brutto
about #byte #bit and xxxx.bits |
Posted: Wed Jun 24, 2015 11:38 am |
hello,
i have a question, i can do:
#BYTE IFS0=0X0084
#BIT IEC0_AD1IE=0X0094.13 |
but could i do any word to write 3 bits for one register? for example, the register "IPC3bits.AD1IP" have 3 bits, would be the solution this?
#BIT IPC3_AD1IP0=0x00A4.4
#BIT IPC3_AD1IP1=0x00A4.5
#BIT IPC3_AD1IP2=0x00A4.6
ipc3_ad1ip0=0; //IPC3bits.AD1IP=6
ipc3_ad1ip1=1;
ipc3_ad1ip2=1;
or is there any other solution to write directly "6" in ipc3.ad1ip register??
thanks in advance... |
Posted: Wed Jun 24, 2015 11:50 am |
Yes, declare a structure with bitfields. Then write to the bitfields in your
code. The compiler will handle inserting the correct data into the bits.
Look at the .LST file to see this.
#include <16F690.h>
#fuses INTRC_IO,NOWDT
#use delay(clock=4M)
// This structure divides PortB into two bitfields.
struct {
int8 Columns:4; // B0-3: Output pins
int8 Rows:4; // B4-7: Input pins
}PortB;
#byte PortB = getenv("SFR:PORTB")
set_tris_b(0);
PortB.Columns = 6;
PortB.Rows = 3;
while(TRUE);
Posted: Wed Jun 24, 2015 12:06 pm |
There is another thing you can do, and a comment.
#byte creates a byte variable at a location if asked to. #word creates a 16bit word. To use bit 13, you should be using #word.
However #byte can also do something else. If given the name of an already declared variable, it can _locate_ this variable at the location. So you can declare a struct, using bit fields, like:
#struct
int8 dummy:4; //bits 0 to 3
int8 ip:3;
int8 dummy2:1;
} ipc3bits ;
#byte ipc3bits=0xA4
You can then write to the variable ipc3bits.ip as a 3bit integer sitting at the required location in the register!.... |
brutto
Posted: Sat Jun 27, 2015 2:53 am |
thanks guys, i will try with that |
