownout reset at 2.4V
#FUSES PPS1WAY                  //Allows only one reconfiguration of peripheral pins
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOCPD                    //No EE protection
#use delay(internal=32MHz)
#use i2c(Slave,Slow,sda=PIN_A2,scl=PIN_A1,force_hw,address=0x20)
Main code has almost nothing just the #include h and a blank void main()
I'm could be wrong many time's, at least I know what I'm doing Smile
PostPosted: Sat Nov 28, 2015 12:42 pm     Reply with quote
while I don't use that PIC it does have 'peripherial pin selection' so I assume you need to do that before you use the I2C???
Also you've selected as a slave I2C device, so can we assume this PIC will be a slave to another PIC as a master ??
Jay
dezso
PostPosted: Sat Nov 28, 2015 12:48 pm     Reply with quote
Yes it will be a slave.
"peripheral pin selection" yup, how to use it ? I guess than the compiler wont take care of that by itself, should I just figure out how to set up the I2C and than remove the "force_hw"
PostPosted: Sat Nov 28, 2015 2:57 pm     Reply with quote
The normal way with PPS, is to use #pin select to set all the peripheral pins you are using to the peripheral, and then use the hardware peripheral name in the #use (not the pins).
The peripheral pins, and the chip pin names available should be at the start of the include file for the processor.
Currently not got a compiler available, so can't look in the file to check that this is how it should be done for this chip.
PostPosted: Sun Nov 29, 2015 2:10 am     Reply with quote
Can confirm. Got back to a compiler this morning, and it does behave like all the other chips with PPS:
#pin_select SDI1=PIN_A2
#pin_select SCL1IN=PIN_A1
//Beware here. For a _slave_ you need to program the two input pins
//For a master, the output pins SDO1, and SCL1
#use i2c(Slave,I2C1,address=0x20)
//select hardware I2C1, a slave does not have a 'speed'
