Trouble with ext interrupt RB4-RB7
sonny
PostPosted: Mon Sep 14, 2015 9:55 am     Reply with quote
I'm new to the forum and to coding to. Anyway I'm struggling with the external interrupt change on value in RB5. I have a pic 1845J50, I made the circuit regulate an external voltage to a 3.3 V, I want to detect in RB5 when is changing from 0 to 3.3V and from 3.3 to 0. Basically changing from 1 to 0 or 0 to 1.
Please Help
TIA
PostPosted: Mon Sep 14, 2015 1:08 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=52922&highlight=intrb
http://www.ccsinfo.com/forum/viewtopic.php?t=52765&highlight=intrb
sonny
PostPosted: Tue Sep 15, 2015 6:33 am     Reply with quote
Thanks so yesterday I got it to work but I can't monitor the H_TO_L and the L_TO_H on the same time in different pins. I want when the interrupt sees the voltage going low then the LED2 goes high, but if goes high led1 goes high. Can't see my error, please help.
This is what I have
#INT_RB
RB()
if(INPUT(PIN_B5) == 1)
   output_high(LED1);
else if (INPUT(PIN_B4) == 0)
   output_high(LED2);
TRISB = 0b11110000;
PORTB = 0X00;
ext_int_edge(L_TO_H);
ext_int_edge(H_TO_L);
enable_interrupts(INT_RB);
clear_interrupt(INT_RB);
output_low(LED1);
output_low(LED2);
