art
pointers problem |
Posted: Wed Jun 10, 2015 8:07 am |
I have problem with pointers. When I type 1234, B0,B1,B2 and B3 will become high, but if after that i send command 0, B0,B1,B2 and B3 still High. What is wrong with my coding? suppose all port B become low when i send command 0.
#include <18F452.h>
#device PASS_STRINGS=IN_RAM
#use delay(crystal=20MHz)
#include <stdio.h>
#include <input.c>
#include <string.h>
char *ptr;
char arrayChars[10];
ptr=arrayChars;
while(true)
printf("Enter number : %s \n",arrayChars);
get_string(arrayChars,10);
for(ptr=1;ptr<5;ptr++)
if (strcmp(arrayChars, "0" )==0)
output_B(0b00000000);
if (*ptr=="1")
output_high(PIN_B0);
if (*ptr=="2")
output_high(PIN_B1);
if (*ptr=="3")
output_high(PIN_B2);
if (*ptr=="4")
output_high(PIN_B3);
rikotech8
Joined: 10 Dec 2011 Posts: 376 Location: Sofiq,Bulgariq
Posted: Wed Jun 10, 2015 8:55 am |
You compare a char with string *ptr == "1"
"1" is set of two characters '1' and '\0'-string terminator.
Try to enclose 1 in single quotation marks to tell the compiler its type is a single char.
(*ptr=='1')
Another thing that may help is to clear the array arrayChars right above get string function.
Code: | strcpy(arrayChars, ""); |
I hope this will help _________________ A person who never made a mistake never tried anything new. |
Posted: Wed Jun 10, 2015 9:05 am |
There are two separate problems.
First when you declare 'arrayChars', it is not initialised. It could initially contain _anything_, and almost certainly will not contain a terminating '\0'. The first print then could easily result in garbage being displayed.
Then the second problem is that '==' will not compare a _string_. It can compare a character, but your right hand argument is a string. I see Rokotech8, has spotted the same problems, while I was on the phone and typing. |
Posted: Wed Jun 10, 2015 9:14 am |
One more very bad problem. Below, you declare 'ptr' as a char pointer
and initialize it to point to arrayChars[].
ptr=arrayChars;
But then, you use 'ptr' in a for() loop, wiping out the address of
arrayChars which was stored in it:
