How to debug memory corruption?
E_Blue
PostPosted: Mon Jul 13, 2015 7:54 am     Reply with quote
I'm having a issue with inside an struct
struct GPRS{
    short Reset;
    short StartSIM900;
    char  IP_Attemps;
    short ComFromSMS;
    short IDxError;
    char  SMS_Phone[15];
    short ChkError;
    short Responder;
    short MassiveAnswer;
    char Step;
    short ShutGPRS;
    char VectorTypeArray[7];
    char VectorActual;
    short AllVectorsInit;
    char GPRS_Step;
    char Pendientes;
    short UnderBit;
}GPRS_Status;
The variable VectorTypeArray[7] is set to zero one by one every time that a CCP interrupt ends.
The compiler version is 5.025.
I'm using this variable only inside an interrupt routines
I think that can be a issue with the FSR register.
I wonder if there any way to make a breakpoint when a variable change to detect what line of code is messing with this variable.
Electric Blue
PostPosted: Mon Jul 13, 2015 9:10 am     Reply with quote
What processor?.
Generally, there is no simple debugging method to find this.
The compiler/chip does not support bit aligned variables. So you will be wasting bytes as the compiler has to use 2 bits for the first two shorts, then byte/word align (depending on the chip) for the characters.
Better to organise your data so things are easier to align:
struct GPRS{
    char  SMS_Phone[15];
    char  IP_Attemps;
    char GPRS_Step;
    char Pendientes;
    char VectorActual;
    char Step;
    short Reset;
    short StartSIM900;
    short ComFromSMS;
    short IDxError;
    short ChkError;
    short Responder;
    short ShutGPRS;
    short UnderBit;
}GPRS_Status;
E_Blue
PostPosted: Mon Jul 13, 2015 9:31 am     Reply with quote
The processor is PIC18F67j50.
Thanks for the tip; I tried and get this results.
Before the change
ROM used 37702 RAM used 2614
After the change(reorder shorts)
ROM used 37792 RAM used 2608.
I don't get why use more ROM, I did not change the code. Confused
Electric Blue
