Logic contention(s) detected on net #00003.
Logic contention(s) detected on net #00001.
Logic contention(s) detected on net #00002.
Logic contention(s) detected on net #00004.
I connect the pins as it says in the library but it gives me error
Proteus cannot simulate the PIC at all well (a search here will find lots of posts about this).
Problem here is that the PIC pins are used by the driver as if they are tri-state. The driver reprograms the I/O direction, when the R/W line is used, so that the same pin used as an input can also be used as an output. Proteus cannot understand this, so complains.....
