Trying to get started with first CCS board
golson8436
PostPosted: Thu Jun 25, 2015 6:55 pm     Reply with quote
I am targeting a PIC24FJ256GB206 PIC. The USB24 board.
Trying to run the example program. But it was set up for a different
chip. The code looks like this now.
#include <24FJ256GB206.h>         // Modify for your chip
//use delay(crystal=32mhz)   // Modify for your clock and freq
                            //   for example: internal=8mhz
#use delay(internal=32mhz)
void main(void) {
    while(TRUE) {           // Produces a 1khz square wave on pin B0
        output_high(PIN_B0);
        delay_us(500);
        output_low(PIN_B0);
        delay_us(500);
But I am getting a verification error when I try to download this code to the board through the ICD-U64 programmer.
Memory usage: ROM=0% RAM=0% - 0%
0 Errors, 0 Warnings.
Build Successful.
CCSLOAD: Connecting
CCSLOAD: Programming PIC24FJ256GB206
CCSLOAD: Error: Verification Error
Thank You,
Gary
PostPosted: Thu Jun 25, 2015 7:03 pm     Reply with quote
ICD cable length issue for PIC24:
http://www.ccsinfo.com/forum/viewtopic.php?t=51762
