pic24fj + explorer16 + WDT + v5.045d
ipq
PostPosted: Thu Aug 20, 2015 2:00 am     Reply with quote
After reading many time the datasheet of this micro, I'm not able to apply correctly the WDT and DSWDT. There are some concepts which I don't really understand and hope that someone could explain...
Here is my source code:
MAIN.H //////////////////////////////
#include <24FJ128GA310.h>
#FUSES WDT                      //Watch Dog Timer
#FUSES WDT32                    //Watch Dog Timer uses 1:32 Postscale
#FUSES WPOSTS11                 //Watch Dog Timer PostScalar 1:1024
#FUSES WINDIS                   //Watch Dog Timer in non-Window mode
#FUSES NOLVR                    //Low Voltage Regulator Disabled
#FUSES IOL1WAY                  //Allows only one reconfiguration of peripheral pins
#FUSES NOOSCIO                  //OSC2 is clock output
#FUSES CKSFSM                   //Clock Switching is enabled, fail Safe clock monitor is enabled
#FUSES VREFNORM_CVREFNORM       //VREF and CVREF are mapped to their default pins
#FUSES WPFP                     //Write/Erase Protect Page Start/End Location, set to last page or use WPFP=x to set page
#FUSES VBATBOR                  //VBAT BOR Enabled
#FUSES SOSC_SEL                 //SOSC circuit selected
#FUSES WDTWIN_25%               //Watchdog Window is 25% of WDT period
#FUSES WPDIS                    //All Flash memory may be erased or written
#FUSES NOWPCFG                  //Configuration Words page is not erase/write-protected
#FUSES WPEND                    //Flash pages WPFP to Configuration Words page are write/erase protected
#FUSES DSWDT_1SEC               //DSWDT uses 1:32768 Postscale (1.057Secs)
#FUSES DSWDTCK_LPRC             //DSWDT uses LPRC as reference clock
#FUSES DSBOR                    //BOR enabled in Deep Sleep
#FUSES DSWDT                    //Deep Sleep Watchdog Timer enabled
#FUSES DS_SW                    //Deep Sleep is controlled by the register bit DSEN
#device ICD=TRUE
#device ICSP=1
#use delay(internal=8MHz)
#define RUN_LED PIN_A0
MAIN.C ////////////////////////////////////////////////////
#include <main.h>
void main(){
  setup_wdt(WDT_ON);
  output_low( RUN_LED ); // turn on RUN LED
  output_high( RUN_LED ); // turn off RUN LED
  while (true){
  sleep(SLEEP_IDLE);
  delay_cycles(1);
  output_toggle(RUN_LED);
//  restart_wdt();
As you can imagine, this code is not working and I do not get exactly the reason why...I guess the problem are the configuration bits, but I have tried all combinations and still doesn't seem to work.
My question is the following...
DSWDT:
I guess it is only applied when the mcu is in sleep mode...doesn't it?
Is it required to execute the instruction setup_wdt(WDT_ON) to enable it if the fuse DS_SW is not present?
WDT:
POR when software malfunction or any instruction takes too long (under values set in prescaler and postscaler).
In case it is not driven by software and pre and post are using fuses...is it required to execute the instruction setup_wdt(WDT_ON)? it it does...if we use setup_wdt(WDT_ON| WDT_1S)...does this last parameter overrides the values set using FUSES? Does this instruction affect WDT and DSWDT?
I know these are really basic concepts but I've read the datasheet many times and I do not get it. Moreover, the most frustrating is that I'm able to make it work with xc16 but not with ccs.
Thanks in advance.
PostPosted: Thu Aug 20, 2015 8:24 am     Reply with quote
Key thing. One simple statement. The watchdog, is _always_ disabled in DEBUG mode.
Simple little thing you can always do, look at the end of the LST file to see the actual fuses being generated. You will find:
Configuration Fuses:
   Word  1L: 378A   WPOSTS11 WDT32 NOWDT WINDIS ICSP1 NOLVR DEBUG NOWRT NOPROTECT NOJTAG
          H: 0000
Note 'NOWDT'.
If you turn off ICD, you will instead see:
   Word  1L: 3FEA   WPOSTS11 WDT32 WDT WINDIS ICSP1 NOLVR NODEBUG NOWRT NOPROTECT NOJTAG
          H: 0000
Note 'WDT'.....
This is a limitation with DEBUG/ICD.
To debug this you have to use a chip directly, not in DEBUG.
