WHY?SELECTING CLOCK BITS FROM ADCON0 & ADCON1
madhura027
PostPosted: Mon Jun 08, 2015 3:55 am     Reply with quote
why do we need to select the both clock bits from ADCON0 & ADCON1 in pic16?
What will happen when we select either?
PostPosted: Mon Jun 08, 2015 4:13 am     Reply with quote
1) What chip.
2) Don't. Let CCS handle the selections for you. For 99.9% of things you never need to touch a register in CCS.
3) Normally on the PIC16, the clock selection is entirely done using ADCON1. Loop back to 1.....
Normally ADCON0 controls which channel is selected from the multiplexer, and triggers the actual conversion. ADCON1 sets the clock, voltage reference, and data format. ADCON2 allows the ADC to be started by a 'trigger'.
A few old chips like the 87xA, have the clock selection bits split into 1 in ADCON1 and 2 in ADCON0. The bit in ADCON1 in these actually does nothing. So back to '1'....
madhura027
PostPosted: Mon Jun 08, 2015 4:15 am     Reply with quote
yes..am using 16f877a
