SIOW Clear Screen / move cursor
NB_CAD
PostPosted: Mon Jul 27, 2015 6:35 pm     Reply with quote
Is there a character sequence that will clear screen when using the SIOW serial monitor?
Can the cursor be moved?
Does it emulate any terminal commands?
dyeatman
PostPosted: Mon Jul 27, 2015 7:28 pm     Reply with quote
The SIOW will respond to VT100 esc sequences
Google and Forum Search are some of your best tools!!!!
NB_CAD
PostPosted: Tue Jul 28, 2015 6:17 am     Reply with quote
I tried this without success. Here is my code to make a simple oscilloscope. I tried using the Graph but found it to be slow and had difficulty to make it reset reliably. Also it is less universal.
   printf("Points Collected => %3u \n\r",plotPoints);
   for (i=160; i>0 ;i-=10){
      outString="";
      for (int8 plotIndex =0; plotIndex<plotPoints; plotIndex++){
         if (plotArray[plotIndex]>i) {
            strcat(outString,"X");
         }else{
            strcat(outString," ");
      printf(outString);printf("\r\n");
   printf("\r\n Clearing ");
   delay_ms(100);            // Whenever in doubt I delay
   printf("\x1b[2J");          // CLEAR SCREEN CODES ????
   delay_ms(2000);
   printf(" Clear ");
Result -->
X
XXX XXX X
XXXXX XXX X
XXXXXXXXX X
XXXXXXXXXX XX
XXXXXXXXXX XX
XXXXXXXXXX XX
XXXXXXXXXX XX
XXXXXXXXXX XX
XXXXXXXXXX XX
XXXXXXXXXX XXX
XXXXXXXXXXX XXX
XXXXXXXXXXX XXX
XXXXXXXXXXX XXXX
XXXXXXXXXXXXX XXXXX
Clearing  Clear Points Collected => 65
X
XXX XXX
XXXXX XXX X
XXXXXXXXX X
XXXXXXXXXX XX
XXXXXXXXXX XX
XXXXXXXXXX XX
XXXXXXXXXX XX
XXXXXXXXXX XX
XXXXXXXXXX XX
XXXXXXXXXX XXX
XXXXXXXXXXX XXX
XXXXXXXXXXX XXX
XXXXXXXXXXX XXXX
XXXXXXXXXXXX XXXXX
Clearing
I appreciate your assistance.
dyeatman
PostPosted: Tue Jul 28, 2015 12:33 pm     Reply with quote
printf("\033[2J"); // clear screen
printf("\033[H"); // home the cursor
NB_CAD
PostPosted: Tue Jul 28, 2015 8:14 pm     Reply with quote
Thank you for your help. Your code is clean and works well although I needed to run the program on Tera Term.
I like the SIOW since my product is developed from the RapidUSB. It allows me to develop without needing to use my ICD64. Ultimately i will need to run the product on another terminal emulator (Unless I am missing a configuration setting for the SIOW.)
Image of the ASCII plot diagnostic screen with level information.
[img]https://dl.dropboxusercontent.com/u/61824884/Plot%20with%20Sonar.PNG [/img][img][/img]
