spilz
| 18f27j53 no write_configuration_memory available ?? |
Posted: Thu Jun 18, 2015 2:47 pm |
Hello
I'm starting with pic18F27j53 (before I used 18F2550).
I try to use the write_configuration_memory function, but I have an error (V5.045) "undefined identifier -- write_configuration_memory"
Why do I have this error ?
What is the solution to change clock source and pll config ?
Thanks for your help
Spilz |
spilz
Posted: Fri Jun 19, 2015 6:33 am |
can I use
| Code: | int data[4];
read_program_memory(0x300000,data,4);
// ... change config
write_program_memory(0x300000,data,4);
thanks for your help
Spilz |
Posted: Fri Jun 19, 2015 8:11 am |
Read section 28.1.1 in the data sheet.
The configuration is different in these chips. It doesn't actually have 'configuration memory' as such. It has 'FCW'. These are 4 _words_ (not bytes) of memory at the top of the program memory. When you boot, these 4 words are copied into the configuration registers. For your chip they are at 0xFFF8 to 0xFFFF.
Remember though that to change these you have to write the entire _page_.
I have to ask why you want to change these?.
Bootloader's should not change the configuration. |
spilz
Posted: Fri Jun 19, 2015 8:31 am |
Hello Ttelmah,
Thanks for your reply,
I know that bootloader shouldn't change it, but I have a sub bootloader, so on 18F2550 I need to activate pll with 4MHz Quartz for USB and my software have to run at 4MHz with pll disable to save a lot of power...
So if bootloader is started, it directly change the config to have the good one, and after it finish the job, there is a specific space memory where software config is stored (that at define, always at the same location) the bootloader load the software config.
It's not perfect, specially for R/W cycles but it works well and I doesn't find an other way to do it ...
Sorry for the stupid question, but how big is a _page_ ?
Is there a simple way to write the entire page ?
Thanks for your help |
Posted: Fri Jun 19, 2015 11:49 am |
You do realise, that if you change the configuration, it won't apply till the _next_ boot. So you can't just change it, and run at the other speed. It's going to be very complex to do.
You can switch speeds in software though. If timings are not essential in the low power mode, just have the fuses default to running with the crystal/PLL, and then just software switch to the internal oscillator at 4MHz, to save power (and turn off the primary oscillator).
On the J53, the erase page is 1024 bytes. Means if you want to change the configuration, the whole top 1024 have to be read, the changes made, and re-written...... |
spilz
Posted: Sat Jun 20, 2015 10:37 am |
I realise that, I need to find a safe solution
I don't really understand why I have to erase all the page, I did a test with : | Code: | read_program_memory(0x1FFF8,data,8);
config1 = 0x0000|0x000E|0x0010|0x0020|0x0080|0x0300|0x0400;
config2 = 0x0004|0x0018|0x0000|0x0000|0x0080;
data[1] = config1 >> 8;
data[0] = (int)config1;
data[3] = config2 >> 8;
data[2] = (int)config2;
write_program_memory(0x1FFF8,data,8); |
and it seems to work well (after restart of course) |
Posted: Sun Jun 21, 2015 4:23 am |
| You can only change bits from their _erased_ state, to their 'set' state. Once a bit is set, you can't then clear it, without an erase. |
spilz
spilz
Posted: Sun Jun 21, 2015 2:48 pm |
from : https://www.ccsinfo.com/forum/viewtopic.php?t=53690&postdays=0&postorder=asc&start=15
| Quote: | | Seriously, I still think you should 'think again', and change the clock rate another way. If you lose power during the config write, then the chip will have to be reprogrammed with an external programmer. It is a dangerous thing to do. One of the reasons it is so complex, is that Microchip do not expect this to be done. It's a wrong/dangerous approach. |
I already try to use internal clock, but I had issue with serial port and temperature change...
The other only way I see is to be abble to turn on/off pll by software. I don't know if it's possible. |
Posted: Mon Jun 22, 2015 12:31 am |
When using the internal clock, what you can do, is adjust to compensate for temperature.
The 'standard' clock is good enough over normal room ranges, provided you are using a baud rate that results in low error, but if this is not the case, what you do is have the transmitting device send a 'sync' frame at the start of it's comms. Typically something like <CR><0x55><0x55><CR>. At the start of the comms (when you see the CR), you enable the autobaud feature of the UART, which automatically adjusts the baud rate used in the chip to match the bit width of the next character received (must by 'sync' - 0x55).
Your baud rate will then be _better_ for the next few minutes, than typically achieved even when using a crystal....
MicroChip do expect you to be able to get reliable comms with the internal clock. |
spilz
Posted: Mon Jun 22, 2015 2:22 am |
it's good to know,
but in my case I can't use it :
It's to use a SIM900 board with the pic and AT commands, I can't change the protocol...
The electronic is in a waterproof box outside, so in summer it become hot inside the box and I had creasy sms sent because of the internal clock not reliable with this temperature difference..
In the datasheet p36, It seems I can turn ON/OFF PLL by software, using PLLEN.
I try that, but it does not work :
| Code: | setup_oscillator(osc_pll_on);
... // led blink 5 times at 1Hz
setup_oscillator(osc_pll_off);
... // led blink 5 times at 1Hz |
I did test with 1Hz blinking led, hopping frequence changing, but no change |
spilz
Posted: Mon Jun 22, 2015 2:25 am |
the other way can be to use interclock with PLL for bootloader, and external clock without bootloader for normal program.
I don't know if it's possible do to that |
Posted: Mon Jun 22, 2015 2:46 am |
Did you have the PLL enabled in the fuses?.
You can _disable_ the PLL if it is enabled, but you can't enable it, if it is disabled in the fuses.
So as I said before, you want the PLL _enabled_ in the fuses, and then have the slow code turn it off.
Look at Table 3-1. Note that with HS, it says:
High-Speed Crystal/Resonator mode,
PLL always disabled, crystal/resonator
connected between RA6 and RA7.
Note 'PLL always disabled'.
Then look at HSPLL:
PLL can be enabled or disabled in
software, crystal/resonator connected
Note 'PLL can be enabled or disabled in software'. |
spilz
Posted: Mon Jun 22, 2015 2:49 am |
I tried both, and I had the same result..
| Code: | | #fuses HSPLL,PLL1,PLLEN |
and
| Code: | | #fuses HSPLL,PLL1,NOPLLEN |
Posted: Mon Jun 22, 2015 3:19 am |
How are you actually testing this?. In a chip for real?.
#include <18F27J53.h>
#device ADC=10
#use delay(clock=48MHz,crystal=4000000)
#fuses HSPLL,NOPLLEN,PLL1,NOCPUDIV,NOXINST,STVREN,NOWDT,SOSC_DIG
void flash(void)
int8 ctr;
for (ctr=0;ctr<5;ctr++)
output_high(PIN_B0);
output_low(PIN_B0);
flash(); //5 seconds
setup_oscillator(OSC_PLL_OFF);
flash(); //48 seconds
delay_cycles(1);
I just merrily tried this, and it did exactly as expected.
Be aware that most debuggers will _not_ change the PLL when running. |
