FILL_ROM and Checksum bug not fixed
Coffee
PostPosted: Mon Sep 21, 2015 11:17 am     Reply with quote
I'm using PCH compiler version 5.049 with a PIC18LF8722.
At the beginning, I'm using the checksum algorithm provided in the ex_checksum.c file for the PCH.
The code below shows a snippit of my main.h where I set the Fill_rom directive. I also show the #ID checksum_program directive
According to the on-line bug fix list at CCSINFO.COM, the issue with fill_rom and checksum was corrected in version 5.046.
The problem I'm having is that my code calculates the correct checksum when I DO NOT use the #FILL_ROM 0x00 directive. It DOES NOT calculate the checksum correctly when I use the FILL_ROM directive and rebuild the project. The ID Location always has the same checksum properly inserted at address 0x200000. This is all without using the debugger in the IDE.
If I use the Debugger mode, everything works OK WITH and WITHOUT the FILL_ROM directive.
My requirements are that I need to do a checksum at startup and compare it to the checksum inserted into the chip's ID LOCATION at compile time. I also need to insure that all my unused code space after my program is full of zeros (NOPs).
Any insight to what I'm doing wrong will be greatly appreciated.
// Includes
#include "18lF8722.h"
/* FUSE SETTINGS */
#FUSES NOWDT                    //No Watchdog timer
#FUSES NOPROTECT                //Code Not Protected From Reading
#FUSES MCLR
#FUSES PUT
#FUSES BBSIZ1K                  //1K words Boot Block size
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
// set ICD=TRUE only when using the CCS Debugger
#device ICD=TRUE
#FILL_ROM 0x00
#define VERSION_NUMBER   "Beta-1.6"
#use delay(internal=16MHZ)
Thank you,
Bill
Coffee
More Info on Fill_ROM / Checksum Problem
PostPosted: Tue Sep 22, 2015 8:20 am     Reply with quote
The on-line release notes are as follows:
" 5.046 A wrong checksum in "#ID checksum" when using #fill_rom is fixed"
That may not be exactly what I'm finding.
The checksum that I find in the ID Location appears to be correct with or without the Fill_Rom directive -- it's always the same value.
What I'm finding is that my run-time calculated value is very different when the Fill_Rom directive is used.
This is very puzzling. I think I'm going to have to go to Tech Support for this one...
Thank you,
Bill
