Bootloader (loader.c) troubles...
tedlarson
PostPosted: Mon Dec 01, 2003 2:16 pm     Reply with quote
I used the CCS bootloader sample, loader.c to make a simple boot loader for a PIC18F252. It seems to work very well when working with a toy/example program.
I went and tried to retrofit an existing (large) program with it, and immediately ran into trouble.
real_load_program
Seg 7C0A-7FFE, 033E left, need 0340
Seg 0000-0002, 0000 left, need 0340
Seg 0004-0006, 0004 left, need 0340
Seg 0008-00A2, 0000 left, need 0340
load_program
When I remove the "load.c" from my include list, I have 50% of my ROM free on the device, so I suspect that an individual segment is overflowing. I have gone through and used the #segment directive on all my functions, but it still doesn't seem to break things up enough. Does anyone have any suggestions on things I can do to get around the problem?
Thanks,
- Ted
Mark
PostPosted: Mon Dec 01, 2003 3:04 pm     Reply with quote
I hope you meant #separate. Look at the lst file and the functions and see which ones are really large. Take those and break them up into smaller functions.
tedlarson
PostPosted: Mon Dec 01, 2003 5:00 pm     Reply with quote
Whew!
After lots of looking at the list file, and breaking things up more....still no luck. Then, I started commenting things out until it would compile.
I isolated the problem to the following.
I have two global arrays in the program:
long vlist[25];
int vstat[25];
I notice that when I reduce the array size to something small....I suddenly can compile. I have a feeling that the compiler is trying to shove these into the same segment as the loader and having trouble. How can I move these out to somewhere else in memory, so they won't get in the way?
Thanks,
-Ted
Mark
PostPosted: Mon Dec 01, 2003 6:57 pm     Reply with quote
Those are ram based and the problem you are having is rom shortage. sometimes moving variables around reduces the code size due to the bank switching instructions.
tedlarson
PostPosted: Tue Dec 02, 2003 11:59 am     Reply with quote
That is what I thought too. Although, I have noticed that I can reduce the total code size...so that the compiler will report to me that only 10% of the rom is being used. Then, I add-in the loader.c code, and I suddenly run out.
I have noticed that reducing the number of global variables I have affects it's ability to compile. Other than bank switching, is there something else about global variables that would cause an out-of-rom situation?
The behavior the compiler is giving me just doesn't make sense.
- Ted
tedlarson
PostPosted: Tue Dec 09, 2003 8:36 pm     Reply with quote
Ok....CCS tech support replied with an answer to the problem. I thought I would post my results, so the next guy who has the same trouble will know what to do.
LOADER_SIZE is incorrect for the PCH compiler.
It is too small. Currently I am using 0x41F
and it seems to all work now....although that value was
obtained by trial and error.
The next problem I am having is, when using it on a PIC16F876, it sucks up 50% of the available ram. Sooo...I am stuck again, with a different problem now.
Anyone out there know the answer to this one?
Thanks,
- Ted
Mark
PostPosted: Wed Dec 10, 2003 7:18 am     Reply with quote
Do you have
#device *=16
in your code?
