mka879
Hypertermial Showing Garbage Despite Correct Baud Rate |
Posted: Fri Oct 30, 2015 1:49 am |
I wrote the following Hello World program but the hyperterminal is showing garbage.
#include <gsm test.h>
#include<string.h>
#use rs232(baud=9600,xmit=PIN_c6,rcv=PIN_c7,PARITY=N,BITS=8,STOP=1)
output_bit(pin_b7,1); //initialization indicated by LED
output_bit(pin_b7,0);
printf("Hello World");
the gsm.h file is as follows
#include <16F877A.h>
#device ADC=16
#use delay(crystal=20000000)
I am using CCS PCWHD version 5.015 and a serial to usb converter. I checked a GSM module on teratrum(terminal software) and successfully send and receive messages using the same serial to usb converter and the terminal program so the converter and software cannot be faulty. Baud rate on the terminal program is 9600. Why am I not getting correct output? Please help. |
Posted: Fri Oct 30, 2015 2:07 am |
What have you got to do the voltage level conversion from TTL to RS232 on the PIC?.
A PIC _does not generate 'RS232'_. It generates 'async TTL serial', that can be converted to 'RS232', using a chip like a MAX232. Without this the output will be inverted compared to what a PC serial port expects.
It's always been to me a little bit confusing the way 'RS232' is referred to in the CCS driver, but 'async TTL serial', doesn't really help explain it, and they assume that people will realise that they need a driver chip. |
mka879
Posted: Fri Oct 30, 2015 2:36 am |
[quote="Ttelmah"]What have you got to do the voltage level conversion from TTL to RS232 on the PIC?.
It's always been to me a little bit confusing the way 'RS232' is referred to in the CCS driver, but 'async TTL serial', doesn't really help explain it, and they assume that people will realise that they need a driver chip.[/quote
I am using serial to uab converter instead of max232. Doesn't the converter handle the conversion? If the converter couldn't do this how did gsm module communicated which outputs TTL signals? |
mka879
Posted: Fri Oct 30, 2015 2:37 am |
Ttelmah wrote: | What have you got to do the voltage level conversion from TTL to RS232 on the PIC?.
I am using serial to usb converter instead of max232. Doesn't the converter handle the conversion? If the converter couldn't do this how did gsm module communicated which outputs TTL signals? |
Mike Walne
Posted: Fri Oct 30, 2015 2:45 am |
mka879 wrote: | Ttelmah wrote: | What have you got to do the voltage level conversion from TTL to RS232 on the PIC?.
No.
The USB converter is usually a USB to RS232 converter.
It allows USB only PCs to behave like legacy PCs with a real RS232 port.
So you probably still need a MAX232 (or equivalent) for your PIC.
Mike |
Posted: Fri Oct 30, 2015 3:32 am |
If you look at modules like this:
<http://www.ebay.com/bhp/gsm-modem-rs232>
These output RS232, _not_ TTL. You can get TTL ones, but have to look for this specifically. Then 99% of USB to serial PC adapters output/input RS232, not TTL. Again there are a few special ones that do use TTL, but these have to be carefully looked for. Such as:
<https://www.sparkfun.com/products/12977> |
Joined: 01 Jul 2010 Posts: 9219 Location: Greensville,Ontario
Posted: Fri Oct 30, 2015 5:12 am |
Sounds like you have a USB<>RS232 module and you need a USB<>TTL module.
You have a couple options.
1) Buy a USB<>TTL module and connect directly to the PICs UART pins. I've done this for almost a decade.Simple and easy.
2) Buy a 'MAX232' type chip and connect between the PIC and your USB<>RS232 module.This does require more parts(MAX232 + 4 caps) and wiring but would allow the PIC to have a true RS232 interface.
Cost. #1 is about $2USD. #2 is about $1
Labour.#1 is easy, NONE,#2,have to wire up 5 more components.properly!
Since ALL PCs these days do NOT have a true RS232 port,just USB option #1 is probably the best choice.
jeremiah
Posted: Fri Oct 30, 2015 5:27 am |
Keep in mind also that if it is a USB to RS232 converter, that you may have damaged your PIC's TTL pins. RS232 can run up to +- 15v. I don't remember off hand what most converters boost to (probably 5v...but just a guess). Be ready to have a spare PIC if that is the case. |
Mike Walne
Posted: Sat Oct 31, 2015 11:58 am |
I've just measured the signals from a randomly selected USB to RS232 converter.
I'm getting roughly +/-8V.
I've also tried the same test on a legacy PC, and got just shy of +/-10V.
I've only used the 5V version of MAX232 so can't comment on the 3V variety.
The booster on the 5V version is trying to double and invert the supply.
So the best it could do is +/- 10V, in practice I find I get +/-7V to +/-8V.
If the OP does HAVE A USB to RS232 converter he may have stuffed the PIC.
(All depends on current capability.)
Mike |
Posted: Sat Oct 31, 2015 12:15 pm |
Fortunately relatively low.
They have to produce 3v into a couple of Kohms only, so about a mA,
I've not seen a RS232 driver damage a logic gate in years. |
mka879
Posted: Wed Nov 04, 2015 1:27 am |
Ttelmah wrote: | If you look at modules like this:
Thank you Mike and Ttelmah. I figured out that the sim900 mini board has a max232 installed so the ttl voltage is converted to RS232 which I didn't noticed.
I have one another problem however related to AT commands. I am using PIC16f877a and the ccs c compiler mentioned in above post. I tested my code logic first using teraterm. The code is supposed to send AT until it receives OK from modem and make pin b7 high on reception of OK. When I checked it on tera term it was sending AT and when I typed OK it stopped and raised pin b7 high. But when I checked it on hardware it did not respond as expected. I believe it has something to do with <CR> and <LF> please help. The code is as follows
#include<string.h>
char flag[10];
int index = 0;
#int_rda
void isr_rda(void)
output_bit(pin_b4,1);
output_bit(pin_b4,0);
flag[index++] = getc();
clear_interrupt(int_rda);
//time for GSM Modem to initialize and register on the network
delay_ms(6000);
delay_ms(6000);
enable_interrupts(global);
enable_interrupts(int_rda);
char par[5];
par = "OK";
flag = "no";
//send AT until OK is received
while(strcmp(flag,par))
printf("AT\n");
//flag when OK is received
The LED on b4 blinks twice indicating two characters are received but b7 remains low. Please help. |
Posted: Wed Nov 04, 2015 2:07 am |
Do a search here on why you should not have delays in interrupt handlers.
Basic rule of interrupt handlers, is they should handle the job that the interrupt implies (so INT_RDA, should receive _one_ character, which is what the interrupt says is available), and then exit as fast as possible. Nothing else. |
mka879
Posted: Wed Nov 04, 2015 3:12 am |
Ttelmah wrote: | Do a search here on why you should not have delays in interrupt handlers.
Hmmm good point...... but I was wondering it should not be a significant factor in the current context since the code works as expected on tera term. |
mka879
Posted: Wed Nov 04, 2015 3:55 am |
Sorry I connected RX and TX of sim900 wrongly. Now the problem might be in sending AT plus "enter key". In the code I am sending AT with \n. My question is how to send enter key? |
ezflyr
Posted: Wed Nov 04, 2015 5:50 am |
Don't fool yourself, delays inside interrupt handlers are a 'significant factor' in virtually *any* circumstance! Just don't do it!
To answer your specific question, the Carriage Return (or Enter key) can be sent with '\r'. _________________ John
If it's worth doing, it's worth doing in real hardware! |
