hayee
Driving an LCD Display |
Posted: Wed Nov 04, 2015 12:49 am |
I am driving an LCD Display having 3 Rows (8-8-6 Digits).
I'm using 18f252 micro-controller with 4Mhz crystal.
Manufacturer and the image of the LCD is in the given link
http://lantiandz.en.made-in-china.com/product/FqPEbGfOCeVp/China-Display-Board-X110-.html
They have used Quote: | HT1609L 2*40 channel LCD Driver IC |
I have write a code to drive the LCD. The code is as follows
#include <18f252.h>
#fuses HS,NOLVP,NOWDT
#use DELAY (CLOCK=4M)
#define data_pin PIN_A3 //data pin for LCD/keypad.
#define clock_pin PIN_A2 //clock pin for LCD/keypad.
#define strobe_lcd PIN_A1 //strobe pin for LCD.
int1 lcd_data[176]={
// dot, g, f, e, d, c, b, a
0, 0, 0, 0, 0, 0, 0, 0, // 21 position, Dot value -> No Effect
0, 0, 0, 0, 0, 0, 0, 0, // 20 position, Dot value -> Effect
0, 0, 0, 0, 0, 0, 0, 0, // 19 position, Dot value -> Effect
0, 0, 0, 0, 0, 0, 0, 0, // 18 position, Dot value -> Effect
0, 0, 0, 0, 0, 0, 0, 0, // 17 position, Dot value -> Effect
0, 0, 0, 0, 0, 0, 0, 0, // 16 position, Dot value -> No Effect
1, 0, 0, 0, 0, 0, 0, 0, // 15 position, Dot value -> No Effect
0, 0, 0, 0, 0, 0, 0, 0, // 14 position, Dot value -> Effect
0, 0, 0, 0, 0, 0, 0, 0, // 13 position, Dot value -> Effect
0, 0, 0, 0, 0, 0, 0, 0, // 12 position, Dot value -> Effect
0, 0, 0, 0, 0, 0, 0, 0, // 11 position, Dot value -> Effect
0, 0, 0, 0, 0, 0, 0, 0, // 10 position, Dot value -> No Effect
0, 0, 0, 0, 0, 0, 0, 0, // 09 position, Dot value -> No Effect
0, 0, 0, 0, 0, 0, 0, 0, // 08 position, Dot value -> No Effect
0, 0, 0, 0, 0, 0, 0, 0, // 07 position, Dot value -> No Effect
0, 0, 0, 0, 0, 0, 0, 0, // 06 position, Dot value -> Effect
0, 0, 0, 0, 0, 0, 0, 0, // 05 position, Dot value -> Effect
0, 0, 0, 0, 0, 0, 0, 0, // 04 position, Dot value -> Effect
0, 0, 0, 0, 0, 0, 0, 0, // 03 position, Dot value -> Effect
0, 0, 0, 0, 0, 0, 0, 0, // 02 position, Dot value -> No Effect
0, 0, 0, 0, 0, 0, 0, 0, // 01 position, Dot value -> No Effect
0, 0, 0, 0, 0, 0, 0, 0, // 00 position, Dot value -> No Effect
int1 out[8]={0,0,0,0,0,0,0,0};
int segx[22]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
// 0 , 1 , 2 , 3 , 4 , 5 , 6 , 7 , 8 , 9 ,Blank,P //
BYTE CONST segs_7[12]={0xfc,0x60,0xda,0xf2,0x66,0xb6,0xbe,0xe0,0xfe,0xf6,0x00,0xce};
int seg_loop,seg_loop2,c,b;
output_toggle(PIN_C0);
//Data to be shown on LCD.
segx[0]=9;segx[1]=8;segx[2]=7;segx[3]=6;segx[4]=5;segx[5]=4;
segx[6]=3;segx[7]=2;segx[8]=1;segx[9]=0;segx[10]=1;segx[11]=2;
segx[12]=3;segx[13]=4;segx[14]=5;segx[15]=6;segx[16]=7;segx[17]=8;
segx[18]=9;segx[19]=0;segx[20]=1;segx[21]=2;
c=175; //Total nos of segments in an LCD.
for(seg_loop=0;seg_loop<22;seg_loop++) //This loop place the 7-segment
{ // values of each digit.
b=0b10000000;
for(seg_loop2=0;seg_loop2<=6;seg_loop2++)
lcd_data[c-seg_loop2]=segs_7[segx[seg_loop]] & b;
rotate_right(&b,1);
c=c-8;
for(seg_loop=0;seg_loop<=175;seg_loop++) //This loop update all the LCD
{ //having 175 segments.
output_bit(data_pin,lcd_data[seg_loop]);
output_high(clock_pin);
output_low(clock_pin);
output_high(strobe_lcd);
output_low(strobe_lcd);
This is working fine but the whole routine is taking 24mS to complete the process. I want to reduce the timings.
Is there a way to simplify the routine and timings?
I don't want to use higher value of crystal nor PLL option.
Thanks |
Posted: Wed Nov 04, 2015 4:32 pm |
Look at the .LST file. It will tell you.
First, you have this output_bit() code. It uses an int1 array (lcd_data).
To handle this int1 array, it branches off to a routine at 0060.
Quote: |
.......... output_bit(data_pin,lcd_data[seg_loop]);
0198: MOVFF seg_loop,??65535
019C: CLRF @READBITA.P1+1
019E: MOVLW lcd_data
01A0: MOVWF @READBITA.P1
01A2: BRA 0060
01A4: BTFSC 01.0
01A6: BRA 01AC
01A8: BCF LATA.3
01AA: BRA 01AE
01AC: BSF LATA.3
01AE: BCF TRISA.3 |
Here is the bit cruncher routine at 0060:
Code: | 0060: MOVF ??65535,W
0062: ANDLW 07
0064: MOVWF @00
0066: RRCF ??65535,W
0068: MOVWF @01
006A: RRCF @01,F
006C: RRCF @01,F
006E: MOVLW 1F
0070: ANDWF @01,F
0072: MOVF @01,W
0074: ADDWF @READBITA.P1,W
0076: MOVWF FSR0L
0078: MOVLW 00
007A: ADDWFC @READBITA.P1+1,W
007C: MOVWF FSR0H
007E: MOVFF INDF0,01
0082: INCF @00,F
0084: BRA 0088
0086: RRCF @01,F
0088: DECFSZ @00,F
008A: BRA 0086
008C: GOTO 01A4 (RETURN) |
But what if I change the array declaration to int8, instead of int1 ?
Quote: | int8 lcd_data[176] |
Then output_bit() reduces to this, only:
Code: | ....... output_bit(data_pin,lcd_data[seg_loop]);
0132: CLRF @03
0134: MOVF seg_loop,W
0136: ADDLW lcd_data
0138: MOVWF FSR0L
013A: MOVLW lcd_data+-4
013C: ADDWFC @03,W
013E: MOVWF FSR0H
0140: MOVF INDF0,F
0142: BNZ 0148
0144: BCF LATA.3
0146: BRA 014A
0148: BSF LATA.3
014A: BCF TRISA.3 |
You could also make it a 'const' array, but that increases the run time
because it adds a little Table Read routine.
And these are just pure coding criticisms. There is also the question
of design. Your lcd_data[] array has all the bits set to 0 except for one
in the "15 position". Surely a better method of handling this single
exception could be invented, such as using an if() statement in the main
code. You don't need a huge array with only one little element set to 1.
This code below also needs to be cleaned up, but I didn't look at it:
Quote: | ......... lcd_data[c-seg_loop2]=segs_7[segx[seg_loop]] & b; |
hayee
Posted: Wed Nov 04, 2015 10:35 pm |
Thanks PCM programmer for your reply
Quote: | You could also make it a 'const' array, but that increases the run time
because it adds a little Table Read routine. |
I can't make it const because values will be changed in this array
in the "15 position" |
I initially declared the array to 0. "1" at 15 position is just for checking if the dot point on the LCD dispaly is changing or not..
my actual data is in
segx[18]=9;segx[19]=0;segx[20]=1;segx[21]=2; |
for example i want to update my LCD position 0 with a value 9. I will update the segx[0]=9, like that all the segx[0 ->21] will be updated with the desired values.
then these segx array values will be replace by their 7-segment values in the following loop
b=0b10000000;
rotate_right(&b,1);
c=c-8;
in the above loop lcd_data[] array will be replaced by the updated values.
then it will send data to LCD Display in the following routine
need further assistance to solve it.
one more query. i can't find where is 0060 located in list file. how can i see it. what i am only seeing is BRA 0060
.................... output_bit(data_pin,lcd_data[seg_loop]);
01AC: MOVFF seg_loop,??65535
01B0: CLRF @READBITA.P1+1
01B2: MOVLW lcd_data
01B4: MOVWF @READBITA.P1
01B6: BRA 0060
01B8: BTFSC 01.0
01BA: BRA 01C0
01BC: BCF LATA.3
01BE: BRA 01C2
01C0: BSF LATA.3
01C2: BCF TRISA.3
Posted: Wed Nov 04, 2015 11:26 pm |
Quote: | i can't find where is 0060 located in list file. how can i see it | First, do a search. Press Ctrl-F and search for 0060, and hopefully you
will find it. If not, it's possible that in your compiler version (you didn't
post your version), that it's hidden code. In that case, edit the 18F252.h
file and comment out the #nolist statement near the top of the file. Then
re-compile and search the .LST file again for it again.
Quote: | need further assistance to solve it. |
Did the changes that I already gave you, help to speed it up ?
I'll bet that they did. What is the measured speed increase ? |
hayee
Posted: Wed Nov 04, 2015 11:46 pm |
Yes PCM Programmer the program is speed up. Now it takes 12mS instead of 24mS. Thanks
My Compiler version is 4.124
I did as you said
//////// Standard Header file for the PIC18F252 device ////////////////
#device PIC18F252
//!#nolist
//////// Program memory: 16384x16 Data RAM: 1536 Stack: 31
//////// I/O: 23 Analog Pins: 5
//////// Data EEPROM: 256
//////// C Scratch area: 00 ID Location: 200000
//////// Fuses: LP,XT,HS,RC,EC,EC_IO,H4,RC_IO,OSCSEN,NOOSCSEN,PUT,NOPUT
//////// Fuses: NOBROWNOUT,BROWNOUT,BORV45,BORV42,BORV27,BORV20,NOWDT,WDT
//////// Fuses: WDT1,WDT2,WDT4,WDT8,WDT16,WDT32,WDT64,WDT128,CCP2B3,CCP2C1
//////// Fuses: NOSTVREN,STVREN,NOLVP,LVP,DEBUG,NODEBUG,PROTECT,NOPROTECT
//////// Fuses: CPB,NOCPB,CPD,NOCPD,WRT,NOWRT,WRTC,NOWRTC,WRTB,NOWRTB,WRTD
//////// Fuses: NOWRTD,EBTR,NOEBTR,EBTRB,NOEBTRB
But still not mentioning that location. Following is list file
CCS PCH C Compiler, Version 4.124 05-Nov-15 10:40
Filename: C:\Users\Abdul Hayee\Desktop\bluesky lcd\bluesky_test1.lst
ROM used: 476 bytes (1%)
Largest free fragment is 32292
RAM used: 57 (4%) at main() level
60 (4%) worst case
Stack: 1 locations
0000: GOTO main
.................... #include <18f252.h>
.................... //////// Standard Header file for the PIC18F252 device ////////////////
.................... #device PIC18F252
.................... #list
.................... #fuses HS,NOLVP,NOWDT
.................... #use DELAY (CLOCK=4M)
.................... #define data_pin PIN_A3 //data pin for LCD/keypad.
.................... #define clock_pin PIN_A2 //clock pin for LCD/keypad.
.................... #define strobe_lcd PIN_A1 //strobe pin for LCD.
.................... int1 lcd_data[176]={
.................... // dot, g, f, e, d, c, b, a
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 21 position, Dot value -> No Effect
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 20 position, Dot value -> Effect
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 19 position, Dot value -> Effect
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 18 position, Dot value -> Effect
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 17 position, Dot value -> Effect
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 16 position, Dot value -> No Effect
.................... 1, 0, 0, 0, 0, 0, 0, 0, // 15 position, Dot value -> No Effect
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 14 position, Dot value -> Effect
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 13 position, Dot value -> Effect
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 12 position, Dot value -> Effect
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 11 position, Dot value -> Effect
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 10 position, Dot value -> No Effect
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 09 position, Dot value -> No Effect
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 08 position, Dot value -> No Effect
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 07 position, Dot value -> No Effect
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 06 position, Dot value -> Effect
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 05 position, Dot value -> Effect
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 04 position, Dot value -> Effect
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 03 position, Dot value -> Effect
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 02 position, Dot value -> No Effect
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 01 position, Dot value -> No Effect
.................... 0, 0, 0, 0, 0, 0, 0, 0, // 00 position, Dot value -> No Effect
.................... int1 out[8]={0,0,0,0,0,0,0,0};
.................... int segx[22]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
.................... // 0 , 1 , 2 , 3 , 4 , 5 , 6 , 7 , 8 , 9 ,Blank,P //
.................... BYTE CONST segs_7[12]={0xfc,0x60,0xda,0xf2,0x66,0xb6,0xbe,0xe0,0xfe,0xf6,0x00,0xce};
.................... int seg_loop,seg_loop2,c,b;
0090: CLRF TBLPTRU
0092: BCF RCON.IPEN
0094: CLRF FSR0H
0096: CLRF FSR0L
0098: BSF ADCON1.PCFG0
009A: BSF ADCON1.PCFG1
009C: BSF ADCON1.PCFG2
009E: BCF ADCON1.PCFG3
00A0: CLRF lcd_data
00A2: CLRF lcd_data+1
00A4: CLRF lcd_data+2
00A6: CLRF lcd_data+3
00A8: CLRF lcd_data+4
00AA: CLRF lcd_data+5
00AC: MOVLW 01
00AE: MOVWF lcd_data+6
00B0: CLRF lcd_data+7
00B2: CLRF lcd_data+8
00B4: CLRF lcd_data+9
00B6: CLRF lcd_data+10
00B8: CLRF lcd_data+11
00BA: CLRF lcd_data+12
00BC: CLRF lcd_data+13
00BE: CLRF lcd_data+14
00C0: CLRF lcd_data+15
00C2: CLRF lcd_data+16
00C4: CLRF lcd_data+17
00C6: CLRF lcd_data+18
00C8: CLRF lcd_data+19
00CA: CLRF lcd_data+20
00CC: CLRF lcd_data+21
00CE: CLRF out+1
00D0: CLRF out
00D2: CLRF segx
00D4: CLRF segx+1
00D6: CLRF segx+2
00D8: CLRF segx+3
00DA: CLRF segx+4
00DC: CLRF segx+5
00DE: CLRF segx+6
00E0: CLRF segx+7
00E2: CLRF segx+8
00E4: CLRF segx+9
00E6: CLRF segx+10
00E8: CLRF segx+11
00EA: CLRF segx+12
00EC: CLRF segx+13
00EE: CLRF segx+14
00F0: CLRF segx+15
00F2: CLRF segx+16
00F4: CLRF segx+17
00F6: CLRF segx+18
00F8: CLRF segx+19
00FA: CLRF segx+20
00FC: CLRF segx+21
.................... while(TRUE)
.................... output_toggle(PIN_C0);
00FE: BCF TRISC.0
0100: BTG LATC.0
.................... //Data to be shown on LCD.
.................... segx[0]=9;segx[1]=8;segx[2]=7;segx[3]=6;segx[4]=5;segx[5]=4;
0102: MOVLW 09
0104: MOVWF segx
0106: MOVLW 08
0108: MOVWF segx+1
010A: MOVLW 07
010C: MOVWF segx+2
010E: MOVLW 06
0110: MOVWF segx+3
0112: MOVLW 05
0114: MOVWF segx+4
0116: MOVLW 04
0118: MOVWF segx+5
.................... segx[6]=3;segx[7]=2;segx[8]=1;segx[9]=0;segx[10]=1;segx[11]=2;
011A: MOVLW 03
011C: MOVWF segx+6
011E: MOVLW 02
0120: MOVWF segx+7
0122: MOVLW 01
0124: MOVWF segx+8
0126: CLRF segx+9
0128: MOVWF segx+10
012A: MOVLW 02
012C: MOVWF segx+11
.................... segx[12]=3;segx[13]=4;segx[14]=5;segx[15]=6;segx[16]=7;segx[17]=8;
012E: MOVLW 03
0130: MOVWF segx+12
0132: MOVLW 04
0134: MOVWF segx+13
0136: MOVLW 05
0138: MOVWF segx+14
013A: MOVLW 06
013C: MOVWF segx+15
013E: MOVLW 07
0140: MOVWF segx+16
0142: MOVLW 08
0144: MOVWF segx+17
.................... segx[18]=9;segx[19]=0;segx[20]=1;segx[21]=2;
0146: MOVLW 09
0148: MOVWF segx+18
014A: CLRF segx+19
014C: MOVLW 01
014E: MOVWF segx+20
0150: MOVLW 02
0152: MOVWF segx+21
.................... c=175; //Total nos of segments in an LCD.
0154: MOVLW AF
0156: MOVWF c
.................... for(seg_loop=0;seg_loop<22;seg_loop++) //This loop place the 7-segment
0158: CLRF seg_loop
015A: MOVF seg_loop,W
015C: SUBLW 15
015E: BNC 01A4
.................... { // values of each digit.
.................... b=0b10000000;
0160: MOVLW 80
0162: MOVWF b
.................... for(seg_loop2=0;seg_loop2<=6;seg_loop2++)
0164: CLRF seg_loop2
0166: MOVF seg_loop2,W
0168: SUBLW 06
016A: BNC 019C
.................... lcd_data[c-seg_loop2]=segs_7[segx[seg_loop]] & b;
016C: MOVF seg_loop2,W
016E: SUBWF c,W
0170: MOVWF @@37
0172: CLRF @03
0174: MOVF seg_loop,W
0176: ADDLW segx
0178: MOVWF FSR0L
017A: MOVLW segx+-27
017C: ADDWFC @03,W
017E: MOVWF FSR0H
0180: CLRF @03
0182: MOVF INDF0,W
0184: RCALL 0004
0186: ANDWF b,W
0188: MOVFF @@37,??65535
018C: MOVWF @WRITEBITA.P1
018E: CLRF @WRITEBITA.P2+1
0190: MOVLW lcd_data
0192: MOVWF @WRITEBITA.P2
0194: BRA 0020
.................... rotate_right(&b,1);
0196: RRNCF b,F
0198: INCF seg_loop2,F
019A: BRA 0166
.................... c=c-8;
019C: MOVLW 08
019E: SUBWF c,F
01A0: INCF seg_loop,F
01A2: BRA 015A
.................... for(seg_loop=0;seg_loop<=175;seg_loop++) //This loop update all the LCD
01A4: CLRF seg_loop
01A6: MOVF seg_loop,W
01A8: SUBLW AF
01AA: BNC 01D0
.................... { //having 175 segments.
01B6: BRA 0060
01B8: BTFSC 01.0
01BA: BRA 01C0
01BC: BCF LATA.3
01BE: BRA 01C2
01C0: BSF LATA.3
01C2: BCF TRISA.3
.................... output_high(clock_pin);
01C4: BCF TRISA.2
01C6: BSF LATA.2
.................... output_low(clock_pin);
01C8: BCF TRISA.2
01CA: BCF LATA.2
01CC: INCF seg_loop,F
01CE: BRA 01A6
.................... output_high(strobe_lcd);
01D0: BCF TRISA.1
01D2: BSF LATA.1
.................... output_low(strobe_lcd);
01D4: BCF TRISA.1
01D6: BCF LATA.1
01D8: BRA 00FE
01DA: SLEEP
Configuration Fuses:
Word 1: 2200 HS NOOSCSEN
Word 2: 0E0E PUT BROWNOUT BORV20 NOWDT WDT128
Word 3: 0100 CCP2C1
Word 4: 0081 STVREN NOLVP NODEBUG
Word 5: C00F NOPROTECT NOCPB NOCPD
Word 6: E00F NOWRT NOWRTC NOWRTB NOWRTD
Word 7: 400F NOEBTR NOEBTRB |
Posted: Thu Nov 05, 2015 5:46 pm |
hayee wrote: |
i can't find where is 0060 located in list file. how can i see it ?
But still not mentioning that location. |
Commenting out the #nolist statement worked for me. I installed
compiler vs. 4.124 and commented out #nolist in the 18F252.h file,
as shown in bold below:
Quote: | //////// Standard Header file for the PIC18F252 device ////////////////
#device PIC18F252
//#nolist
Then I re-compiled and looked at the .LST file, and there's the code
right at address 0060, as shown in bold below:
Quote: |
0000: GOTO main
0004: CLRF TBLPTRH
0006: ADDLW 14
0008: MOVWF TBLPTRL
000A: MOVLW 00
000C: ADDWFC TBLPTRH,F
000E: TBLRD*+
0010: MOVF TABLAT,W
0012: RETURN 0
0014: DATA FC,60
0016: DATA DA,F2
0018: DATA 66,B6
001A: DATA BE,E0
001C: DATA FE,F6
001E: DATA 00,CE
0020: MOVF ??65535,W
0022: ANDLW 07
0024: MOVWF @00
0026: RRCF ??65535,W
0028: MOVWF @01
002A: RRCF @01,F
002C: RRCF @01,F
002E: MOVLW 1F
0030: ANDWF @01,F
0032: MOVF @01,W
0034: ADDWF @WRITEBITA.P2,W
0036: MOVWF FSR0L
0038: MOVLW 00
003A: ADDWFC @WRITEBITA.P2+1,W
003C: MOVWF FSR0H
003E: CLRF @01
0040: INCF @01,F
0042: INCF @00,F
0044: BRA 0048
0046: RLCF @01,F
0048: DECFSZ @00,F
004A: BRA 0046
004C: MOVF @WRITEBITA.P1,F
004E: BZ 0056
0050: MOVF @01,W
0052: IORWF INDF0,F
0054: BRA 005C
0056: COMF @01,F
0058: MOVF @01,W
005A: ANDWF INDF0,F
005C: GOTO 0196 (RETURN)
0060: MOVF ??65535,W // Start of data fetch routine for int1 array
0062: ANDLW 07
0064: MOVWF @00
0068: MOVWF @01
006A: RRCF @01,F
006C: RRCF @01,F
006E: MOVLW 1F
0070: ANDWF @01,F
0072: MOVF @01,W
0076: MOVWF FSR0L
0078: MOVLW 00
007C: MOVWF FSR0H
0082: INCF @00,F
0084: BRA 0088
0086: RRCF @01,F
0088: DECFSZ @00,F
008A: BRA 0086
008C: GOTO 01B8 (RETURN)
The routine starts at 0060 and continues to 008C, where it returns to the caller. |
Eugeneo
Posted: Sun Nov 08, 2015 3:07 pm |
Something like this would be faster.
#define latch_seg output_high(clock_pin); output_low(clock_pin)
send_seg(int8 bit_value)
output_bit(bit_test (bit_value, 0);
latch_seg;
output_bit(bit_test (bit_value, 1);
latch_seg;
output_bit(bit_test (bit_value, 2);
latch_seg;
output_bit(bit_test (bit_value, 3);
latch_seg;
output_bit(bit_test (bit_value, 4);
latch_seg;
output_bit(bit_test (bit_value, 5);
latch_seg;
output_bit(bit_test (bit_value, 6);
latch_seg;
output_bit(bit_test (bit_value, 7);
latch_seg;
for(seg_loop=21; seg_loop > 0; seg_loop--)
send_seg(segs_7[segx[seg_loop]]);
