PIC12F675 input question
corgenius
PostPosted: Sat Jun 13, 2015 1:18 pm     Reply with quote
Dear colleagues,
Recently I've developed a code for making a small delay project using a PIC12F675.
The program makes an output high for a specific amount of time and it works perfectly but just for ONE input.
I've tried to add 2 inputs to have different delay time for the same output, but it seems whatever I try, the only input that works is the one that is written first in the code.
My code is :
#include <12F675.h>
#FUSES INTRC_IO
#use delay(clock=4MHz)
#define LAMP_BUTTON    PIN_A0
#define LAMP_BUTTON2   PIN_A2
#define LAMP           PIN_A5
#define LAMP2          PIN_A4
#define LAMP3          PIN_A1
#define SWITCH_PRESSED      0          //  5V
#define SWITCH_NOT_PRESSED  1          //  0V
int8 previous, current, previous2, current2;
delay_us(100);                     // delay for pullups
output_high(LAMP3);                //STATUS MICROCONTROLLER - LED ON = MICROCONTROLER ON
//first input
previous2 = !input(LAMP_BUTTON2);   // read buton
While (true)                        // FOREVER LOOP
current2 = !input(LAMP_BUTTON2);
if((current2 == SWITCH_PRESSED) && (previous2 == SWITCH_NOT_PRESSED))
output_high(LAMP);
delay_ms(5000);
output_low(LAMP);}
previous2 = current2;
//secund input
previous = !input(LAMP_BUTTON);   // read buton
current = !input(LAMP_BUTTON);
if((current == SWITCH_PRESSED) && (previous == SWITCH_NOT_PRESSED))
delay_ms(200);                // DELAY
output_high(LAMP);            // Open PIN_A5
// light game - just for fun - start
output_high(LAMP2);
delay_ms(3000);
output_low(LAMP2);
delay_ms(300);
output_high(LAMP2);
output_low(LAMP2);
delay_ms(200);
output_high(LAMP2);
delay_ms(900);
output_low(LAMP2);
delay_ms(180);
output_high(LAMP2);
// light game - just for fun - end
output_low(LAMP);                                  // close pin_a5
output_low(LAMP2);                                  //close light game LED
delay_ms(30);
previous = current;
delay_ms(30);
I'm guessing its from
#FUSES INTRC_IO
I've tried to search the datasheet but with no results.:( Also tried modifying it in order to add I2 as INTRC but with no result
Does anyone have an idea why the code doesn't accept 2 inputs?
Warm regards,
Eugeniu
ezflyr
PostPosted: Sat Jun 13, 2015 3:13 pm     Reply with quote
It's working exactly as you coded it! Hint: how does your code ever get beyond the 1st While loop? You need to investigate what While (true) means!
John
corgenius
PostPosted: Sun Jun 14, 2015 10:47 am     Reply with quote
Dear colleagues,
I've tried modifying the code in order to have just one
while(true)
, but I didn't had any luck:(.
#include <12F675.h>
#FUSES INTRC_IO
#define LAMP           PIN_A5
//first input
output_high(LAMP);
delay_ms(5000);
output_low(LAMP);}
//secund input
output_high(LAMP2);
delay_ms(3000);
output_low(LAMP2);
delay_ms(300);
output_high(LAMP2);
output_low(LAMP2);
delay_ms(200);
output_high(LAMP2);
delay_ms(900);
output_low(LAMP2);
delay_ms(180);
output_high(LAMP2);
delay_ms(30);
previous = current;
delay_ms(30);
Does anyone else have any ideas?
Regards,
Eugeniu
PostPosted: Sun Jun 14, 2015 11:25 am     Reply with quote
Look up the 'break' statement in a C manual.
Edit:
He solved it per my answer to his question in a PM, that he combine the
two while() loops into one while() loop.
