Error message Contact CCS
CMatic
PostPosted: Sat Oct 24, 2015 12:00 am     Reply with quote
I have CCS C CCS PCM C Compiler, Version 5.026.
The file is now generating error as shown below:
*** Error 44 "Thermo_Menu_v9.c" Line 677(1,1): Internal Error - Contact CCS LABEL SCR=2699
Does any one knows what does this means.
PostPosted: Sat Oct 24, 2015 1:19 am     Reply with quote
It's telling you what to do. Contact CCS. This is _not_ 'CCS'. This is a user forum.
PostPosted: Sat Oct 24, 2015 5:35 am     Reply with quote
There is a simple way (other than contacting CCS) to figure what it is.
Go back 1 version of your program and look at the new code of the current non working version. It will be obvious what code you just added that made the compiler stop.
Whatever you did in the new version is very likely what gave the error.
While having 20-30-59 versions of one program may seem excessive and ridiculous, since it doesn't take up any 'real' amount of HD space, it DOES make troubleshooting code a LOT easier!
Yes, once you have a final version, you can delete all but say the last 3 versions or maybe 4, depending on how many changes per version you make.
Jay
guy
PostPosted: Mon Oct 26, 2015 5:29 am     Reply with quote
I agree with Jay - try going back to an older version of the code. I also had a case when, after adding a piece of code, the message would sometimes appear after compilation and sometimes not. In another case it appeared due to while(true) instead of while(1) but it could be from numerous reasons.
dyeatman
PostPosted: Mon Oct 26, 2015 9:52 am     Reply with quote
Every single case of this I have encountered has always been a syntax
error on my part. I just comment out the latest lines until the problem goes
away and that tells me where to look.
Google and Forum Search are some of your best tools
CMatic
PostPosted: Tue Nov 10, 2015 9:20 am     Reply with quote
Yes, it was syntax. Thanks a lot Wink
