Problem with function gets(string) rs232
kevinvig7
PostPosted: Sun Oct 25, 2015 8:36 am     Reply with quote
Hi I have a problem with the function gets(string).
I make a program in C sharp that send a string by serial port. The string is a hexadecimal number of 6 characters.
When I try receive this with CCS with function gets(string) in the rda interrupt the program does nothing, it ignores the received data from rs232.
Should I send a null character at the end of the string with C sharp?
jeremiah
PostPosted: Sun Oct 25, 2015 9:27 am     Reply with quote
A few things of note:
1. Never use gets() in the RDA ISR. The ISR is for receiving "1" character
2. There is almost never any need to use gets() to begin with.
3. Look at ex_sisr.c located in the examples directory of your PICC install. It will show you how to properly use the RDA interrupt. The only gotcha is the buffer size in that example needs to be a power of 2 (if you don't want this, search the forum for ex_sisr.c and see other threads on how to change it for this).
The big thing here is you need to start looking at it from an "embedded" perspective vs a desktop application perspective. The method gets() can hang in multiple ways. While this can be less problematic in a windows program (I still don't use it here either though), it is absolutely killer for an embedded program. Once you hang, your device is useless.
ezflyr
PostPosted: Sun Oct 25, 2015 9:34 am     Reply with quote
You are making a classic mistake with the #int rda serial interrupt handler. This interrupt is designed to receive ONE character, and one character only, which you do with the getc function. If you want to receive multiple characters, create an array and fill the array as characters are received. Have the C# program prefix the data with a 'start' character, such as '!', and append the data with 'stop' character, such as a CR of LF. Start buffering when '!' is received and stop with 'CR' or 'LF' is received.
To answer your specific question, the gets function will hang until a carriage return is detected. You could add that to your C# program.
John
If it's worth doing, it's worth doing in real hardware!
kevinvig7
PostPosted: Sun Oct 25, 2015 10:27 am     Reply with quote
Thanks for your answer!
Can you give me an example of a program that does this?
will have to send a string or character followed ?
Thanks!
ezflyr
PostPosted: Sun Oct 25, 2015 7:02 pm     Reply with quote
Read this thread, it describes how to do what you are asking: http://www.ccsinfo.com/forum/viewtopic.php?p=199146&highlight=#199146
John
