Big error in 12c (HELP URGENT)
lucasromeiro
PostPosted: Tue Jun 23, 2015 6:27 pm     Reply with quote
I have a problem I have never seen.
I made a plate with 3 peripheral devices connected in communication i2c.
But I'm not getting to use them!
These devices are:
DS 1307
MCP 3424
24LC1025
I'm using pullup of 4.7k
I'm using a pic: 18LF2685
I am using ccs in version: 5,008
In the DS1307 I get an incorrect date, is not so and never changes:
00/02/03
0:00:00
MCP-3424 readings are incorrect, arrive very small and incorrect values even changing configurations.
In 24LC1025 does not respond to my command.
I do not understand what happens, because there was already simulated in Proteus and worked properly!
Already used two different plates to see if the problem was not the board, the two work the same.
I do not know what to do!
It could be the resistors pullup?
FUSES?
COMPILER??
I checked and the call is correct.
The code I'm testing is very simple and has no complications, see below.
Can anyone help me?
already I do not know what to do ...
#include "18LF2685.h"
#device ADC=16
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES NOPBADEN                 //PORTB pins are configured as digital I/O on RESET
#FUSES BBSIZ1K                  //1K words Boot Block size
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES PROTECT                  //Code protected from reads
#use delay(crystal=20000000)
#use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=Modem)
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3)
#include "ds1307.c"
#include "mcp342X.c"
#include "241025.c"
#include "STRING.h"
//DEFINES
#define regulador_modem PIN_C1
#define WATCHDOG PIN_B5
#define CONFIGURA PIN_A5
#Define Buffer_size 100
//VARIAVEIS CONFIG
//LEITURAS
float analogica_1;
float analogica_2;
float analogica_3;
float analogica_4;
int32 hidrometro_1;
int32 hidrometro_2;
int32 hidrometro_3;
//VARIAVEIS RELOGIO
   unsigned int8 dia=0;
   unsigned int8 mes=0;
   unsigned int8 ano=0;
   unsigned int8 hora=0;
   unsigned int8 min=0;
   unsigned int8 seg=0;
int set_dia;                        //variaveis de SET
int set_mes;                        //essas variaveis vao ser atribuidas pelo modem
int set_ano;
int set_hora;
int set_min;
int set_seg;
int1 LED=1;
int1 Ativa_Interrupcao_RDA;
unsigned int16 J=0;
unsigned int16 cont_serial=0;
unsigned int32 tempo=0;
char dado_recebido_modem[Buffer_size];
BYTE _dia;
BYTE _mes;
BYTE _ano;
BYTE _dow;
BYTE _hora;
BYTE _min;
BYTE _seg;
   setup_adc_ports(AN0_TO_AN3);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_32);      //420 ms overflow
   enable_interrupts(INT_RTCC);
   enable_interrupts(INT_EXT);
   enable_interrupts(INT_EXT1);
   enable_interrupts(INT_EXT2);
   enable_interrupts(INT_RDA);
   output_high(regulador_modem);
   adc_init();
   ds1307_init();
   init_ext_eeprom();
   fprintf(Modem, "Inicio:\r\n");
   ds1307_set_date_time(16,06,2015,0,20,48,00);
   int a,b;
      While(1){
    write_ext_eeprom(a,10);
    b = read_ext_eeprom(10);
    Fprintf(Modem, "\r\n %d",b);
    a++;
      ds1307_get_date(&_dia,&_mes,&_ano,&_dow);//Ler Data
      ds1307_get_time(&_hora,&_min,&_seg);//Ler Hora
      Fprintf(Modem,"\r\n%02d/\%02d/\%02d",_dia,_mes,_ano);//Exibir
      Fprintf(Modem,"\r\n%02d:\%02d:\%02d",_hora,_min,_seg);//Exibir
   set_adc_channel_mcp(0);
   analogica_1=read_adc_mcp();
   Fprintf(Modem,"\r\n 1: %ld",analogica_1);//Exibir
   set_adc_channel_mcp(1);
   analogica_2=read_adc_mcp();
   Fprintf(Modem,"\r\n 2: %ld",analogica_2);//Exibir
   set_adc_channel_mcp(2);
   analogica_3=read_adc_mcp();
   Fprintf(Modem,"\r\n 3: %ld",analogica_3);//Exibir
   set_adc_channel_mcp(3);
   analogica_4=read_adc_mcp();
   Fprintf(Modem,"\r\n 4: %ld",analogica_4);//Exibir
PostPosted: Tue Jun 23, 2015 7:37 pm     Reply with quote
You have no interrupt routines for any of these interrupts.
int a,b;
While(1){
The address 'a' is never initialized to a specific address.
The ds1307 driver doesn't support a 4-digit year. Only two digits.
You are writing the value of 10 to address 'a'. Then you read address 10.
But you didn't write to address 10. You wrote to address 'a'.
Basically, you didn't read the manual or the driver specifications, given
in each driver file.
lucasromeiro
PostPosted: Tue Jun 23, 2015 7:56 pm     Reply with quote
int a,b;
While(1){
I removed the functions interrupt because station empty.
This was the last test I did, already tested fixed values in recording and reading memory and did not work!
I had already tested this code before and did not work:
      While (1) {
    write_ext_eeprom (10,10);
    b = read_ext_eeprom (10);
    Fprintf (Modem, "\ r \ n% d", b);
    delay_ms (1000);
As the change in the adjustment handle the DS1307, the date changed to the format below and the same error occurs, time does not increases and nothing works!
00/02/01
0:00:00
I believe that the problem is being in something of communication ..
PostPosted: Tue Jun 23, 2015 8:17 pm     Reply with quote
Run this i2c bus scanner progam and see if it finds your i2c chips.
http://www.ccsinfo.com/forum/viewtopic.php?t=49713
Post the results.
lucasromeiro
PostPosted: Tue Jun 23, 2015 8:27 pm     Reply with quote
Post the results.
RESULT OF TEST:
*p:▒Utu▒ACK addr: A6
ACK addr: D0
Number of i2c chips found: 2▒hE▒▒▒▒
ACK addr: A6
ACK addr: D0
Number of i2c chips found: 2ACK addr: A6
ACK addr: D0
Number of i2c chips found: 2▒▒hE▒▒▒▒
ACK addr: A6
ACK addr: D0
PostPosted: Tue Jun 23, 2015 8:50 pm     Reply with quote
The ds1307 has a slave address of 0xD0. The MCP3424 also has a default
slave address of 0xD0. This will not work. There is an address conflict.
But, it can be fixed.
The MCP3424 can be configured to use a different slave address.
If you connect the Adr0 pin to ground, and leave Adr1 un-connected,
the slave address will be changed to 0xD2. Then you can edit the
MCP342x.c file and change the following line to use 0xD2 as shown below:
#define MCP342X_DEVICE_CODE       0xD2
Make that change to your board and run the i2c bus scanner program
again.
lucasromeiro
PostPosted: Tue Jun 23, 2015 9:20 pm     Reply with quote
again.
Result of scanner:
ACK addr: A6
ACK addr: D0
ACK addr: D2
Number of i2c chips found: 3
PostPosted: Tue Jun 23, 2015 9:26 pm     Reply with quote
Now you can edit the MCP342x.c file and change the following line to use
Then compile and start testing your program again.
lucasromeiro
PostPosted: Tue Jun 23, 2015 10:10 pm     Reply with quote
UHULLLL
Now ALL work!!
look:
10
16/06/15
20:49:43
1: 2
2: 131071
3: 2
4: 2
TKS man
